STNICCC 2000 remix for Jaguar (2nd and WIP)
42bs
15 hours ago, JagChris said:
In the source codes included with the Graphic Gems collections was a line drawing algorithm called LINE.C. It looks like Eric Smith had separated it out and was going to use it for something. Maybe you should consider throwing that in there after running it through the risc compiler and see how that one does.
Found it. It is a classical Bresenham.
Bresenham gives nicer "lines" and works better for slopes where y steps are != 1.
But for a poly algo, I do not care, I need to record  min and max X per Y. So I only need the X step and Y is always 1.
DDA:
Bresenham
So for a poly routine, Bresenham actually calculates to many X.
Triangle only routine means splitting up the > 3 point polys. But you may just adapt my poly routine.
What is the rez. of the Specci? 192x100?
For the Lynx we pre-processed scene.bin to fit the Lynx rez.
Just now, Seedy1812 said:
Speccy rez is 256*192 but on the Next there are a number of modes one being byte per pixel
So you can use the original data, maybe shrink y a bit. 1 byte per pixel, is cool. IIRC Z80 has a loop filling instruction, right? So horizontal lines can be done quick.
1 minute ago, 42bs said:
Does it have a linear gfx memory or weird thing like the Amstrad 464?
In this mode yes - but you have to page it into main memory - so you can treat the memory as 8k chunks or 16k chunks . So normally create your array of min/max x and then work down paging the memory so (0, 64 and 128  regions for y )
I want to make sure we're talking about the same line.c because it's like 3X longer than a standard Bresenham.
Does it have this header?
Symmetric Double Step Line Algorithm
by Brian Wyvill
from "Graphics Gems", Academic Press, 1990
user provides "setpixel()" function for output.
