I'm trying to fix my old SC1224 (goldstar ca-3) monitor which was in basement around 20 years ;-). I know that it was faulty when it was stored. Root cause was as kid I broke V.Lin adjustable resistor (R635) and it was replaced by someone who at that time had TV repair shop ;-), but still not working. I run it and it was looks like that V deflection is not working (big white line on the screen). I figured out that V.Size adjustable resistor (R616) had broken leg, so I fixed and right now I have grey screen see picture. This screen is without signal from atari st. I tried to adjust all 5 adjustable resistor, but no luck (with and without signal). When signal is give there is some change in sync. My monitor is 110v, my atari is 220v, but I'm using improved TOS switching between 50Hz/60Hz there some difference on screen, but I wasn't able to see any picture that at least I can recognise it's always grey.
I'm not electronics hobbies and it's first time when I'm trying to fix CRT monitor. I scan repair manual and I don't recognise flow which match to this. As I understand in case of missing sync I should see something and in case of missing signal screen should be black, but not in my case.
Any hint is welcome, what is worth to check? I googled a lot, but found one similar case, but not solution there, discussion at the end was about signal for atari st.
https://forums.atariage.com/topic/334469-sc1224-grey-screen-with-lines/
With no signal, that looks like the tube is being overdriven (brightness circuit), apart from the normal control
on the front, there should be some adjustment of the coarse brightness. Could also be caused by tube avoervoltage
but that requires specialist equipment to check.
Look for any adjusters around the HT circuit, please don't do this with it powered, any adjustment should
be done with long plastic screwdrivers, if your not sure, would be best to see if there's someone who
can still fix these things.
  • 5 weeks later...
2 hours ago, Paweł said:
Yes, please check 3rd post in this thread (#3)
Actually, the question (I believe) was what steps did you take to narrow down the problem.  I think that would be something of interest as troubleshooting monitor issues is probably a weak point for most of us here.
  • 1 year later...
I have very similar problem. Grey screen only. sc1425
Based on post 1 and wanting to take a wild pot shot guess, and I'd have to find the schematics, I would surmise that R363 might pertain to the brightness part of the circuit? Given the number of resistors on the circuit board, it's not quite a needle in a haystack but approaching it... resistors don't go bad as often but it does happen, of course... yay for entropy!
I'd probably replace the capacitors on the board as well for good measure as well - after ensuring they're all discharged...
Edited by CommodoreDecker
