coleconut Posted April 8, 2022 Share Posted April 8, 2022 Located in Canada, Im looking for suggestions on using a monitor or TV with my Japanese Sony MSX2 I have on order. The connector on the computer itself is I believe an 8-pin DIN plug. I have in my stockpile a PAL TV with SCART connector, rest have no SCART - a Commodore 1902a, various models of Amiga monitors 1080, 1084, 1084s, a Sony 1302A Any one of these means putting together a custom cable I expect. Anyone using one of these or have a suggestion? Quote Link to comment Share on other sites More sharing options...
Tempest Posted April 8, 2022 Share Posted April 8, 2022 I have an MSX 2+ and I think it just had a composite plug on it. I was able to get it S-Video modded and it looks super sharp so that's what I use now. Which model do you have? I wasn't aware that the MSX used any special monitor connector. Got a picture? Quote Link to comment Share on other sites More sharing options...
youxia Posted April 8, 2022 Share Posted April 8, 2022 (edited) 5 hours ago, coleconut said: Any one of these means putting together a custom cable I expect. I'm currently struggling with figuring out one for DIN 8A - SCART for my Japanese MSX2. Somebody made one for me just yesterday according to info from this thread and wiki, but it doesn't work. Not sure why, since I don't know anything about electronics, but lack of clear schematic is not helping. There is more info on their wiki, so maybe you will find one for yourself. I have it connected via composite atm, and it's okay, but RGB would be much better (as I can see from my MiSTer). Edited April 8, 2022 by youxia Quote Link to comment Share on other sites More sharing options...
carlsson Posted April 8, 2022 Share Posted April 8, 2022 I think there are at least a handful different monitor pinouts on various MSX computers, so while they're internally the same in terms of hardware, the connectors are not identical. Regarding which screen to use, the 1084 ones should have analog RGB input through a DIN connector if it doesn't have SCART. Yet even if the number of pins in both ends would be the same, you can't expect that a direct cable in any way is compatible before looking it up. 1 Quote Link to comment Share on other sites More sharing options...
CatPix Posted April 19, 2022 Share Posted April 19, 2022 MSX tried to have a standard for video pinout but it wasn't required and as such several manufacturers made their own thing. Your PAL TV most likely support 60 htz so it would be a good candidate. You will probably have to make your own cable, but there are normally no oddities in cabling; no resistors or caps to add, just 8 wires to solder. Quote Link to comment Share on other sites More sharing options...
jltursan Posted April 22, 2022 Share Posted April 22, 2022 It's easy, check RGB (8-pin DIN 45326) at MSX.org Using the analog DIN6 connector of a 1084 it's just a matter of wire same signals. MSX's composite sync goes to the H-Sync pin of the monitor. The only drawback is you need to split the monitor's end to route the audio to the 1084 RCAs. 1 Quote Link to comment Share on other sites More sharing options...
