Lando242 Posted February 6, 2022 Share Posted February 6, 2022 (edited) I brought out my old NES after about 25 years in a box and immediately remembered why I parked it. The controller's D-Pads barely work. I disassembled them and found that the black pads on the PCB are almost completely worn away and its worn down through the top layer of the PCD in some places. Is this fixable? If so, how? Just to note, the little silicone pads that are between the plastic buttons and the PCB are near mint somehow. No tearing or cracks. Edited February 6, 2022 by Lando242 Quote Link to comment Share on other sites More sharing options...
Austin Posted February 16, 2022 Share Posted February 16, 2022 The PCBs may still be functional, you'll need to clean them and see. Likewise, you'll want to clean the rubber pad contacts too. You can take a sheet of paper, drag the black side of the contact down against it (you'll see black streaks on the paper). It sort of wipes them clean and makes them fresh again. Do that along with cleaning the PCB and you may find they are still functional. If not, you'll need to get new controllers (fortunately standard official pads are still pretty affordable). Quote Link to comment Share on other sites More sharing options...
CapitanClassic Posted February 16, 2022 Share Posted February 16, 2022 I believe that electrical conductive glue is used on the PCB to bridge the connection when you push the button/D-pad. I think I had some nice ASCII SNES controllers that had a similar problem. The directional pad glue was so worn out that it didn’t close the circuit when pressed I believe it is possible to by electrically conductive glue (think it has graphite in it), but I have never tried to actually fix a controller with that problem. Quote Link to comment Share on other sites More sharing options...
Lando242 Posted February 24, 2022 Author Share Posted February 24, 2022 I cleaned up the controllers and they are better but still not good. Sometimes the D-pad simply fails to respond to presses. Less often now, but it still happens. It is a shame no one makes bog standard replacement PCBs (I don't want to spend $20 to turn it into an 8bitdo BT controller). Quote Link to comment Share on other sites More sharing options...
vintagegamecrazy Posted March 11, 2022 Share Posted March 11, 2022 You can actually buy a jar of carbon conductive paint. Usually spreads with a nail polish applicator which is included. You could always try that to see if it brings them back to life. 1 1 Quote Link to comment Share on other sites More sharing options...
0078265317 Posted April 2, 2022 Share Posted April 2, 2022 (edited) Or just get one of these. https://www.8bitdo.com/retro-receiver-nes/ It pairs nicely with a Wii mote. Then a classic controller attached to the back. Best nes experience ever. Better than the rectangular nes hand cramp pads of back then. And one of the thumbtacks works. Edited April 2, 2022 by 0078265317 1 Quote Link to comment Share on other sites More sharing options...
