zoggins Posted May 7, 2022 Share Posted May 7, 2022 I have a heavy sixer that has one paddle input not working. I have tried multiple paddles and all the paddles work in controller port 2, controller port 1 has the issue. I have tested the circuit for continuity and checked the resistor and cap values which all check out. I even swapped the TIA which didn't change anything. The circuit doesn't seem complex, so I am wracking my brain trying to think of what to check next. Any ideas would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted May 11, 2022 Share Posted May 11, 2022 The only other component would likely be the RIOT IC at that point. I just finished up working on a 7800 that had a similar issue. In the case of the 7800, as soon as you plugged in a set of paddle controllers into port 1, both fire buttons would register as always active and the paddles them selves would go full right and never respond. 2nd controller port, the paddles worked properly. In the case of that 7800 it is actually due to a faulty TIA as when I swapped it out with a working one from a heavy sixer in fact, the paddles would work normally in port 1. But my client elected for me to just install the TIA into a socket so they could replace it with a different TIA on their own in the future. Quote Link to comment Share on other sites More sharing options...
zoggins Posted May 11, 2022 Author Share Posted May 11, 2022 Yeah I swapped the 6532 with a known good one too. Still no activity on the one side of the paddle plugged into port 1. This may just fall into the "known issues" category for the console because I am out of ideas. Quote Link to comment Share on other sites More sharing options...
