globeron Posted May 9, 2022 Share Posted May 9, 2022 Batocera is an emulation system very easy to run from an USB stick on a Laptop PC for example (I used the USB on different laptop PC's and works excellent) (example to setup explained by Wagner's Tech Talk - https://www.youtube.com/watch?v=F1GshnAYrII) The zip file is already provided in v33 of Batocera and you only have to add the .rpk format as it is based on MAME/MESS (list of cartridges) https://ftp.whtech.com/Cartridges/MAME/rpk/ Setup instructions - https://wiki.batocera.org/systems:ti99 3 1 Quote Link to comment Share on other sites More sharing options...
globeron Posted May 9, 2022 Author Share Posted May 9, 2022 Basically I use Batocera for playing games, but the Speech Synthesizer is not working in the emulation mode it is possible to press TAB to see all the MESS settings. Question to @mizapf to get the Speech to work is that very simple to do by using the .zip files (ti99_speech.zip)? or is something needed in the Batocero system to get Speech to work? ti99_speech8.zipti99_speech.zipti99_rs232.zip 2 Quote Link to comment Share on other sites More sharing options...
globeron Posted May 9, 2022 Author Share Posted May 9, 2022 Okay I got Speech working as follows: 1. install the ti99_speech.zip file in the /bios folder 2. start a program like Alpiner 3. press TAB 4. select Slot Devices 5. select ioport "peb" 6. select ioport:peb:slot3 "speech" 7. select "Reset Machine" (only after getting back to Batocera and starting the game, the settings are not saved, so I guess there is somewhere a mame startup command where these parameters can be set. something like " mame64 ti99_4a -ioport peb -ioport:peb:slot3 speech 2 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted May 9, 2022 Share Posted May 9, 2022 First time that I heard about Batocera, so I can't really give you a lot of help here. I don't know what MAME version it is based on. By the way, the claim that the software list files don't work is wrong; the ZIP files are those files, and they are working perfectly. You should not unzip the ZIP files, though. 1 Quote Link to comment Share on other sites More sharing options...
globeron Posted May 29, 2022 Author Share Posted May 29, 2022 Speech and 32K is working now (and configurable to turn it on/off) https://batocera.org/changelog Batocera 34 - 2022/02/06 change: MAME/MESS: speech module and 32k RAM option for TI-99 4 Quote Link to comment Share on other sites More sharing options...
globeron Posted June 17, 2022 Author Share Posted June 17, 2022 Sample Batocera setup (TI-99/4A) based in MAME using .rpk format for roms. 3 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted June 17, 2022 Share Posted June 17, 2022 Watching it on a PC, this feels like peeking through a gap of a door that is slightly ajar. 2 Quote Link to comment Share on other sites More sharing options...
globeron Posted June 23, 2022 Author Share Posted June 23, 2022 FYI - Batocera (based on MAME and .rpk format) (wait until the .zip file is available on ftp.whtech.com, then you easily can download and install it in Batocera). This is the list of games (289) + images + videos including some multi-game modules in .rpk format. Batocera-ti99-rpk-image-video.xlsx 2 Quote Link to comment Share on other sites More sharing options...
globeron Posted June 23, 2022 Author Share Posted June 23, 2022 (Batocera version 34 for x86 x64 bit - https://updates.batocera.org/x86_64/stable/last/batocera-x86_64-34-20220523.img.gz) Here are some notes to myself which tools I used to make the package. (inside the .rpk is a file layout.xml, sometimes 378, 379i, or gromemu need to be used) https://www.ninerpedia.org/wiki/MESS_cartridge_handling (1x laptop runs Batocera is connected to the Wi-Fi network) (other laptop uses ESGME to open file via Wi-Fi \\192.168.1.191\gamelist.xml directly in Batocera) Windows explorer //192.168.1/191 Default login: batocera / linux EmulationStation Gamelist Metadata Editor · https://www.jeffersoftware.com/esgme/index.php · To edit in /roms/ti99/gamelist.xml o Use SAVE o Edit the names of games o Edit the link to images (preview) o Edit the link to video files (preview) Bulk Rename Utility (to rename files, like filaabc_x264.mp4 to file.mp4 (play around with the filters) https://www.bulkrenameutility.co.uk/ https://js99er.net/#/ Js99er.net to make screenshots in .png format Js99er.net to make video snapshots in webpm Convert Also use Screenhunter - https://www.wisdom-soft.com/index.htm To do image snaphots or video recording, select an area to capture (e.g. from Classic99) Use Any Video Converter to convert from .webm format to .mp4 format https://www.any-video-converter.com/download-avc-free.html · Output select Customized MP4 Movie (*.mp4) format · Change video size 320 x 240 · Drag and drop all .webm and .mp4 files to Any Video Converter · And convert Copy the .png files to Batocera //192.168.1.191/share/roms/ti99/images Copy the .mp4 files to Batocera //192.168.1.191/share/roms/ti99/videos once the .zip file is available, just copy everything to .../roms/ti99 (then in Batocera press "spacebar" for main menu, select Game Settings and update gamelists) then back and the TI99 should be available now with 289 games, image and video previews. ( 3 Quote Link to comment Share on other sites More sharing options...
globeron Posted June 23, 2022 Author Share Posted June 23, 2022 (list of all games: https://ftp.whtech.com/Cartridges/Batocera/Batocera-ti99-rpk-image-video.xlsx) Steps: 1. install Batocera image on a USB, Raspberry PI, or any other device USB for PC (to boot from USB) - Batocera version 34 for x86 x64 bit - https://updates.batocera.org/x86_64/stable/last/batocera-x86_64-34-20220523.img.gz 2. Download the .zip and unzip (e.g. using WinRar) https://ftp.whtech.com/Cartridges/Batocera/Batocera-ti99.zip 3. Copy all files in /share/roms/ti99 (it copies .rpk format (game modules), images and videos preview snaps. 3 Quote Link to comment Share on other sites More sharing options...
globeron Posted June 24, 2022 Author Share Posted June 24, 2022 Batocera with TI-99/4A emulation (based on MAME, files are .rpk format). 2 Quote Link to comment Share on other sites More sharing options...
globeron Posted June 25, 2022 Author Share Posted June 25, 2022 These files need to be in the /share/bios directory ti99_4a.zip ti99_speech.zip 2 Quote Link to comment Share on other sites More sharing options...
globeron Posted June 25, 2022 Author Share Posted June 25, 2022 (edited) no delete option to remove posts Edited June 25, 2022 by globeron deleted redundant post 1 Quote Link to comment Share on other sites More sharing options...
globeron Posted June 26, 2022 Author Share Posted June 26, 2022 Additional useful tools to do mass renaming and organising gamelist.xml with images and videos in Batocera * Explanation https://www.digimoot.com/retropie-generate-xml-mass-rename-media-roms/ * Fat Match file renamer (to map roms with images or videos), run the tool 2x (for images and videos) https://emumovies.com/files/file/227-fatmatch-file-renamer/ * Gengal.zip - Gengal (very difficult to find it online) to generate the gamelist.xml with images and videos * Use ESGME to load the gamelist.xml to validate. If it gives errors then probably filenames have the "&" (ampersand) character in the filename (change it to "+" (plus)), * Use the Bulk Rename Utility to rename the files (include the subdirectories !) EmulationStation Gamelist Metadata Editor · https://www.jeffersoftware.com/esgme/index.php · To edit in /roms/ti99/gamelist.xml o Use SAVE o Edit the names of games o Edit the link to images (preview) o Edit the link to video files (preview) Bulk Rename Utility (to rename files, like filaabc_x264.mp4 to file.mp4 (play around with the filters) https://www.bulkrenameutility.co.uk/ 3 Quote Link to comment Share on other sites More sharing options...
globeron Posted July 18, 2022 Author Share Posted July 18, 2022 (edited) Additiional rpk format for MAME / Batocera systems Batocera-ti99-add.zip Edited July 18, 2022 by globeron 2 Quote Link to comment Share on other sites More sharing options...
globeron Posted December 3, 2022 Author Share Posted December 3, 2022 TI99 - Batocera roms - Version 2 * 309 .rpk format modules + images & video snaps. * Upload these files in the roms directory (and in the bios for first time users) https://www.whtech.com/ftp/Cartridges/Batocera/Batocera-ti99v2.zip 2 Quote Link to comment Share on other sites More sharing options...
globeron Posted December 6, 2022 Author Share Posted December 6, 2022 Addendum v2: * Blockbuster * Tetris (2 player version) * gamelist.xml .csv list with a complete list of all modules in the v2 package Batocera-ti99v2-addendum.zip TI99-v2-and-addendum-gamelist.csv 1 Quote Link to comment Share on other sites More sharing options...
globeron Posted January 8 Author Share Posted January 8 (edited) Today I got Batocera working in a (Oracle) Virtual Box (VM) environment (not booting from USB). (as with VMware Player I did not had much success to boot from an USB image and to install VMWare tools) * I still suggest to boot Batocera from a USB stick on a PC as it works very well (it works on all x64 PCs I have been testing so far and is perfect, for some modern PC, in the BIOS you need to turn on Legacy support to boot, that's a bit inconvenient). * Note: in a VM environment Batocera performance itself has sometimes audio distortions, but sometimes it is okay (see Batocera audio settings), most systems (MAME, MSX, Commodore64, NES, TI-99/4A) seems to work too fast and for TI-99 somehow the screensize is smaller than other systems. Have not had time to figure out if it is a Virtual Box, or Batocera or MAME setting. * the reason for the VM is that if I do not have my USB with me (or other laptop), I still can do some work on the Batocera system * Once installed. (right click on the icon) and run as "administrator" (I am using a Lenovo to run Virtual Box on Windows 11 64-bit) 1.Download the latest Batocera x86_64 image. 2. Install Oracle's VirtualBox. (Virtual Box 7.x) 3. VirtualBox 7.0.4 Oracle VM VirtualBox Extension Pack All supported platforms Install the VirtualBox #.#.# Oracle VM VirtualBox Extension Pack too. Important is to select "Linux" (and not Windows as it will hang the system) For the rest follow these instructions (also enable 3D acceleration !) https://wiki.batocera.org/run_batocera_in_vm Note" TI-screen is a bit small and speed is too fast. Edited January 8 by globeron 2 Quote Link to comment Share on other sites More sharing options...
globeron Posted January 8 Author Share Posted January 8 On 12/6/2022 at 11:37 PM, globeron said: Addendum v2: * Blockbuster * Tetris (2 player version) * gamelist.xml .csv list with a complete list of all modules in the v2 package Batocera-ti99v2-addendum.zip 655.35 kB · 5 downloads TI99-v2-and-addendum-gamelist.csv 90.5 kB · 5 downloads Addendum for Batocera -- spac-man Batocera-spac-man.zip 1 Quote Link to comment Share on other sites More sharing options...
