Corcomp 9900 MES - Disk Controller + 32K Board Recreation
acadiel
34 minutes ago, HOME AUTOMATION said:
I have a pile, all from old hard drives.;)
Understood, I probably do too, somewhere out in deep storage. Getting ready to place a small order to Digikey or Mouser and thought I'd go ahead and get one to see if it fixes my CC  MES. Thanks for responding. I also probably need to change out one of the 22 pin ones  on J2 also, as it appears damaged, though I think it checked out fine when tested 2 years ago.
I think I found them at Digikey, about insulation height .335 inches tall, contact length on post . 126 inches? part # PPPC021LFBN-RC
Edited by RickyDean
added content
  • 4 months later...
I decided to burn replacement Gal chip for the upper section. I did one at a time, starting with U11, nothing changed. Then I replaced U10 and it woke up some with Extended basic seeing the 32k when you type in size, but none of the ram testers sees the ram. I tried replacing U9, but no change.
Then I went into the Corcomp peripherial test and it said that on the 32k test:
"Error Found at Address >2010
Value Written = >2010
Value Read + >2000"
Does this sound like a bad TMS4500, though I've changed it out with two other, believed good, 4500's, or bad dram? Or one of the two 9901's bad?
Edited by RickyDean
spelling
I just tried a HXC emulated disk on the MES and it now accesses the drive but I get a disk not intialized message or an error 16 no disk or dosk drive present. These are known good 40 track disk images.
Edited by RickyDean
spelling, added content
