BBS On a MaxFlash Cartridge YES its Possible
Yes it is possible to put a BBS onto a cartridge, I have succesfully run Forem XE 26M from cartridge, the only thing is that when someone tries to log in, it trys to find everything on the Fujinet, I suspect that if you were to use it with an 850 interface it would work. At the moment I am going to try patching the workbook file and will get back to you if that fixes the problem. This introduces a few problems, saving on the cartridge for #1, it appears to be saving but may actually be read only. I just discovered the problem, you have to eject drive 1 on the Fujinet as it bombs when trying ton read drive 1 from both Fujinet and cart.
