+Karl G Posted May 8, 2022 Share Posted May 8, 2022 This is spawned from a discussion in the batari Basic forum about how to count the number of bits that differ between two bytes. The first part is easy: do an EOR of the two bytes to get a result containing 1s where the bits differed between the two bytes. So from there the question becomes how to count the number of 1s in a byte. I came up with 3 different possibilities. 1) Iterate. Check the rightmost bit, increment a counter if it is 1, then lsr. Repeat until number is zero 2) Big table: Have a 256-byte lookup table returning the number of 1 bits for all 256 values of the byte being checked. 3) Hybrid: Load the byte to be checked, and #$0F, and check a 16-byte lookup table to see how many 1s are in that nybble. Load the byte again, do lsr 4 times, and check the lookup table again. Add the two results. I just wanted to see if anyone had a more clever way to get the number of 1 bits in a byte. 2 Quote Link to comment Share on other sites More sharing options...
JetSetIlly Posted May 9, 2022 Share Posted May 9, 2022 Simplest method other than (1) I know which is easy to remember. First published in 1960 https://dl.acm.org/doi/abs/10.1145/367415.367425 bitCount = 0 while val != 0 val &= val - 1 bitCount++ } Nice thing about this is that if there is only one bit set then the loop iterates once. If two bits are set then it iterates twice, etc. 3 1 Quote Link to comment Share on other sites More sharing options...
+Karl G Posted May 9, 2022 Author Share Posted May 9, 2022 (edited) 11 hours ago, JetSetIlly said: Simplest method other than (1) I know which is easy to remember. First published in 1960 Excellent! I love that it is a 62 year old solution as well. Here's my translation into 6502 assembly. Byte to be checked is temp1, and X will contain number of bits. No doubt others could optimize further: ldx #0 sec CountBitsLoop lda temp1 beq ____done_count_bits inx sbc #1 and temp1 sta temp1 jmp CountBitsLoop Edited May 9, 2022 by Karl G 3 Quote Link to comment Share on other sites More sharing options...
Danjovic Posted May 9, 2022 Share Posted May 9, 2022 (edited) Full solution: lda byte1 eor byte2 sta temp lda #0 ldy #8 loop: rol temp adc #0 ; a = a + 0 + carry dey bne loop at the end a holds bit count. Edited May 9, 2022 by Danjovic 2 Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted May 9, 2022 Share Posted May 9, 2022 ? No 6502 ASM solution on rosettacode: https://rosettacode.org/wiki/Population_count Quote Link to comment Share on other sites More sharing options...
orange808 Posted May 9, 2022 Share Posted May 9, 2022 Could we abuse ASR for this? https://atariage.com/forums/topic/124320-illegal-opcodes/ Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted May 10, 2022 Share Posted May 10, 2022 On 5/8/2022 at 4:45 PM, Karl G said: This is spawned from a discussion in the batari Basic forum about how to count the number of bits that differ between two bytes. The first part is easy: do an EOR of the two bytes to get a result containing 1s where the bits differed between the two bytes. So from there the question becomes how to count the number of 1s in a byte. I came up with 3 different possibilities. 1) Iterate. Check the rightmost bit, increment a counter if it is 1, then lsr. Repeat until number is zero 2) Big table: Have a 256-byte lookup table returning the number of 1 bits for all 256 values of the byte being checked. 3) Hybrid: Load the byte to be checked, and #$0F, and check a 16-byte lookup table to see how many 1s are in that nybble. Load the byte again, do lsr 4 times, and check the lookup table again. Add the two results. I just wanted to see if anyone had a more clever way to get the number of 1 bits in a byte. No, I think that is pretty much it unless there is some weird not obvious method. Here's what I would do: ldx #$FF ; use TSX if SP=$FF to save a byte .doInx: inx .doShift: lsr bcs .doInx bne .doShift ; will exit early if no more bits are set ;X = number of bits, A = 0, carry is clear You might want to choose ASL instead of LSR depending on what it is known about the data beforehand. I.e. if bit 0 is always clear but bit 7 is unknown then ASL makes more sense to use. 3 Quote Link to comment Share on other sites More sharing options...
stepho Posted May 10, 2022 Share Posted May 10, 2022 The algorithm by JetSetIlly is known as Brian Kernighan's method, although it didn't originate with him - he just popularised it. There is one remaining method. Go to this webpage and then scroll down to the parallel method. https://graphics.stanford.edu/~seander/bithacks.html#CountBitsSetNaive https://graphics.stanford.edu/~seander/bithacks.html#CountBitsSetParallel Use the best method for 32-bits - you will have to cut it down to 8 bits (do the 0x55, 0x33, 0x0f steps as 8-bit but skip the 0x01 and final >>24 steps). It has a lot of shifts and adds, so not sure if it will be quicker than the methods above. That web page is also a great grab bag of tricks - although they are mostly optimisations for bigger CPU's than ours. Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted May 10, 2022 Share Posted May 10, 2022 12 hours ago, Karl G said: Excellent! I love that it is a 62 year old solution as well. Here's my translation into 6502 assembly. Byte to be checked is temp1, and X will contain number of bits. No doubt others could optimize further: I count that at about 18 cycles/bit. This one is about 13 cycles/bit... still expensive. I'd use a 16-byte table lookup myself. Would be 6 cycles with 0 bits set, and 115 cycles with 8 bits set. 16 bytes of ROM. ; assume A = value to count bits for and it's just been loaded beq doneCount ldx #0 sec count inx sta temp sbc #1 and temp bne count txa doneCount ; a = # bits rts table lookup... untested. Looks like 38 cycles always... that's averaging 9 cycles/bit I think. forgot the cycle count for abs,x and abs,y so I used 5. 36 bytes of ROM. countBits ; A = byte to count bits of sta temp and #15 tax lda temp lsr lsr lsr lsr tay clc lda t16,x adc t16,y ; #bits in A rts t16 dc 0 ; 0000 dc 1 ; 0001 dc 1 ; 0010 dc 2 ; 0011 dc 1 ; 0100 dc 2 ; 0101 dc 2 ; 0110 dc 3 ; 0111 dc 1 ; 1000 dc 2 ; 1001 dc 2 ; 1010 dc 3 ; 1011 dc 2 ; 1100 dc 3 ; 1101 dc 3 ; 1110 dc 4 ; 1111 1 Quote Link to comment Share on other sites More sharing options...
