rcajun90 Posted May 19, 2022 Share Posted May 19, 2022 Just got it and I’m so excited! Eh is it supposed to update forever? 6 Quote Link to comment Share on other sites More sharing options...
THX-1138 Posted May 19, 2022 Share Posted May 19, 2022 Patience. There's probably a big cumulative update of the OS, Firmware etc. Mine has been boxed for a month or so because of a house move, it needed to do some big updates. It takes a while, just let it do what it needs to do, its worth the wait. :-) Quote Link to comment Share on other sites More sharing options...
joeatari1 Posted May 20, 2022 Share Posted May 20, 2022 Yeah man, give it time. It'll update, eventually. Tons of fun to be had but the updates can take a while. I am using my VCS primarily for streaming right now but it will eventually go into my home theater room and be used more for games. Quote Link to comment Share on other sites More sharing options...
rcajun90 Posted May 20, 2022 Author Share Posted May 20, 2022 Any good links to get batocera running on it? Not finding much on YouTube. Quote Link to comment Share on other sites More sharing options...
zzip Posted May 20, 2022 Share Posted May 20, 2022 10 hours ago, rcajun90 said: Any good links to get batocera running on it? Not finding much on YouTube. You can put it on a flash drive and it pretty much runs as intended on a VCS, once you disable secureboot. How to disable secureboot depends on if your unit accepts the well-known BIOS password or not. If it does, just turn off secureboot and you can boot anything you like. If it doesn't, then you need to downgrade the OS+bios, which forces it to set the password, then it will upgrade to the latest with the correct password. Instructions on how to do this can be found in this thread: post #18, steps 1-4 talk about flashing the bios and getting Batocera to work. Quote Link to comment Share on other sites More sharing options...
rcajun90 Posted May 21, 2022 Author Share Posted May 21, 2022 15 hours ago, zzip said: You can put it on a flash drive and it pretty much runs as intended on a VCS, once you disable secureboot. How to disable secureboot depends on if your unit accepts the well-known BIOS password or not. If it does, just turn off secureboot and you can boot anything you like. If it doesn't, then you need to downgrade the OS+bios, which forces it to set the password, then it will upgrade to the latest with the correct password. Instructions on how to do this can be found in this thread: post #18, steps 1-4 talk about flashing the bios and getting Batocera to work. Thank you. Can you just install it in windows? Very nervous about fooling with the bios. Quote Link to comment Share on other sites More sharing options...
zzip Posted May 23, 2022 Share Posted May 23, 2022 On 5/21/2022 at 2:17 AM, rcajun90 said: Thank you. Can you just install it in windows? Very nervous about fooling with the bios. The BIOS downgrade process? I think you just put it on a flash drive, then boot the VCS with that flashdrive plugged in and follow the directions. Quote Link to comment Share on other sites More sharing options...
rcajun90 Posted May 23, 2022 Author Share Posted May 23, 2022 43 minutes ago, zzip said: The BIOS downgrade process? I think you just put it on a flash drive, then boot the VCS with that flashdrive plugged in and follow the directions. Thank you. I was able to do it. Quote Link to comment Share on other sites More sharing options...
