New offering from Lotharek
So this device would allow you to connect your ST to any modern TV in low, medium and high rez?  No need for 15khz monitors and such?
Im confused on the 8bit part of this.  I have no problem connecting my 130XE to any modern TV via the old switch box or Composite plugs.
I works assume it would be if you wanted to use SVideo to HDMI. I also connect my XEGS to the composite ports (called AV ports on my TV).
I assume this would be most useful to ST owners or someone with a VBXE which I think also uses 15kHz RGB.
Bob C
  • 2 months later...
  • 7 months later...
I have a medusa and use it with my ST, Amiga, Spectrums and Amstrad CPCs. I get better results with the Medusa than I do with my OSSC. It's a gret piece of kit.
I nice to be able to use all three resolutions with one convertor.
