DocSchlock Posted February 24, 2022 Share Posted February 24, 2022 I have a Lynx II that outputs garbled video but the audio is OK. Thinking it was the original LCD, I bought a BennVenn Rev6 and am getting the same garbled video with it. It would appear this is not an LCD problem but a video signal problem and am wondering if anyone has suggestions on what else I could check. The motherboard is labeled as C104342-001 REV .1 [3] The capacitors, power mosfet and diode have already been replaced. Thinking it could be a bad ribbon cable socket, I direct wired the BennVenn but got the same garbled video result Quote Link to comment Share on other sites More sharing options...
oski_98 Posted February 24, 2022 Share Posted February 24, 2022 Do you have an oscilloscope or logic probe? You can test the pins and compare them to the measurements I posted here. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted February 27, 2022 Share Posted February 27, 2022 Did you remove the RF shielding or did it come that way? Quote Link to comment Share on other sites More sharing options...
DocSchlock Posted February 27, 2022 Author Share Posted February 27, 2022 (edited) -^CrossBow^-: I removed the RF shielding. I have access to an oscilloscope but am no expert. Here are measurements for the pins that the BennVenn LCD uses: VCC - 6.22V DC RES - 6.11V (avg), 59.52 Hz CLKA1 - 4.6V (avg), 6.4vpp, 2.083 MHz CLKA2 - 4.6V (avg), 6.5vpp, 2.083 MHz CLKA3 - 4.6V (avg), 6.6vpp, 2.083 MHz CL2 - 188mv (avg) 5.9vpp, 3.145 Khz DL0, DL1, DL2, DL3 - Logic signal (hard to capture) Measurements were taken between the LCD ground pin (pin 26) and the corresponding pins above. Is the measured voltage of 6.22V too high for the 5V pin? Not sure what would cause that or if that's indicative of another issue. 5V Pin CLKA1 CLKA2 CLKA3 CL2 RESET Edited February 27, 2022 by DocSchlock Updated Image format Quote Link to comment Share on other sites More sharing options...
BennVenn Posted February 28, 2022 Share Posted February 28, 2022 6.22 is too high, its bordering damage to Mike/Suzy/Dram if it hasn't already. Your CLKA1,2,3, RES signals look good. CL2 looks normal but the amplitude of them doesn't - could be an artifact from your scope though or the higher than normal voltages being clipped somewhere. If that LCD kit of ours has the zener installed, it will definitely be shunting some current which will make a mess of some of the waveforms. I suspect it isn't fitted though if you're seeing 6.5v. I'd look into your 5v issues, or power it from usb during testing. The DRAM is pretty sensitive to over voltage but you wouldn't be getting game audio if that was cooked so probably not that. The white band at the bottom of my lcd indicates my board is getting all its signals, and the timings are OK. Fix the 5v and hope that Suzy is ok Quote Link to comment Share on other sites More sharing options...
oski_98 Posted March 2, 2022 Share Posted March 2, 2022 As @BennVenn suggested I would recommend supplying 5V directly to C41. After you sort out the LCD issues, consider either replacing Q12, Q7, Q8, and D13 (there are kits available for this) or buy a USB port, or breakout board, and consider always supplying power through USB. Quote Link to comment Share on other sites More sharing options...
