Appeelicious Posted March 8, 2022 Share Posted March 8, 2022 So I got a TIPI for what I thought was a solution for all my needs only to find out that I need a true floppy controller in the party so I can use my Plato Interpreter module. So I have a loose floppy controller and a 32k that interfaces with the TIPI. What would it take to rig the floppy controller for use? As I understand the PEB gives power and someplace for the cards and drives to live. Do I need any logic to make the floppy controller work? Or or can I just run cables from the 32k to the floppy controller and the floppy controller to a gotek emulator and just supply power from a PC power supply matching voltages correctly to the floppy controller and the gotek? Quote Link to comment Share on other sites More sharing options...
RXB Posted March 8, 2022 Share Posted March 8, 2022 1 hour ago, Appeelicious said: So I got a TIPI for what I thought was a solution for all my needs only to find out that I need a true floppy controller in the party so I can use my Plato Interpreter module. So I have a loose floppy controller and a 32k that interfaces with the TIPI. What would it take to rig the floppy controller for use? As I understand the PEB gives power and someplace for the cards and drives to live. Do I need any logic to make the floppy controller work? Or or can I just run cables from the 32k to the floppy controller and the floppy controller to a gotek emulator and just supply power from a PC power supply matching voltages correctly to the floppy controller and the gotek? You are going to need a TI floppy controller. Quote Link to comment Share on other sites More sharing options...
Appeelicious Posted March 8, 2022 Author Share Posted March 8, 2022 Right, I do have a TI floppy controller that normally would live in a PEB. Just wondering if I could rig it to the 32k sidecar that interfaces with a TIPI Quote Link to comment Share on other sites More sharing options...
Stuart Posted March 8, 2022 Share Posted March 8, 2022 You can make up a cable/adaptor to connect the floppy controller direct to the sideport - http://www.stuartconner.me.uk/ti/ti.htm#resurrecting_disk_system. But not sure how that arrangement would get on with the 32K and TIPI. 1 Quote Link to comment Share on other sites More sharing options...
Appeelicious Posted March 8, 2022 Author Share Posted March 8, 2022 I would settle for the 32k and the floppy controller playing nice. I'll do some light reading and see what's doable. Thanks for the link! Quote Link to comment Share on other sites More sharing options...
