apersson850 Posted May 9, 2022 Share Posted May 9, 2022 In another thread, @retroclouds asked for a comparison between the TMS 9900, with its microcomputer origin, and the superminicomputer Digital VAX 11/780. Here's an attempt. As always, more things could have been included, but I hope I touched the more interesting parts. TMS 9900 versus something big.pdf 4 2 Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted May 9, 2022 Share Posted May 9, 2022 Another interesting comparison is between the 9900 and the LS-11, a four-chip implementation of the PDP-11. In the Book "16-bit Microprocessors" (Titus, Titus, Baldwin, Hubin and Scanlon, 1981, Howard Sams) several small assembler benchmarks were used for performance comparisons. Here are the numbers for the 9900 (numbers I obtained long ago utilizing pad ram on a 99/4a), an 8086 at 4Mhz, and an LS-11. The benchmarks were: - A bubble sort of 600 numbers arranged in the worst-case high to low order, - A square root routine, tested with three values, - a string search - finding a value in a lookup table - a memory transfer Bubble sort (seconds) 9900 15.3" 8086 13.9" LS-11 10.5" Square root of 10,000 (microseconds) 9900 490 8086 637 LS-11 628 Square root of 16,384 9900 370 8086 480 LS-11 458 Square root of 58,081 9900 370 8086 480 LS-11 457 String Search (microseconds) 9900 1075 8086 767 LS-11 979 Sine Lookup Table (from four quadrants of table, microseconds) 9900 84, 86, 77, 79 8086 36 to 43 microseconds LS-11 64, 74, 75, 85 Transfer 256 words in memory (microseconds) 9900 4308 LS-11 3265 (8086 not reported) Of course, later 16/32 bit processors just coming online at the time (e.g. the 68000, etc.), also discussed int he book, blew the above numbers away. 4 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted May 9, 2022 Author Share Posted May 9, 2022 The VAX 11/780 CPU, KA 780 was implemented mainly by using standard Schottky TTL circuits. Smaller versions of the computer had different implementations. The 11/730 implemented the processor with the popular AMD 2900 bit-slice chips. It had less performance, but also less cost. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted May 9, 2022 Share Posted May 9, 2022 2 hours ago, Reciprocating Bill said: Another interesting comparison is between the 9900 and the LS-11, a four-chip implementation of the PDP-11. In the Book "16-bit Microprocessors" (Titus, Titus, Baldwin, Hubin and Scanlon, 1981, Howard Sams) several small assembler benchmarks were used for performance comparisons. Here are the numbers for the 9900 (numbers I obtained long ago utilizing pad ram on a 99/4a), an 8086 at 4Mhz, and an LS-11. The benchmarks were: - A bubble sort of 600 numbers arranged in the worst-case high to low order, - A square root routine, tested with three values, - a string search - finding a value in a lookup table - a memory transfer Bubble sort (seconds) 9900 15.3" 8086 13.9" LS-11 10.5" Square root of 10,000 (microseconds) 9900 490 8086 637 LS-11 628 Square root of 16,384 9900 370 8086 480 LS-11 458 Square root of 58,081 9900 370 8086 480 LS-11 457 String Search (microseconds) 9900 1075 8086 767 LS-11 979 Sine Lookup Table (from four quadrants of table, microseconds) 9900 84, 86, 77, 79 8086 36 to 43 microseconds LS-11 64, 74, 75, 85 Transfer 256 words in memory (microseconds) 9900 4308 LS-11 3265 (8086 not reported) Of course, later 16/32 bit processors just coming online at the time (e.g. the 68000, etc.), also discussed int he book, blew the above numbers away. That looks pretty good for our old friend. I bet 9900 would beat the others if they measured context switching time. I have had 40 stack manipulation dummy tasks running simultaneously on my Forth system and the interpreter still responds reasonably well. 5 Quote Link to comment Share on other sites More sharing options...
