saxmeister Posted March 17, 2022 Share Posted March 17, 2022 Greetings all, I apologize if this has been covered already, but searches did not turn up anything specific to my issue. I'm following the 7800basic guide at Random Terrain and found the section on fixed point and the instructions stated to use the format: dim playerx = j.k I tried that and then I tried plotting the sprite to the screen and it jumps all over the place. I can't get this to work properly. I go back to declaring the variables like: dim playerx = j And it behaves again, but I want to add smaller numbers to move fractionally. Do I need to convert the numbers to integers before I use them in the plotsprite command? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
+Muddyfunster Posted March 17, 2022 Share Posted March 17, 2022 8 minutes ago, saxmeister said: Greetings all, I apologize if this has been covered already, but searches did not turn up anything specific to my issue. I'm following the 7800basic guide at Random Terrain and found the section on fixed point and the instructions stated to use the format: dim playerx = j.k I tried that and then I tried plotting the sprite to the screen and it jumps all over the place. I can't get this to work properly. I go back to declaring the variables like: dim playerx = j And it behaves again, but I want to add smaller numbers to move fractionally. Do I need to convert the numbers to integers before I use them in the plotsprite command? Thanks for any help. Usually if you have a variable defined as you state in your example to get subpixel increments, then using that for a plotsprite is fine. Can you share your source code that you are using where you are having the problem, it might be something else causing the odd behavior. 2 Quote Link to comment Share on other sites More sharing options...
saxmeister Posted March 18, 2022 Author Share Posted March 18, 2022 Thanks @Muddyfunster! This isn't all of the code (too long to place here) but the pieces that are currently running (up to this point). As my programming teacher told me in college, "My cat knows more programming than anyone else I know. I talk through all of my bugs with my cat and, in the course of explaining it I find the answer." Below is the code that wasn't working properly. I found the issue. displaymode 160A set screenheight 224 set zoneheight 8 set doublewide off BACKGRND=$00 clearscreen dim splitscrn = a dim level = b dim livesleft = c dim playerx = d.e dim playery = f.g dim playerdir = h dim beendefeated = l dim levelbgcolor = m dim isrunning = n dim levelclear = o rem ** Set default values ** livesleft = 3 ; default of three starting lives splitscrn = 0 level = 1 beendefeated = 0 levelclear = 0 ... __Main ; do stuff here... goto __Level01 ; here we would jump to __Level02, __Level03, etc. goto __Main __Level01 if beendefeated=0 then gosub __Level01Intro ; shows a text intro unless this level has been played before if levelclear=1 then return ; return to __Main playerx = 72 playery = 170 playerdir = 2 isrunning = 0 v = 0 x = $00 y = 0 z = 1 var1 = framecounter __Level01Loop clearscreen if livesleft then gosub __ShowLivesLeft gosub __UpdateScore isrunning=0 if x>$FE then x=$00 if !(var1//121) then x=x+1:P5C2=x if joy0up then playery=playery-1:playerdir=0:isrunning=1 ; 0=north if joy0down then playery=playery+1:playerdir=1:isrunning=1 ; 1=south if joy0left then playerx=playerx-1:playerdir=2:isrunning=1 ; 2=west if joy0right then playerx=playerx+1:playerdir=3:isrunning=1 ; 3=east if joy0left && joy0up then playerx=playerx-0.5:playery=playery-0.5:playerdir=4:isrunning=1 ; 4=northwest if joy0right && joy0up then playerx=playerx+0.5:playery=playery-0.5:playerdir=5:isrunning=1 ; 5=northeast if joy0left && joy0down then playerx=playerx-0.5:playery=playery+0.5:playerdir=6:isrunning=1 ; 6=southwest if joy0right && joy0down then playerx=playerx+0.5:playery=playery+0.5:playerdir=7:isrunning=1 ; 7=southeast if !joy0any then isrunning=0 y=y+1 if y > 15 then y=1 z=(y/4) ; calculate the frame to show if isrunning=1 then gosub __DrawMoving if isrunning=0 then gosub __DrawStill isrunning=0 drawscreen goto __Level01Loop ... __DrawMoving rem ** Draw character: If isrunning=1 then animate ** if playerdir=0 then plotsprite north01 7 playerx playery z if playerdir=1 then plotsprite south01 7 playerx playery z if playerdir=2 then plotsprite west01 7 playerx playery z if playerdir=3 then plotsprite east01 7 playerx playery z if playerdir=4 then plotsprite northwest01 7 playerx playery z if playerdir=5 then plotsprite northeast01 7 playerx playery z if playerdir=6 then plotsprite southwest01 7 playerx playery z if playerdir=7 then plotsprite southeast01 7 playerx playery z return __DrawStill rem ** Draw character: If isrunning=0 then don't animate ** if playerdir=0 then plotsprite north01 7 playerx playery if playerdir=1 then plotsprite south01 7 playerx playery if playerdir=2 then plotsprite west01 7 playerx playery if playerdir=3 then plotsprite east01 7 playerx playery if playerdir=4 then plotsprite northwest01 7 playerx playery if playerdir=5 then plotsprite northeast01 7 playerx playery if playerdir=6 then plotsprite southwest01 7 playerx playery if playerdir=7 then plotsprite southeast01 7 playerx playery return __UpdateScore rem ** Update the score in the 320 area up top ** plotvalue atascii 1 score0 2 0 3 return __ShowLivesLeft rem ** Display the number of lives left ** rem ** Displays in the 320 area up top ** temp9=140 for i = 1 to livesleft plotsprite oneup 0 temp9 10 temp9=temp9-9 ; move back 9 pixels for each life displayed next return In the lines where I read the joystick movements, the playerx and playery variables were being added multiple times and causing overflows. I re-ordered the joystick reading to read the diagonal movements first, then the regular compass points. Then, at the end of each of these lines I added a "goto" command to bypass all of the others. Updated code: if joy0left && joy0up then playerx=playerx-0.5:playery=playery-0.5:playerdir=4:isrunning=1:goto __Loop01Movement ; 4=northwest if joy0right && joy0up then playerx=playerx+0.5:playery=playery-0.5:playerdir=5:isrunning=1:goto __Loop01Movement ; 5=northeast if joy0left && joy0down then playerx=playerx-0.5:playery=playery+0.5:playerdir=6:isrunning=1:goto __Loop01Movement ; 6=southwest if joy0right && joy0down then playerx=playerx+0.5:playery=playery+0.5:playerdir=7:isrunning=1:goto __Loop01Movement ; 7=southeast if joy0up && !joy0left then playery=playery-0.5:playerdir=0:isrunning=1:goto __Loop01Movement ; 0=north if joy0down && !joy0left then playery=playery+0.5:playerdir=1:isrunning=1:goto __Loop01Movement ; 1=south if joy0left && !joy0up then playerx=playerx-0.5:playerdir=2:isrunning=1:goto __Loop01Movement ; 2=west if joy0right && !joy0up then playerx=playerx+0.5:playerdir=3:isrunning=1:goto __Loop01Movement ; 3=east if !joy0any then isrunning=0 __Loop01Movement That fixed it and I was able to get the movements to render correctly. Thanks for jumping in to help. That's what is so great about this community. I'm hoping this helps someone else out... 6 Quote Link to comment Share on other sites More sharing options...
+Muddyfunster Posted March 18, 2022 Share Posted March 18, 2022 Good stuff Quote Link to comment Share on other sites More sharing options...
+Karl G Posted March 18, 2022 Share Posted March 18, 2022 8 hours ago, saxmeister said: As my programming teacher told me in college, "My cat knows more programming than anyone else I know. I talk through all of my bugs with my cat and, in the course of explaining it I find the answer." Yup! There's actually a term for it: Rubber Duck Debugging. Anyway; I'm glad you found the cause of your issue. 3 Quote Link to comment Share on other sites More sharing options...
saxmeister Posted March 18, 2022 Author Share Posted March 18, 2022 3 hours ago, Karl G said: Yup! There's actually a term for it: Rubber Duck Debugging. I had forgotten about that! Thanks for a good reminder and a good laugh... 2 Quote Link to comment Share on other sites More sharing options...
