+mksmith Posted March 28, 2022 Share Posted March 28, 2022 Hi all! Thanks @RevEng, @Gemintronic and @Karl G. One of the things with the Linux and macOS releases is I do try and set the chmod permissions (to 777) for folders and files before running the compilers and emulators. As Karl pointed out it was an early issue that cropped up as I don't run macOS myself and only occasionally Ubuntu Linux. If you activate Help -> Toggle Developer Tools and try the compile again it does document the entire process in the logs. The problem might very well show up there if you can take a look for me. 3 Quote Link to comment Share on other sites More sharing options...
+mksmith Posted March 28, 2022 Share Posted March 28, 2022 @RevEng Mike do you think the standard macOS build will run on an M1 ok? [Update] actually I should read the very first part of the post ? Quote Link to comment Share on other sites More sharing options...
+Karl G Posted March 28, 2022 Share Posted March 28, 2022 17 hours ago, mksmith said: @RevEng Mike do you think the standard macOS build will run on an M1 ok? It appears that dasm runs if the execute bit is set, so I would expect the other binaries to run, too. 2 Quote Link to comment Share on other sites More sharing options...
RevEng Posted March 28, 2022 Share Posted March 28, 2022 Not really sure, since I have no experience with the M1 cross-compatibility. It seems like dasm is running, so that's a good sign. The 2600basic.sh script *should* be ok, based on what I've seen too. If someone ships me an M1 MacBook Pro, I will definitively confirm. 1 Quote Link to comment Share on other sites More sharing options...
+Karl G Posted March 29, 2022 Share Posted March 29, 2022 14 hours ago, RevEng said: 2600basic.sh script *should* be ok, based on what I've seen too. Would it not fail when it doesn't find anything with the .arm64 extension (uname -m)? Quote Link to comment Share on other sites More sharing options...
RevEng Posted March 29, 2022 Share Posted March 29, 2022 4 minutes ago, Karl G said: Would it not fail when it doesn't find anything with the .arm64 extension (uname -m)? No, it does this scanning thing, where it tries hardcoded .x86 and .x64 extensions first, before trying the one discovered from uname -m. Whichever form actually runs without error first is used. 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted March 30, 2022 Share Posted March 30, 2022 Haven't tried doing the chmod thing yet. instead I got it "working" by.. Installing the Mac "Intel Chip" only version of Visual Studio Code on your M1. Created a small batari BASIC program that randomizes the background then saved and compiled fine. Even launched Stella. So, counterintuitive as it seems.. just run the Intel VS Code instead of Universal or "Apple Silicon" for now? 2 3 Quote Link to comment Share on other sites More sharing options...
rsiddall Posted March 30, 2022 Share Posted March 30, 2022 13 minutes ago, Gemintronic said: Haven't tried doing the chmod thing yet. instead I got it "working" by.. Installing the Mac Intel only version of Visual Studio Code. Created a small batari BASIC program that randomizes the background then saved and compiled fine. Even launched Stella. So, counterintuitive as it seems.. just run the Intel VS Code instead of Universal or "Apple Silicon" for now? I can confirm this works...I guess it's just running Rosetta to emulate the Intel version. But it does, indeed, work. ? 2 Quote Link to comment Share on other sites More sharing options...
+stephena Posted March 30, 2022 Share Posted March 30, 2022 Just to add to this. The next version of Stella (6.7) will be a fat binary with Intel64 and ARM64 (M1) support. It compiles and runs fine; I just forgot to enable the M1 build in the last release. 5 1 Quote Link to comment Share on other sites More sharing options...
+mksmith Posted March 31, 2022 Share Posted March 31, 2022 Well done @Gemintronic in determining how this can work! I'll add an update to the ADS info for future macOS users to install the Intel VS Code version for the time being! Thanks @stephena for the update! 1 Quote Link to comment Share on other sites More sharing options...
ColecoGamer Posted March 31, 2022 Author Share Posted March 31, 2022 On 3/28/2022 at 5:06 PM, Gemintronic said: So, I started to feel like my advice was too confusing or too strange. Decided to prove it to myself aaaaand.. PlayOnMac on M1 is very touchy. Wouldn't even install the latest Visual Studio Code. Crossover just got a recent update so I had high hopes. Visual Studio Code and Atari Dev Studio installed but I cannot compile. Apologies for the bunk advice. The only thing that %100 percent works is Parallels and a Windows ARM virtual machine. sigh. How do we obtain a copy of Windows ARM? When I search online, it takes me to a Microsoft website that states, ‘Beta testing is now closed’ for Windows Arm. I own the latest M1 compatible version of Parallels. ? Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted March 31, 2022 Share Posted March 31, 2022 1 hour ago, ColecoGamer said: How do we obtain a copy of Windows ARM? When I search online, it takes me to a Microsoft website that states, ‘Beta testing is now closed’ for Windows Arm. I own the latest M1 compatible version of Parallels. ? I'm pretty sure Parallels itself gave me some help getting a Windows ARM image. https://kb.parallels.com/125375 Windows 10 ARM might not support 64-bit x86 programs. So, Windows 11 might be the way to go. Not an evil move at all, Microsoft. 1 Quote Link to comment Share on other sites More sharing options...
ColecoGamer Posted October 8, 2022 Author Share Posted October 8, 2022 Any updates on an M1 compatible version yet? Quote Link to comment Share on other sites More sharing options...
+Karl G Posted October 8, 2022 Share Posted October 8, 2022 8 minutes ago, ColecoGamer said: Any updates on an M1 compatible version yet? I think we determined earlier in the thread that the existing binaries should run on a M1 Mac. If you have tried and run into problems, post them here and we can see if we can figure them out (I only have an Intel Mac so I can't test directly). 1 1 Quote Link to comment Share on other sites More sharing options...
MikeDX_ Posted March 16 Share Posted March 16 (edited) Just in case anyone wants to re-visit this. I resolved this as follows: Install VS code and installed the vscode atari dev studio extension Cloned bB from github and built using make git clone git@github.com:batari-Basic/batari-Basic.git cd batari-Basic make Copied the binaries which were generated by make to the vscode extension folder (this assumes you cloned and built bB in ~/src/batari-Basic cd ~/.vscode/extensions/chunkypixel.atari-dev-studio-0.8.6/out/bin/compilers/bB cp ~/src/batari-Basic/2600basic 2600basic.Darwin.arm64 cp ~/src/batari-Basic/bbfilter bbfilter.Darwin.arm64 cp ~/src/batari-Basic/optimize optimize.Darwin.arm64 cp ~/src/batari-Basic/postprocess postprocess.Darwin.arm64 cp ~/src/batari-Basic/preprocess preprocess.Darwin.arm64 installed dasm via homebrew brew install dasm copied the dasm binary to the vscode extension folder cp /opt/homebrew/bin/dasm dasm.Darwin.arm64 Downloaded stella from the website and copied the stella.app into a newly created "arm64" folder cd ~/.vscode/extensions/chunkypixel.atari-dev-studio-0.8.6/out/bin/emulators/stella/darwin mkdir arm64 cp -R /Applications/Stella.app arm64 I think that was everything, and it seemed to work well. Edited March 16 by MikeDX_ 3 Quote Link to comment Share on other sites More sharing options...
Darkhog Posted June 10 Share Posted June 10 (edited) On 3/28/2022 at 10:39 PM, rsiddall said: Sorry, I ran it again with the "cd" and got: cd ~/.vscode/extensions/chunkypixel.atari-dev-studio-0.7.2/out/bin/compilers/bB ./dasm.Darwin.x64 zsh: permission denied: ./dasm.Darwin.x64 I can cd to the directory and manually drop "dasm.Darwin.x64" onto the terminal and it still won't run. Gives the "permission denied". I know it's not Linux, but mac, but on Linux when I got this kind of error it usually meant that the file didn't have the execution privilege set. Tried doing chmod +x on it? Edited June 10 by Darkhog 1 Quote Link to comment Share on other sites More sharing options...
r_chase Posted June 11 Share Posted June 11 On 6/10/2023 at 4:24 AM, Darkhog said: I know it's not Linux, but mac, but on Linux when I got this kind of error it usually meant that the file didn't have the execution privilege set. Tried doing chmod +x on it? I somehow had a couple issues because missing packages and a makefile that needed cleanup on my Raspberry Pi 400, but I will say that compiling batariBasic on ARM64 Linux does indeed work. The problem is that I'm not sure what to make using bB yet. I have a couple ideas, but I don't know what to do to execute them, y'know? Quote Link to comment Share on other sites More sharing options...
rsiddall Posted June 12 Share Posted June 12 On 6/10/2023 at 4:24 AM, Darkhog said: I know it's not Linux, but mac, but on Linux when I got this kind of error it usually meant that the file didn't have the execution privilege set. Tried doing chmod +x on it? If you look directly above your post, another member (MikeDX_) posted on how to resolve the issue. My workaround was installing the existing binaries on my M1 Mac. Quote Link to comment Share on other sites More sharing options...
