Harry Potter Posted May 19, 2022 Share Posted May 19, 2022 Hi! I am working on a XZ0-variant compressor and need help. Right now, it is for the Commodore 64, but I plan to port it to the Atari 8-bit series soon. The problem I have is that it is too slow. I am using cc65 to create it. The LZ77 code in assembler follows: _ChkBlockA: ;inc $D020 ;clc ;adc #<_InBuffer ;sta ptr1 ;txa ;adc #>_InBuffer ;sta ptr1+1 ldy #1 ;iny @lp: lda (ptr1),y cmp (ptr2),y bne @exit iny cpy tmp1 bcc @lp @exit: ;cpy #2 ;bcs *+4 ;ldy #0 ;tya ;ldx #0 rts ;ptr2=absolute address of current input ;ptr3=InPos of call. ;ptr4=current pos. in InBuffer ;curl=earliest pos. of scan. ;tmp1=max. len. of block _GetLZ: ldy #0 sty _techLZ+2 sta ptr3 stx ptr3+1 ;sta ptr4 ;stx ptr4+1 ora ptr3+1 bne *+5 jmp @exit clc lda ptr3 adc #<_lzdict sta ptr2 sta ptr1 txa adc #>_lzdict sta ptr2+1 sta ptr1+1 @regstart: lda ptr3+1 cmp #$12 bcc @calcincl sbc #$12 sta curl+1 lda ptr3 sta curl jmp @endcalc ;bcs @endcalc @calcincl: ldy #0 sty curl sty curl+1 @endcalc: ;lda curl ;sta $400+16 ;lda curl+1 ;sta $400+17 lda _InEnd sec sbc _InPos sta regbank lda _InEnd+1 sbc _InPos+1 sta regbank+1 bne @maxlenw lda regbank cmp #128 bcc @maxlenx @maxlenw: lda #128 @maxlenx: ;sta $400+16 sta tmp1 cmp #2 bcc @exit lda curl clc adc #<_lzdict sta curl lda curl+1 adc #>_lzdict sta curl+1 ;lda ptr3 ;sta ptr4 ;lda ptr3+1 ;sta ptr4+1 ldy #0 lda (ptr1),y sta tmp4 ;iny ;lda (ptr1),y ;sta curread+1 @lp: ldy ptr1 bne *+4 dec ptr1+1 dec ptr1 ;ldy ptr4 ;bne *+4 ;dec ptr4+1 ;dec ptr4 ldy #0 lda tmp4 cmp (ptr1),y bne @lp2 ;iny ;lda curread+1 ;cmp (ptr1),y ;bne @lp2 ;lda ptr4 ;ldx ptr4+1 jsr _ChkBlockA ;cpy #0 ;beq @lp2 ;bcc @lp2 cpy _techLZ+2 beq @lp2 bcc @lp2 sty _techLZ+2 ;sty $400+8 ;lda ptr4 lda ptr1 sta _techLZ ;lda ptr4+1 lda ptr1+1 sta _techLZ+1 @lp2: lda curl+1 cmp ptr1+1 bcc @lp lda curl cmp ptr1 bcc @lp @exit: ;inc $D021 ldx #0 lda _techLZ+2 cmp #2 bcs *+3 ;lda #0 txa ;ldx #0 rts and the code to write to the output: static void writebyte (void) { //cbm_write (0, &wr, 1); //wr>>=8; // #ifdef __C128__ // bank1_writebyte (&OutBuffer[OutPos], wr); // #else // hidewriteb(&OutBuffer[OutPos], wr); // #endif OutBuffer[OutPos]=wr; wr=0; //OutBit-=8; ++OutPos; } void writeoutlast (void){ if ((signed char)OutBit<8) { wr<<=OutBit-1; writebyte (); } } void __fastcall__ writeoutf (unsigned val, unsigned char bitlen) { while (bitlen) { --OutBit; //wr=(wr<<1)|((val>>(OutBit))&1); //wr|=(((val>>(bitlen-1))&1)<<OutBit); wr=(wr<<1)|((val>>(bitlen-1))&1); //val>>=1; if (!OutBit) { writebyte (); OutBit=8; } --bitlen; } } BTW, if you want more informartion, just ask, as this code is to be open-source. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted May 19, 2022 Share Posted May 19, 2022 Maybe some comments to help identify what your code blocks are doing/trying to achieve, also leaving lots of commented out code just confuses things. It's good practice even if your only writing code for yourself is to add comments as you go, that way even if you have to revisit code many moons later it will help you identify what your code is doing. 1 Quote Link to comment Share on other sites More sharing options...
Harry Potter Posted May 19, 2022 Author Share Posted May 19, 2022 You're right. I'm a sloppy coder. Quote Link to comment Share on other sites More sharing options...
Harry Potter Posted May 19, 2022 Author Share Posted May 19, 2022 I fixed the LZ77 code. It follows: ;Compare current block with LZ77 test block. Return in Y len. of match. _ChkBlockA: ldy #1 @lp: lda (ptr1),y cmp (ptr2),y bne @exit iny cpy tmp1 bcc @lp @exit: rts ;Find best LZ77 block. ; ;ptr2=absolute address of current input ;ptr3=InPos of call. ;ptr4=current pos. in InBuffer ;curl=earliest pos. of scan. ;tmp1=max. len. of block _GetLZ: ;Clear returned len. of LZ77 block. ldy #0 sty _techLZ+2 ;Save pos. in LZ77 input buffer sta ptr3 stx ptr3+1 ;If 0, exit. ora ptr3+1 bne *+5 jmp @exit ;Add the address of input buffer and store current input and test. clc lda ptr3 adc #<_lzdict sta ptr2 sta ptr1 txa adc #>_lzdict sta ptr2+1 sta ptr1+1 @regstart: ;Get offset of end of scan, which is the greater of $1300 before ;current and beginning of input. ;. lda ptr3+1 cmp #$13 bcc @calcincl sbc #$13 sta curl+1 lda ptr3 sta curl jmp @endcalc @calcincl: ldy #0 sty curl sty curl+1 @endcalc: ;Get max. len., which is the smaller of 128 bytes and the rest of input. lda _InEnd sec sbc _InPos sta regbank lda _InEnd+1 sbc _InPos+1 sta regbank+1 bne @maxlenw lda regbank cmp #128 bcc @maxlenx @maxlenw: lda #128 @maxlenx: sta tmp1 ;Exit if at end of input (<2 bytes left--uncompressable). cmp #2 bcc @exit ;Add input buffer address to offset found at @regstart. lda curl clc adc #<_lzdict sta curl lda curl+1 adc #>_lzdict sta curl+1 ;Save first input byte for later optimization. ldy #0 lda (ptr1),y sta tmp4 @lp: ;Decrease test address. ldy ptr1 bne *+4 dec ptr1+1 dec ptr1 ;Compare first byte. If !=, skip. lda tmp4 cmp (ptr1),y bne @lp2 ;Get LZ77 len. at current pos. jsr _ChkBlockA ;If >last best, cpy _techLZ+2 beq @lp2 bcc @lp2 sty _techLZ+2 ;store current loc. and len. lda ptr1 sta _techLZ lda ptr1+1 sta _techLZ+1 @lp2: ;Loop until end of scan. lda curl+1 cmp ptr1+1 bcc @lp lda curl cmp ptr1 bcc @lp @exit: ;Return best len. found--loc. and len. also in _techLZ. ldx #0 lda _techLZ+2 cmp #2 bcs *+3 txa rts Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 19, 2022 Share Posted May 19, 2022 This code is written to use pointer arithmetic, which is natural for C but translates poorly to 6502. The 6502 is much better with base+offset addressing, particularly with the (zp),Y addressing mode. But that is not your big problem. Your big problem is that this appears to be a brute force LZ search, which is going to be very slow. If I read this algorithm correctly, for each byte it is going to search all previous locations all the way up to $1300 behind the current point. This going to be quadratic time -- the search time for each input byte will be linear with the position of the byte, which means that the running time for the whole input will be proportional to the square of the input length. That will run slowly even on a modern CPU, much less a 6502. I'll bet that if you ran this under a profiler you'd find that _ChkBlockA lights up like a christmas tree compared to the main loop, due to the sheer number of matches being tried. Practical implementations of LZ matching use incremental search structures to speed up the search. Common ones include binary tree and hash table. The hash table is the easier approach and would be simpler to implement here; the popular zlib library has a description of the algorithm. Basically, you continuously hash groups of 2 or 3 bytes and insert them into a running hash table. This speeds up the search because you can then also hash at the current position and check only the positions in the matching hash chain, which is a fraction of the full set of possibilities. A limit is also usually imposed to cut off the search if there are too many candidates, to avoid worst-case performance. This can miss some matches in corner cases, but greatly improves the average time. It does also require some memory for the hash table, which will reduce the maximum length or at least window that the compressor can support. There is also a specific issue with quadratic time behavior involving cases of patterns that are actually really good for the compressor, but causes the compressor to do tons of redundant checks unless you specifically handle it. The simplest case is a plain run of A characters, where the compressor spends time finding a match for A, then AA, then AAA, etc. Testing the last character first sometimes helps with this. Charles Bloom, who worked on compression libraries at RAD Game Tools, refers to this as the "follows" problem in some of his articles. He also goes into a lot of details, such as running the LZ search backwards if you want optimal parsing, etc. But that's for after you get to reasonable performance. 2 Quote Link to comment Share on other sites More sharing options...
Harry Potter Posted May 19, 2022 Author Share Posted May 19, 2022 I thank you. I figured out how to download the text file--I had problems from the site before. I will look at it in more detail later. Quote Link to comment Share on other sites More sharing options...
