leech Posted March 22, 2022 Share Posted March 22, 2022 So I had ordered a Super Twin 78 Controller a while back, and hoped it would also work on the Amiga. No such luck! So I went hunting for the pinouts... Looks pretty straight forward, unless someone has some caveats? Pin# Atari 7800 Amiga 1 Up Up 2 Down Down 3 Left Left 4 Right Right 5 Button: Right +5V DC 6 Both Buttons Button II 7 Not Connected Not Connected 8 Ground Ground 9 Button: Left Button I All the pins look like they match up except the voltage and buttons. Guess the question becomes; Do I just skip the 'both buttons' connection and +5v DC, then connect 5 -> 6? I was worried after plugging the controller into my A500+ that I'd toasted either the controller or the Amiga port, but another joystick I have seems to work fine still (R-Type on the Amiga is a great port!), and plugged the controller(s) into an iCode adapter, and they all tested out fine there, though I don't think it showed up as different buttons, even though it looks like it should support them. Now I could rewire the Elgaddin controller itself, but I still want to be able to use it on my Atari 7800, or other 8bit computers. Quote Link to comment Share on other sites More sharing options...
Daedalus2097 Posted March 23, 2022 Share Posted March 23, 2022 Okay, there are a couple of issues here. The Amiga pinout is quite wrong for a start. Pin 6 is button 1, pin 9 is button 2 and pin 7 is +5V. The 7800 has a kinda funky controller pinout that's designed to be backwards compatible with the 2600 (both buttons act as button 1 in that case), but that will cause problems with Amiga use unless the Amiga software provides explicit support for the controller. It should be possible to construct an adaptor that allows 2-button use on the Amiga without modifying the controller itself. From the top of my head, the adaptor would wire 7800 controller pin 6 to Amiga pin 8 (ground), controller pin 9 to Amiga pin 6 and controller pin 5 to Amiga pin 9. It might also need controller pin 8 to Amiga pin 7 (+5V). Note that I haven't tried this... 1 Quote Link to comment Share on other sites More sharing options...
