ATASCII ASCII Assembly question on "A" = $21?
Hi folks,
Going back to basics here.
Watching Ed on YouTube:
And testing out the code:
https://github.com/EdSalisbury/edventure/blob/episode_1/main.asm
Question:
Why are the uppercase letters not following ASCII with "A" = decimal 65, etc.? (i.e., hex $41 for "A")
I noticed the lowercase are correct, lowercase "a" being $61 hex
I looked at the Disassembly and the Hex Dump on Altirra, and checking it on the ATASCII table just to be sure.
Edited by atarialoha
The order of the characters in the character ROM aren't all the same as ASCII.
This is due to how Graphics 1 and 2 work - they only allow 64 characters with the upper 2 bits choosing which PF colour to use for the foreground.
The problem you'd get there is that with default ASCII order, the space, numbers and most of the symbols are in the lower 64 but upper/lower case are in the top 64.
The solution used is to move the alpha characters down to the second half of the first block of 64.  Then the numbers and symbols (mostly shifted numbers) are moved to the first half of that block.
The second block has the control graphics followed by lower case.
The other benefit is that space becomes code 0 - the clear screen routine can be shared with bitmap modes.
You can use the second half of the character set in Gr. 1 and 2 to get lower case but the problem is there's no space character (heart will show instead) - this can be overcome by copying the character set to Ram then blanking that one out.
