Selecting a bit?
Trip2018
So I was wondering if there is a simple way to read and select a bit with a variable.
Like a possible implementation of a{6} = b{x}
I know course it throws an error for that specifically, but are there any alternatives? I'm trying to setup a 4 way platformer map where the bits are read across the x axis.
here's one way
setbyte is the kernel table for selecting bits (for eg setting playfield pixels)
the exact form of setbyte depends on the kernel but you could do your own table if neccesary
  if setbyte[x] & b then a{6} = 1 else a{6} = 0
Edited by bogax
6 hours ago, Trip2018 said:
Oh, that was a lot simpler than I was anticipating! Does the setbyte table loop once the variable is over 7 or would I need to reset the variable before I read? Very much appreciated, thanks!
the setbyte table is for a row of playfield pixels
some bytes in the playfield are reversed but which ones depends on kernel/kernel options
you'd have to limit x
2 hours ago, KevKelley said:
So could something like this also be used to count the bits turned on or off on the screen instead of selecting, like
  if setbyte[x] & b then c=c+1
yes you could do that if eg you're going to access bits randomly
if you're doing a byte at a time a table would be better
