+TheBF Posted May 14, 2022 Author Share Posted May 14, 2022 6 hours ago, speccery said: Just realised I was missing the repeat loop, i.e. the thing should be run 10 times, here is that result: At 8.69 seconds I am behind the assembly version on the TMS9900, so will definitely need to optimise the interpreter I think you beat it. On a stock console Bill's hand coded solution runs in 10 seconds. I will put you in the record books. 1 Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted May 14, 2022 Share Posted May 14, 2022 (edited) On 5/14/2022 at 9:20 AM, TheBF said: I think you beat it. On a stock console Bill's hand coded solution runs in 10 seconds. I will put you in the record books. On Classic99 it runs in about 9.3 - 9.4 seconds. That's hand-timed. Edited to add: On a stock console it runs in 9.35 seconds. Edited June 18, 2022 by Reciprocating Bill Stock console Quote Link to comment Share on other sites More sharing options...
+TheBF Posted May 14, 2022 Author Share Posted May 14, 2022 33 minutes ago, Reciprocating Bill said: On Classic99 it runs in about 9.3 - 9.4 seconds. That's hand-timed. I think my old Dell struggles a bit. Classic99 is using 6..7% of the CPU. So I saw closer to 10 here. I will push it over to my stock console and double check. 1 Quote Link to comment Share on other sites More sharing options...
atari1byte Posted July 3, 2022 Share Posted July 3, 2022 On 5/14/2022 at 8:29 AM, speccery said: After some bug fixing, I got the Sieve running on the StrangeCart Basic. Needed to fix a problem with FOR loop handing when the initial value was already exceeding the limit. Also increased the size of symbol space (as I call it) to 40kbytes, so that the DIM for the flags succeeds. Below are screenshots of a run on the actual hardware as well as the listing of the TI Basic program. This cannot be run on the normal TI Basic, since the array size exceeds RAM space. Also for convenience line 110 makes the DIM based on a variable value, this does not work with TI Basic. The runtime is 0.86 seconds with current firmware version. And here is the listing. I also edited this so that the code reads as below, which can be run on TI Basic. It takes about 47 seconds to run. On the StrangeCart Basic this takes just under 0.14 seconds. This is only 340 times faster, so I still have optimisation work to do, I haven't focused on optimisation yet. Without I/O the Basic runs at around 60.000 to 80.000 lines per second. Excuse me, where can i find this basic that handles array 8192 numbers? Thanks ! Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted July 3, 2022 Share Posted July 3, 2022 This BASIC, is under development, and runs on special hardware... Quote Link to comment Share on other sites More sharing options...
speccery Posted July 4, 2022 Share Posted July 4, 2022 22 hours ago, atari1byte said: Excuse me, where can i find this basic that handles array 8192 numbers? Thanks ! Yes, like @HOME AUTOMATION linked to my thread above, this is a re-creation of TI BASIC running on a processor on a cartridge, not on the stock TI-99/4A. It also uses single precision floating point as the default data type, so each array entry takes 4 bytes instead of the 8 with TI BASIC. Thus larger arrays become possible - the StrangeCart has 192K of RAM, of which something like 128K is available to BASIC. At the moment the BASIC programs, in terms of program length, are limited to saved TI BASIC programs, which in turn have to fit into 16K VDP RAM. But the variable space is on top of that and currently I have set it to something like 40K. These are compile time options in the firmware. Quote Link to comment Share on other sites More sharing options...
atari1byte Posted July 4, 2022 Share Posted July 4, 2022 47 minutes ago, speccery said: Sì, come AUTOMAZIONE @HOME collegato al mio thread sopra, questa è una ri-creazione di TI BASIC in esecuzione su un processore su una cartuccia, non sul TI-99/4A di serie. Utilizza anche la virgola mobile a precisione singola come tipo di dati predefinito, quindi ogni voce di matrice richiede 4 byte invece degli 8 con TI BASIC. Così diventano possibili array più grandi: StrangeCart ha 192K di RAM, di cui qualcosa come 128K è disponibile per BASIC. Al momento i programmi BASIC, in termini di lunghezza del programma, sono limitati ai programmi TI BASIC salvati, che a loro volta devono adattarsi alla RAM VDP 16K. Ma lo spazio variabile è in cima a quello e attualmente l'ho impostato su qualcosa come 40K. Queste sono le opzioni del tempo di compilazione nel firmware. Hi! Interesting!!! StrangeCart Basic is only real hardware? ps. Thanks to the forum I'm also starting to work on RXB is a little slow.... I need to learn how to use it! Quote Link to comment Share on other sites More sharing options...
speccery Posted July 4, 2022 Share Posted July 4, 2022 2 minutes ago, atari1byte said: Hi! Interesting!!! StrangeCart Basic is only real hardware? ps. Thanks to the forum I'm also starting to work on RXB is a little slow.... I need to learn how to use it! Yes it's only real hardware. It's not totally impossible imagining to run it on classsic99, but that is not a small project... Quote Link to comment Share on other sites More sharing options...
atari1byte Posted July 4, 2022 Share Posted July 4, 2022 47 minutes ago, speccery said: Yes it's only real hardware. It's not totally impossible imagining to run it on classsic99, but that is not a small project... I have a TI 99... I haven't turned it on in 45 years.... I don't know if it still works! I'd like to turn it on again. The price of the cartridges ? 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 14 Author Share Posted February 14 I got a version of this running with my JIT compiler early December last year but I forgot to cross-post it here. This JIT is limited it can only optimize Forth words that are written in Assembly Language it can replace all looping and branching words with native code equivalents (big win) it replaces variables and constants with native code that loads the accumulator register with LI instruction This happens to be enough to optimize the entire inner loop of the Byte Mag. sieve. Here is the final source code that uses the JIT compiler. Spoiler \ BYTE MAGAZINE SIEVE \ 10 ITERATION TIMINGS \ Normal OPT \ Camel99 DTC 104 50.5 (jit.fth DTC version) \ TurboForth 107 \ Camel99 ITC 120 50.1 (jit2b.fth) \ FbForth 2.0:13 174 NEEDS ELAPSE FROM DSK1.ELAPSE NEEDS JIT: FROM DSK1.JIT NEW-HEAP DECIMAL 8190 CONSTANT SIZE 0 VARIABLE FLAGS SIZE ALLOT 0 FLAGS ! HEX JIT: DO-PRIME FLAGS SIZE 01 FILL 0 SIZE 0 DO FLAGS I + C@ IF I DUP + 3 + DUP I + BEGIN DUP SIZE < WHILE 0 OVER FLAGS + C! OVER + REPEAT DROP DROP 1+ THEN LOOP ;JIT DECIMAL : PRIMES ( -- ) PAGE ." 10 Iterations" 10 0 DO DO-PRIME CR . ." PRIMES" LOOP CR ." Done!" ; 2 Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted February 14 Share Posted February 14 And time to execute 10 iterations is.... Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 14 Author Share Posted February 14 22 minutes ago, Reciprocating Bill said: And time to execute 10 iterations is.... oops. 50.1 seconds. So big improvement from 120 with threaded code, but way off your 10 seconds. 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 15 Author Share Posted February 15 Down the rabbit hole I went... So I wondered was that really the best I could do? What other tricks have I developed over all this time? Included FILLW which fills word at a time not bytes (like the ASM version Bill did) Included CODEMACROS to give Forth indexed addressing ability make getter & setter words for the array with the indexed addressing macros Modernized the Forth code: changed VARIABLE to CREATE changed "DUP +" to 2* "DROP DROP" to 2DROP Pre-initialize the 1st 2 bytes of the array to zero Include the JIT compiler JIT the inner loop Spoiler \ BYTE MAGAZINE SIEVE WITH TABLE: and FILLW \ 10 ITERATION TIMINGS \ Normal JIT + indexed addressing + code improvement \ TurboForth 107 \ Camel99 ITC 120 37.8 \ FbForth 2.0:13 174 NEEDS JIT: FROM DSK1.JIT NEEDS ELAPSE FROM DSK1.ELAPSE NEEDS FILLW FROM DSK1.FILLW NEEDS ()C!, FROM DSK1.CODEMACROS DECIMAL 8192 CONSTANT SIZE CREATE FLAGS SIZE ALLOT \ getter and setter for FLAGS ARRAY MACRO ]FLAGS@ ( ndx -- c ) FLAGS ()C@, ;MACRO MACRO ]FLAGS! ( c ndx -- ) FLAGS ()C!, ;MACRO HEX NEW-HEAP JIT: DO-PRIME FLAGS SIZE 0101 FILLW FLAGS OFF -1 SIZE 0 DO I ]FLAGS@ IF I 2* 3 + DUP I + ( cntr ndx1 ndx2 ) BEGIN DUP SIZE < WHILE 0 OVER ]FLAGS! OVER + REPEAT 2DROP 1+ THEN LOOP ;JIT DECIMAL : PRIMES ( -- ) DECIMAL PAGE ." 10 Iterations" 10 0 DO DO-PRIME CR . ." PRIMES" LOOP CR ." Done!" ; And here is what happened. About 3.2 times faster. I think this is as fast I can get using just Camel99 Forth extensions. 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 17 Author Share Posted February 17 I re-worked Bills' Assembler version to compile in Forth Assembler to finish the series. It is a thing of beauty to watch on Tursi's heatmap display. The code was so organized that it dropped perfectly into the structured looping used by the Forth assembler. I broke out the array initializer as a sub-routine which costs a few milli-seconds but not a big deal. In this example I BLWP to a new workspace so I didn't have to re-work Bill's register allocations. That is easy with a PROG: directive I created for Camel99 Forth. At compile time PROG: takes a workspace argument and creates it's own vector. At run-time it does a BLWP to its vector and after RTWP it returns to Forth. Spoiler \ SIEVE in Forth Assembler based on code by @Reciprocating Bill on atariage.com \ Original notes by BIll. \ * SIEVE OF ERATOSTHENES ------------------------------------------ \ * WSM 4/2022 \ * TMS9900 assembly adapted from BYTE magazine 9/81 and 1/83 issues \ * 10 iterations 6.4 seconds on 16-bit console \ * ~10 seconds on stock console NEEDS DUMP FROM DSK1.TOOLS NEEDS MOV, FROM DSK1.ASM9900 \ PROG: is compiler extension for Forth \ - at compile time creates 9900 Vector with workspace and entry address \ - at run-time it does a BLWP to it's own vector : PROG: ( wksp -- ) CREATE , HERE CELL+ , !CSP ;CODE *W BLWP, NEXT, ENDCODE : ;PROG ( -- ) ?CSP ; \ check stack position for junk left on it. \ macro to give you Forth's TOS register from a foreign workspace : [TOS] ( -- ) 8 R13 () ; DECIMAL 8190 CONSTANT SIZE CREATE FLAGS SIZE CELL+ ALLOT CREATE WRKSP2 16 CELLS ALLOT \ ---------------------------------------- \ Registers used \ R0 I loop index \ R1 prime address \ R2 inner loop address (K) \ R7 NUMBER 0 for byte comparison \ R5 0101 \ R6 base address of flags array \ R8 size of array \ R10 prime number counter HEX CREATE INIT-FLAGS \ set array to 1 R6 FLAGS LI, \ base of FLAGS array R0 SIZE LI, \ index FLAGS array R5 0101 LI, \ To initialize array BEGIN, R5 R6 *+ MOV, \ write ones to FLAGS R0 DECT, NC UNTIL, RT, DECIMAL WRKSP2 PROG: DO-PRIME ( 0 -- n) \ Called with '0' on stack to provide a place for return value INIT-FLAGS @@ BL, \ inits R7 CLR, \ 0 constant R6 FLAGS LI, \ array base address R8 SIZE LI, \ size R10 CLR, \ clear counter R0 CLR, \ clear loop index BEGIN, R6 *+ R7 CMPB, \ FLAGS I + C@ NE IF, R0 R1 MOV, \ I -> R1 R1 1 SLA, \ R1 2* R1 3 AI, \ R1 3+ R0 R2 MOV, \ I -> R2 ( R2 is K index) R1 R2 ADD, \ PRIME K +! BEGIN, R2 R8 CMP, \ K SIZE COMPARE LTE WHILE, R7 FLAGS R2 () MOVB, \ no,reset @FLAGS(R2) R1 R2 ADD, \ PRIME K +! REPEAT, R10 INC, \ increment count of primes ENDIF, R0 INC, \ next I R0 R8 CMP, \ I>SIZE? GTE UNTIL, \ no, next R10 [TOS] MOV, \ R10 -> Forth top of stack register, R4 RTWP, ;PROG : PRIMES ( -- ) PAGE ." 10 Iterations" 10 0 DO 0 DO-PRIME CR . ." primes" LOOP CR ." Done!" ; 3 Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted February 18 Share Posted February 18 "SIEVE in Forth Assembler based on code by @billsullivan atariage.com" Oops - I'm a different Bill. Just FYI. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 18 Author Share Posted February 18 3 hours ago, Reciprocating Bill said: "SIEVE in Forth Assembler based on code by @billsullivan atariage.com" Oops - I'm a different Bill. Just FYI. My humble apologies. I will fix it directly. Appropriate reciprocation shall be added. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 18 Author Share Posted February 18 @Reciprocating Bill the error has been corrected. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted February 19 Share Posted February 19 10 hours ago, Reciprocating Bill said: "SIEVE in Forth Assembler based on code by @billsullivan atariage.com" Oops - I'm a different Bill. Just FYI. But you also used to post as @FDOS, i.e., Bill R. Sullivan, correct? ...lee Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 21 Author Share Posted February 21 I am getting this machine Forth system called ASMFORTH II closer to reality. Here it is compiling and running the SIEVE https://youtu.be/n_POsgZ5yVE 1 Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted February 21 Share Posted February 21 On 2/18/2023 at 9:01 PM, Lee Stewart said: But you also used to post as @FDOS, i.e., Bill R. Sullivan, correct? ...lee No, always and only as Reciprocating Bill. I'm not Bill R. Sullivan. 2 1 Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted February 22 Share Posted February 22 10 hours ago, Reciprocating Bill said: No, always and only as Reciprocating Bill. I'm not Bill R. Sullivan. I see that Bill Sullivan used to sign off as "Retro Bill." Plenty similar. I was not yet even lurking here when he was posting. "Reciprocating Bill" has a very obscure origin in vintage HiFi, specifically, the University Sound "Reciprocating Flare" design for midrange and high frequency horns, which originated in the early 1950's or so. The TI has not been my only retro interest. 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted May 15 Author Share Posted May 15 On 4/24/2022 at 2:40 PM, lucien2 said: For this benchmark program, we could also keep the default character set. That could improve it by a few seconds, but I was expecting something 1.5x slower than Forth (~150-200 seconds). I missed this comment last year. GPL is a byte coded system so it will always run slower as you suspected, but I don't think the GPL interpreter is as stripped down as the Forth equivalent. Forth's running interpreter as you know is 3 instructions on TI-99 for indirect threading and 2 instructions for direct threading. I have it on my project list to write a byte-coded Forth for TI-99 to see what happens and I suspect your 1.5 factor is going to be about right. Although the TI-99's indirect addressing instructions might make the difference smaller. Does anyone have the GPL runtime interpreter code or know how many instructions are executed to interpret a byte code? Based on the benchmark it appears to be between 6 to 10 instructions. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted May 15 Share Posted May 15 30 minutes ago, TheBF said: Does anyone have the GPL runtime interpreter code or know how many instructions are executed to interpret a byte code? Based on the benchmark it appears to be between 6 to 10 instructions. The GPL Interpreter is most of the first third or so of the console ROM (see the listing of ROM-4A.lst at TI-99/4A Operating System). It starts at line 261 in the listing. You will notice the familiar NEXT label at listing line 282. ...lee 1 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted May 15 Author Share Posted May 15 8 hours ago, Lee Stewart said: The GPL Interpreter is most of the first third or so of the console ROM (see the listing of ROM-4A.lst at TI-99/4A Operating System). It starts at line 261 in the listing. You will notice the familiar NEXT label at listing line 282. ...lee Thanks Lee, From looking at NEXT in GPL it's no surprise that it runs slower than address threaded Forth. I don't pretend to understand all the details and I can see that not all of this code runs for every GPL instruction, but it's still a lot more than 3 instructions. The counter to this on the Forth side, is that some of the GPL NEXT seems to be doing things that are distributed in other places in Forth. Variables, branching and code to enter a routine exist separate from the NEXT interpreter. So that's where Forth spends extra time that is not seen if we just look at Forth's NEXT code. I think that's as deep as I need to go. 241 0070 0300 NEXT LIMI 2 ALLOW INT'S BETWEEN GPL INSTN'S 241 0072 0002 242 0000 0072 HX0002 EQU $-2 243 0074 0300 C074 LIMI 0 243 0076 0000 244 0078 D25D MOVB *R13,R9 LOAD INSTN FROM GAME ROM. 245 007A 1105 JLT ABOPS JMP IF MS BIT SET 246 007C D109 MOVB R9,R4 MOVE INSTN TO WORK REG'R 247 007E 09C4 SRL R4,12 LEAVE TOP 3 BITS *2 248 0080 C164 MOV @ITAB(R4),R5 GET BRANCH ADDRESS 248 0082 0C36 249 0084 0455 B *R5 B @MICSLN, MOVDAT, BRESET, BSET 250 *---------INSTRUCTIONS WITH A & B OPERANDS--------- 251 0086 04C4 ABOPS CLR R4 CLEAR VDP RAM FLAGS 252 0088 C149 MOV R9,R5 LOAD R5 WITH DOUBLE FLAG 253 008A 0245 ANDI R5,>0100 IF 0, BYTE OPND, IF 1 = WORD OPND 253 008C 0100 254 008E 06A0 BL @GETMAD GET FIRST OPERAND 254 0090 077A 255 0092 06C4 SWPB R4 256 0094 C0C1 MOV R1,R3 SAVE VARIABLE ADDRESS 257 0096 C080 MOV R0,R2 SAVE VAR. VALUE (OPERAND) 258 0098 0289 CI R9,>A000 SINGLE OPND? (8X OR 9X = SINGLE) 258 009A A000 259 009C 1A09 JL AOPS YES 260 009E 2260 COC @C030,R9 IMMEDIATE OR VAR? (C030 =>0200) 260 00A0 0030 261 00A2 160C JNE ABOPA VARIABLE 262 00A4 C04D MOV R13,R1 GET IMMEDIATE VALUE 263 * (2ND OPERAND IS IMMEDIATE) 264 00A6 D011 MOVB *R1,R0 GET FIRST BYTE 265 00A8 0601 DEC R1 MODIFY FOR COMMON ROUTINE 266 00AA 06A0 BL @MADC2 GO TO COMMON ROUTINE (PUT 2ND IMM. 266 00AC 07AA 267 * OPND BYTE IN R0 LSB, IF WORD. 268 * OTHERWISE SIGN EXTEND BYTE TO LSB) 269 00AE 1008 JMP BOPS 270 00B0 C209 AOPS MOV R9,R8 BRANCH THROUGH BRANCH TABLE 271 00B2 0988 SRL R8,8 272 00B4 0700 SETO R0 273 00B6 C228 MOV @ATAB(R8),R8 273 00B8 0BFE 274 00BA 0458 B *R8 275 00BC 06A0 ABOPA BL @GETMAD 275 00BE 077A 276 00C0 C209 BOPS MOV R9,R8 BRANCH THROUGH BRANCH TABLE 277 00C2 0998 SRL R8,9 278 00C4 C228 MOV @BTAB(R8),R8 LOAD BRANCH TABLE 278 00C6 0C4E 279 00C8 8002 C R2,R0 COMPARE FOR IF PRIMITIVES 280 00CA 0458 B *R8 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted May 16 Author Share Posted May 16 I posted this over in the Camel99 thread but here is ASMForth code for this sieve thread. ASMForth was my attempt to try and blend Assembler and Forth. I knew that using only stacks for data, the 9900 would never compete with C or Assembler so this was my rebuttal. (A smarter man would have made an optimizing Forth compiler) You can read about it here: GitHub - bfox9900/ASMFORTH: Experimental Assembler using Forth like syntax It works and it's fast but nobody else will ever use it. I wanted to see if it was possible. (TOS in the code is just R4 aliased) Here is what the sieve looks like is ASMForth. It runs in ~10 seconds with WKSP at >8300 \ SIEVE in ASMFORTH for Camel99 Forth Mar 1 2023 Brian Fox \ based on code by @Reciprocating Bill atariage.com \ Original notes by BIll. \ * SIEVE OF ERATOSTHENES ------------------------------------------ \ * WSM 4/2022 \ * TMS9900 assembly adapted from BYTE magazine 9/81 and 1/83 issues \ * 10 iterations 6.4 seconds on 16-bit console \ * ~10 seconds on stock console \ Removed size in R8. Used immediate compare HOST DECIMAL 8190 CONSTANT SIZE HEX 2000 CONSTANT FLAGS \ array in Low RAM ASMFORTH : FILLW ( addr size char --) \ nestable sub-routine TOS R0 ! \ char -> R0 TOS POP \ size in TOS for FOR to use R1 POP \ Memory location in R1 TOS FOR \ FOR takes a register argument R0 R1 @+ ! \ write ones to FLAGS NEXT2 \ *NEW* counts down by 2 ; : PRIME-MOVER FLAGS # SIZE # 0101 # FILLW \ inits R0 OFF \ clear loop index R3 OFF \ 0 constant FLAGS R5 #! \ array base address 0 # \ counter on top of Forth stack SIZE #FOR \ #FOR takes a literal number argument R5 @+ R3 CMPB \ FLAGS C@+ byte-compared to R3 (ie: 0) <> IF \ not equal to zero ? R0 R1 ! \ I -> R1 R1 2* R1 3 #+ \ R1 2* 3+ R0 R2 ! \ I -> R2 ( R2 is K index) R1 R2 + \ PRIME K +! BEGIN R2 SIZE #CMP \ K SIZE compare < WHILE R3 FLAGS (R2) C! \ reset byte FLAGS(R2) R1 R2 + \ PRIME K +! REPEAT TOS 1+ \ increment count of primes THEN R0 1+ \ bump index register NEXT ; HEX CODE DO-PRIME ( -- n) \ code words can be called from Forth PRIME-MOVER \ ASMForth colon words are called from CODE words ;CODE ONLY FORTH ALSO MFORTH ALSO FORTH DEFINITIONS DECIMAL : PRIMES ( -- ) PAGE ." 10 Iterations" 10 0 DO DO-PRIME CR . ." primes" LOOP CR ." Done!" ; 3 Quote Link to comment Share on other sites More sharing options...
