Sayonara! Posted April 17, 2022 Share Posted April 17, 2022 I'm having some issues with the vram on the ti-99/4a. I have figured out that chip 5 is bad and needs a replacement. I've failed to find a replacement online, does anyone have a link to a replacement chip for this? what I can read on the chip is NEC 8245DF400. Thanks in advance Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted April 17, 2022 Share Posted April 17, 2022 If you look in the FAQ you will find information on this, I have ram in my store it's 4164 which is easily modified (or use one of the boards I sell to drop in with it) 4164 runs cooler and lasts longer and is easier to source 2 1 Quote Link to comment Share on other sites More sharing options...
Ed in SoDak Posted April 17, 2022 Share Posted April 17, 2022 (edited) 16 hours ago, Sayonara! said: what I can read on the chip is NEC 8245DF400. Thanks in advance That's the date code, 45th week of 1984. The chip is a 4116, in stock about $4 each at Jameco Electronics for example. Jameco should have a low-cost first class mail shipping option. Bummer for small orders from them, there's a $10 surcharge on orders less than $20. There's other places too, I saw at least one listing on ebay. Just be aware some parts sourced from China can potentially be bogus relabeled chips. It's best to order from a US company with a good reputation of long-standing. Or the 4164 can be substituted with modification as arcadeshopper says. Edited April 17, 2022 by Ed in SoDak 2 1 Quote Link to comment Share on other sites More sharing options...
Sayonara! Posted April 17, 2022 Author Share Posted April 17, 2022 4 hours ago, Ed in SoDak said: That's the date code, 45th week of 1984. The chip is a 4116, in stock about $4 each at Jameco Electronics for example. Jameco should have a low-cost first class mail shipping option. Bummer for small orders from them, there's a $10 surcharge on orders less than $20. There's other places too, I saw at least one listing on ebay. Just be aware some parts sourced from China can potentially be bogus relabeled chips. It's best to order from a US company with a good reputation of long-standing. Or the 4164 can be substituted with modification as arcadeshopper says. Thanks, I just ordered a 4116 chip off eBay and am going to replace the bad chip on the ti 1 Quote Link to comment Share on other sites More sharing options...
mvancopp Posted April 18, 2022 Share Posted April 18, 2022 (edited) 23 hours ago, Sayonara! said: I'm having some issues with the vram on the ti-99/4a. I have figured out that chip 5 is bad and needs a replacement. I've failed to find a replacement online, does anyone have a link to a replacement chip for this? what I can read on the chip is NEC 8245DF400. Thanks in advance I bought some from this place and all the chips worked fine and were in really good shape. Texas Instruments - TMS4116-15NL - IC, Memory. DRAM, 16,384 Bit. (electronicsurplus.com) Edit: I just checked and they still have > 400 in stock. Edit2: Another place but you may need to buy 24 for 28+ sh. I haven't purchased for this place. 4116 RAM Set of 24 (arcadeshop.com) Mark Edited April 18, 2022 by mvancopp Add new source Quote Link to comment Share on other sites More sharing options...
XLERB Posted April 28, 2022 Share Posted April 28, 2022 On 4/17/2022 at 1:08 PM, arcadeshopper said: If you look in the FAQ you will find information on this, I have ram in my store it's 4164 which is easily modified (or use one of the boards I sell to drop in with it) 4164 runs cooler and lasts longer and is easier to source 4164 works just fine! 1 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted April 28, 2022 Share Posted April 28, 2022 On 4/17/2022 at 9:38 PM, mvancopp said: I bought some from this place and all the chips worked fine and were in really good shape. Texas Instruments - TMS4116-15NL - IC, Memory. DRAM, 16,384 Bit. (electronicsurplus.com) Edit: I just checked and they still have > 400 in stock. Edit2: Another place but you may need to buy 24 for 28+ sh. I haven't purchased for this place. 4116 RAM Set of 24 (arcadeshop.com) Mark I've bought a lot of good things from Electronicssurplus.com in the past. Among other things, I bought a few hundred hexbus controller chips from them a few years back, probably the entire NOS supply of them on Earth. 1 Quote Link to comment Share on other sites More sharing options...
JJB Posted November 12, 2022 Share Posted November 12, 2022 Just adding info to this topic as I have just replaced my QI 4116's with 4164's. I had given my non-QI console the same treatment in the past but found removing the original RAM's and replacing them with sockets a royal pain the backside. This time I decided to snip a couple of 4116 pins and piggyback the 4164's on top: - snip 4116 pin 1, 8 and 9 as close to the chip as possible and bend the PCB side remnants out of the way - fold 4164 pins 1, 8 and 9 back on the top of the chip - lightly tin 4116 pins with fresh solder, making sure the pad solder melts too - lightly tin 4164 pins - piggyback a 4164 on 4116 (this is the fiddly bit) and when you're happy with its position, solder 1 4164 pin to its 4116 mate. - solder the remaining pins; with a little bit of fresh solder on your iron, start from the PCB pad and work your way up. - solder a small length of stiff connecting wire to the PCB remnant of pin 9 - connect the other side of the wire to pins 8 and 9 on top of the 4164, taking care the wire doesn't touch any other pins. I did 1 chip at the time, checking for the familiar start screen in between to see if all pins were properly connected (giving the 4164's a little twist at the same time). Jochen 3 1 Quote Link to comment Share on other sites More sharing options...
