Game Cheats or Trainers
Khaizeka
What I meant was, how are these codes entered? While the game is running? I think with some you may have to alter a copy of the game with a sector editor, which I know nothing of.
Sorry if I wasn't or am not being too clear, and thanks for any advise.
Here is an example of another type puzzling me
SERPENTINE
BLOADSERPENTINE
CALL-151
81A:# SERPENTS
7FDG
I'm guessing Bload means to binary load this from dos?
That's all I can figure out.
Thanks again for your help!
SERPENTINE
BLOADSERPENTINE
CALL-151
81A:# SERPENTS
7FDG
Exactly.
"CALL -151" enters the built-in firmware debugger.  Then you just memory-edit the program (that's what the "81A:" is) and start it with the 7FDG command.
Alternatively in AppleWin after it loads you can enter the debugger and modify the memory address with the "meb" command.
5 hours ago, Khaizeka said:
SERPENTINE
BLOADSERPENTINE
CALL-151
81A:# SERPENTS
7FDG
In this case, you're talking about a single game file so there's no need to sector edit. Let's say you want to permanently change the number of serpents in your copy of the game to 15 (0F in Hex). Before running the game, you'll want to exit back to DOS to save the file on your disk image. You can exit the monitor by pressing CTRL-C and Enter or typing 3D0G (that's a zero not an "O") and Enter. After that you need to find the starting address and length for the SERPENTINE file so you can save it to disk.
BLOAD SERPENTINE
CALL -151
81A:0F
3D0G
To find the starting address in decimal (XXXX):
PRINT PEEK(43634)+PEEK(43635)*256
To find the length in decimal (YYYY):
PRINT PEEK(43616)+PEEK(43617)*256
To save your trained version of SERPENTINE:
BSAVE SERPENTINE,AXXXX,LYYYY
As an example, let's say the starting address returned: 16384
and the length returned: 8192
You'd then save your file with: BSAVE MYGAME,A16384,L8192
Then you can jump back into the monitor with CALL -151 and type 7FDG (this means run whatever is at Hex memory address: 7FD) to start your game or you can run it back from disk with BRUN SERPENTINE.
