Fabrizio Caruso Posted March 16, 2022 Share Posted March 16, 2022 I know nothing about JagStudio. I would like to support it in my framework (Cross-Lib). To do so, I will need to call JagStudio's compiler from a command line and generate some very simple graphics assets (monochromatic 8x8 tiles) from some data that describes the tiles (just a CSV text file with 8 bytes). Is this doable? Does JabStudio come with a compiler? How can I use it to compile and possible link to any necessary library? The games I can write with Cross-Lib only use trivial monochromatic tiles/characters (usually 8x8), very simple sounds, and some joystick or keyboard input. Obviously ANSI C does not provide APIs for graphics, sounds and input. Does JabStudio come with lib(s) to handle graphics, sounds and input. How do I run a command line to build with support for such APIs? Quote Link to comment Share on other sites More sharing options...
Zerosquare Posted March 17, 2022 Share Posted March 17, 2022 Have you downloaded it and read the documentation? I'm pretty sure it covers most of your questions, if not all. Quote Link to comment Share on other sites More sharing options...
