rcajun90 Posted May 23, 2022 Share Posted May 23, 2022 (edited) Any way to fix it? I’ve tried everything I can think of. Edited May 30, 2022 by justclaws corrected title spelling typo, for search results Quote Link to comment Share on other sites More sharing options...
THX-1138 Posted May 23, 2022 Share Posted May 23, 2022 If it's a TV its because of that. The VCS is just a regular PC outputting 720p or 1080p over HDMI. Look at the TV picture settings, I had an older TV that did this, there was a PC mode that corrected it. Otherwise try another resolution on the VCS side. Quote Link to comment Share on other sites More sharing options...
andymanone Posted May 23, 2022 Share Posted May 23, 2022 (edited) I face the same issue with some Consoles in the past. You could try to go to the menu / configuration part of your TV set and go to the " Screen Format Option" there try to use "Auto-Scan" feature. After than the screen should be shown in a proper way. Cheers, andY Edited May 23, 2022 by andymanone Quote Link to comment Share on other sites More sharing options...
Mockduck Posted May 23, 2022 Share Posted May 23, 2022 I have this issue with one of my televisions as well, I can minimize it in the television settings but it just has too much "overscan". I think the actual issue is it is a cheap TV and they simply put the plastic over the edge of the screen, but hey. Unfortunately, unless the TV settings allow for the ability to adjust the edge of the screen you may be out of luck. Quote Link to comment Share on other sites More sharing options...
rcajun90 Posted May 23, 2022 Author Share Posted May 23, 2022 22 minutes ago, THX-1138 said: If it's a TV its because of that. The VCS is just a regular PC outputting 720p or 1080p over HDMI. Look at the TV picture settings, I had an older TV that did this, there was a PC mode that corrected it. Otherwise try another resolution on the VCS side. It worked fine until I started installing a bunch of apps. I want to say the game pass app messed it up. Quote Link to comment Share on other sites More sharing options...
rcajun90 Posted May 23, 2022 Author Share Posted May 23, 2022 1 hour ago, THX-1138 said: If it's a TV its because of that. The VCS is just a regular PC outputting 720p or 1080p over HDMI. Look at the TV picture settings, I had an older TV that did this, there was a PC mode that corrected it. Otherwise try another resolution on the VCS side. The VCS only let’s me choose one resolution. It also does it on Windows. Quote Link to comment Share on other sites More sharing options...
THX-1138 Posted May 23, 2022 Share Posted May 23, 2022 1 hour ago, rcajun90 said: It worked fine until I started installing a bunch of apps. I want to say the game pass app messed it up. No, that's not possible. Its the TV. Quote Link to comment Share on other sites More sharing options...
THX-1138 Posted May 23, 2022 Share Posted May 23, 2022 Just now, rcajun90 said: The VCS only let’s me choose one resolution. It also does it on Windows. Your display (TV) probably doesn't support other resolutions. Is it old? Is it an old HDMI cable? Quote Link to comment Share on other sites More sharing options...
rcajun90 Posted May 23, 2022 Author Share Posted May 23, 2022 Just now, THX-1138 said: No, that's not possible. Its the TV. Dang it. I don’t want to switch tvs just for the VCS. I will try it on another tv. Thank you for your help. Quote Link to comment Share on other sites More sharing options...
rcajun90 Posted May 23, 2022 Author Share Posted May 23, 2022 Different Tv, cable and resolution settings. Same problem. Quote Link to comment Share on other sites More sharing options...
+Neon Wraith Posted May 23, 2022 Share Posted May 23, 2022 I had this same issue when I first used the VCS on my Samsung 40" from 2015. I needed to adjust the screen size on my TV to, I think it was "native" resolution or something like that. Then the sizing was perfect. Also check if your TV has a "game mode". This will reduce lag and also move the borders in. Quote Link to comment Share on other sites More sharing options...
rcajun90 Posted May 23, 2022 Author Share Posted May 23, 2022 31 minutes ago, joeatari1 said: I had this same issue when I first used the VCS on my Samsung 40" from 2015. I needed to adjust the screen size on my TV to, I think it was "native" resolution or something like that. Then the sizing was perfect. Also check if your TV has a "game mode". This will reduce lag and also move the borders in. Thank you. The first tv is a Samsung. The second was A Dell monitor. I even did a reset to the VCS. I don’t see anything about native resolution. Very frustrating Quote Link to comment Share on other sites More sharing options...
Deteacher Posted May 23, 2022 Share Posted May 23, 2022 I had the same issue with my Element 55" TV. There are 3 display options on my VCS. When I picked the 2nd option (standard HD, I believe) I got the overscan issue. When I pick the 3rd (bottom) option, which I think is Ultra HD, it fits my TV perfectly. The downside to that is when I load any of the streaming services, everything is SUPER small. So, if I'm going to use a streaming service, I'll lower the resolution first. Quote Link to comment Share on other sites More sharing options...
rcajun90 Posted May 24, 2022 Author Share Posted May 24, 2022 50 minutes ago, Deteacher said: I had the same issue with my Element 55" TV. There are 3 display options on my VCS. When I picked the 2nd option (standard HD, I believe) I got the overscan issue. When I pick the 3rd (bottom) option, which I think is Ultra HD, it fits my TV perfectly. The downside to that is when I load any of the streaming services, everything is SUPER small. So, if I'm going to use a streaming service, I'll lower the resolution first. Yep it’s the tv. I had time to try the tv upstairs. It works fine. I wonder why I didn’t have that issue for days when I first got it home. Now I just need to break the tv in the game room.? 1 Quote Link to comment Share on other sites More sharing options...
E. King Posted May 30, 2022 Share Posted May 30, 2022 I have the same issue with a Sony Bravia TV. The VCS is my only console that does this on that TV so it is a VCS issue, not a TV issue. The VCS needs a screen resize option in the settings. 1 Quote Link to comment Share on other sites More sharing options...
OBLIVION23 Posted June 1, 2022 Share Posted June 1, 2022 I have experienced this on every single TV I've tried EXCEPT my girlfriend's newer Roku tv 1 Quote Link to comment Share on other sites More sharing options...
Mockduck Posted June 1, 2022 Share Posted June 1, 2022 I pretty much only have cheap TVs so I'm surprised I haven't run into this, but I haven't. Sounds like an OS-level overscan issue somehow. 1 Quote Link to comment Share on other sites More sharing options...
RollOut Posted July 3, 2022 Share Posted July 3, 2022 So I've only been playing my VCS for a few days, but it found I have a similar issue. The issue is inconsistent though. Sometime it boots up fine, sometimes the dashboard is cropped, and sometimes the dashboard is cropped and I loose sound. I haven't figured out what I do differently that gives me different outcomes. I tried turning off overscan on my tv, but nothing noticable happened. The fact that sometimes it's fine gives me hope that there is a solution, but I'm a bit confused so far. Quote Link to comment Share on other sites More sharing options...
OBLIVION23 Posted July 4, 2022 Share Posted July 4, 2022 (edited) I managed to figure out the fix for this on my TV is to change the display mode to Pan and Scan Edited July 4, 2022 by OBLIVION23 Typo 1 Quote Link to comment Share on other sites More sharing options...
RollOut Posted July 24, 2022 Share Posted July 24, 2022 So update on my situation, now that I've had a chance to observe it for a bit. If I haven't used the VCS for a few hours (like if it's the first time I've turned it on all day), the display and sound seem fine. If the console goes to sleep, or if I change input on the TV (but it doesn't go to sleep), and I use it again, the screen gets cut off (I think the resolution gets messed up), and I lose sound. If I turn the console off, and then back on within an hour or two of playing, I also end up with weird resolution (screen cut off) and no sound. This happens in VCS mode, and in Windows PC mode (I just installed windows, Thanks @Mockduck). For the record, I have an oldish (decade old?) 46" Dynex TV. I have a feeling the VCS just doesn't like playing with my oldish, and kind of cheap TV. has anyone experienced what I am describing, and is there a fix? I was considering using a converter to downgrade the HDMI signal from the VCS to composite video, but that is a complete shot in the dark. Quote Link to comment Share on other sites More sharing options...
+Neon Wraith Posted July 24, 2022 Share Posted July 24, 2022 I have experienced this. My solution was simple, set the TV to use native resolution (?). I have a 7 or 8 year old Samsung 40" and changing that setting fixed it. If your Dynex doesn't have a way to change the setting then you may want to invest in a newer one (they're only built to last 7-10 years anyway). Good luck. Quote Link to comment Share on other sites More sharing options...
SabertoothRetro Posted July 25, 2022 Share Posted July 25, 2022 I have a 2018 Samsung 4K that is my main gaming TV and have never had this issue. Last week, I moved my Collector's edition to our 55" Sony Bravia from 2012 or so and encountered the overscan. Solution for this set was to change the "Wide" setting to "Full Pixel" mode. 1 Quote Link to comment Share on other sites More sharing options...
tripled79 Posted August 1, 2022 Share Posted August 1, 2022 I get that occasionally on my TV set. I have to change the picture size setting "fit to screen" on. 1 Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted August 1, 2022 Share Posted August 1, 2022 Just ran into this issue with our new LG OLED when my wife was playing the switch on it for the first time. I noticed it was cutting off some of the graphics but she didn't. On our new OLED and on some older Samsungs that my company uses, we found out how to correct this. First is that older monitors that first started to feature HDMI inputs had overscan in them and no way to properly adjust for this. We found with our older Samsung monitors that using the DVI input solved this issue as in DVI the screen would fit exactly to the size of the screen without overscan. Later Samsungs finally built it into the HDMI inputs and it was found in the aspect section. The setting needed was called "Just Scan" and took care of the overscan issue. Funny thing is that my new LG uses the same terminology and it is called Just Scan on it as well. Switch is fitting the screen properly again, although now we have noticed that we are seeing more blank space border around normal TV broadcasts and I don't recall seeing that before with our older Sony 4K? Speaking of Sony... I use an older Bravia in my game room and I found out that I had to force it to tread all the inputs as if they were PC inputs. Doing this allows me to finally stop the auto brightness option as nothing else would, and it also properly adjusted the screen sizes doing this. Quote Link to comment Share on other sites More sharing options...
E. King Posted January 14 Share Posted January 14 Atari VCS Hates Sony Bravia TVs and no there is no setting on the TV to fix the cutoff screen, It is the VCS that does not autofit to the TV like all other game systems do. Quote Link to comment Share on other sites More sharing options...
