Centipede Disassembly
DEBRO
49 minutes ago, DEBRO said:
Hi there,
Hopefully this one is okay. They used the entire 128 bytes of RAM (i.e. 1,024 bits) for this. Enjoy...
Centipede
? great work!
Quote
NTSC ROM usage stats
*** 187 BYTES OF ROM FREE IN BANK0
***   4 BYTES OF ROM FREE IN BANK1
*** 191 TOTAL BYTES FREE
PAL50 ROM usage stats
*** 176 BYTES OF BANK0 FREE
***   0 BYTES OF BANK1 FREE
*** 176 TOTAL BYTES FREE
min. 176 bytes free !
Sounds like a simple case for adding this to the PlusROM High Score Club
41 minutes ago, Gemintronic said:
Seems like the PAL sources tend to use up more ROM in bank 2.  Why is that?
More garbage data.
You can get more free ROM if needed if you build setting the ORIGINAL_ROM flag to FALSE. This will eliminate a lot of garbage data. The stats I reported are from the original ROM builds. Removing the garbage data should give you...
 *** 417 BYTES OF ROM FREE IN BANK0
 *** 24 BYTES OF ROM FREE IN BANK1
On 2/16/2022 at 2:16 PM, DEBRO said:
Hi there,
Centipede
I was able to make the changes for the PlusROM HSC, but it toke me some time.
Free ROM space was not the problem here!
The ROM switches to attraction mode when the game is over and this is the situation where the scores have to be sent. Unfortunately, it uses the same code when it switches from the title screen to attraction mode.
So to prevent the ROM from sending a zero score (or the last score) every time it switches to attraction mode, I had to find a way to distinguish the two cases.
