tripled79 Posted December 5, 2022 Share Posted December 5, 2022 17 hours ago, Thomas Jentzsch said: I suppose you experienced crashes, right? Then you should have a look at this thread and try the first community version which I linked in the last post. Hmm... I followed the the link but I don't see a download anywhere... Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 5, 2022 Share Posted December 5, 2022 6 hours ago, tripled79 said: Hmm... I followed the the link but I don't see a download anywhere... At the end of my last post ("3.9.4. can be found here"), click on "here". Quote Link to comment Share on other sites More sharing options...
tripled79 Posted December 9, 2022 Share Posted December 9, 2022 On 12/5/2022 at 12:18 AM, Thomas Jentzsch said: At the end of my last post ("3.9.4. can be found here"), click on "here". I clicked on "here" but it just leads to another thread with no download link whatsoever. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 9, 2022 Share Posted December 9, 2022 Direct link to the post: Quote Link to comment Share on other sites More sharing options...
pacmanrocks Posted April 4, 2023 Share Posted April 4, 2023 rescue terra 1 and x-man didn't work for me if you want to add those Quote Link to comment Share on other sites More sharing options...
SmartSped Posted May 1, 2023 Author Share Posted May 1, 2023 On 4/4/2023 at 3:42 PM, pacmanrocks said: rescue terra 1 and x-man didn't work for me if you want to add those Hey thanks. I'll add them. Quote Link to comment Share on other sites More sharing options...
SmartSped Posted June 26, 2023 Author Share Posted June 26, 2023 Slots, Oscar's Trash Race, Task Force and Gremlins added. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted June 27, 2023 Share Posted June 27, 2023 I just checked your list. To me it makes little sense, even for the uninformed. IMO it may be even more confusing than helpful. For some games there is a note regarding the missing pin connection. Since you cannot have tested all cart variations of all working games (currently marked as green), why did you not add the same note there too? Theoretically no game in the list should be green following that logic. Also, there are some <=4K games marked red (e.g. Bridge and Checkers). Have you tested tested them with your switch and they failed there too (which would raise the question why this is happening)? Else they also should be marked yellow, because other cart variations might exist and work I would suggest that you only mark games red which use an unsupported bankswitching. Green would makes sense for all others (with the note regarding the pins added). And no yellow anymore. Quote Link to comment Share on other sites More sharing options...
SmartSped Posted June 27, 2023 Author Share Posted June 27, 2023 4 hours ago, Thomas Jentzsch said: I just checked your list. To me it makes little sense, even for the uninformed. IMO it may be even more confusing than helpful. For some games there is a note regarding the missing pin connection. Since you cannot have tested all cart variations of all working games (currently marked as green), why did you not add the same note there too? Theoretically no game in the list should be green following that logic. Also, there are some <=4K games marked red (e.g. Bridge and Checkers). Have you tested tested them with your switch and they failed there too (which would raise the question why this is happening)? Else they also should be marked yellow, because other cart variations might exist and work I would suggest that you only mark games red which use an unsupported bankswitching. Green would makes sense for all others (with the note regarding the pins added). And no yellow anymore. Thanks for the suggestions. Regarding the fist note, I can only mark yellow on the games that I know have variations that don't work (ones that I've tested). On the other green Atari made games, I'm not 100% sure that variants exist with the pin configuration that makes them incompatible with the Retron 77. On the second note, I just didn't know that those games should normally work. If you think they should normally, I can mark them yellow. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted June 27, 2023 Share Posted June 27, 2023 15 minutes ago, SmartSped said: Regarding the fist note, I can only mark yellow on the games that I know have variations that don't work (ones that I've tested). On the other green Atari made games, I'm not 100% sure that variants exist with the pin configuration that makes them incompatible with the Retron 77. Ok, but then you should a that info to the sheet. 15 minutes ago, SmartSped said: On the second note, I just didn't know that those games should normally work. If you think they should normally, I can mark them yellow. Assuming the pins are connected, any game <= 4K should work. And also all games using Atari's F8 or F6 bankswitching. All other games will not work. You can find info (incl. size and bankswitching) about the original games here. Quote Link to comment Share on other sites More sharing options...
SmartSped Posted June 27, 2023 Author Share Posted June 27, 2023 4 minutes ago, Thomas Jentzsch said: Ok, but then you should a that info to the sheet. Assuming the pins are connected, any game <= 4K should work. And also all games using Atari's F8 or F6 bankswitching. All other games will not work. You can find info (incl. size and bankswitching) about the original games here. Thanks! Quote Link to comment Share on other sites More sharing options...
SmartSped Posted October 29, 2023 Author Share Posted October 29, 2023 Added Solar Storm to the list. Quote Link to comment Share on other sites More sharing options...
akator Posted January 6 Share Posted January 6 Anyone know if Mr. Run and Jump works on the R77? Quote Link to comment Share on other sites More sharing options...
yorxs Posted January 13 Share Posted January 13 I just put Mr. Run and Jump into my Retron 77 and it loaded without issue. 2 Quote Link to comment Share on other sites More sharing options...
SmartSped Posted January 13 Author Share Posted January 13 8 hours ago, yorxs said: I just put Mr. Run and Jump into my Retron 77 and it loaded without issue. Thanks for reporting. I'll update my compatibility list today. Quote Link to comment Share on other sites More sharing options...
