+Larry Posted May 31, 2022 Share Posted May 31, 2022 From around 1982. Basic -- sort of. Never got much traction, AFAIK. Basic ASseMbler. Anyone used it? Anyone like it? Atarimania shows a disk dump not available, but has several ads for it. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted May 31, 2022 Share Posted May 31, 2022 I found this from Analogue Magazine, starts at page 60:- https://archive.org/details/analog-computing-magazine-11/page/n77/mode/2up You may be wondering why I haven't yet men- tioned BASM, the third "BASIC compiler" listed at the beginning of this article. The reason is simple: BASM isn't really a BASIC compiler at all. It's a BASIC assembler — an entirely new programming environment for the ATARI that looks like BASIC but acts like assembly language. Take a look at Listing 5. This is the BASM equi- valent of the speed benchmark used to test the ABC and Datasoft compilers. Notice that some of the lines look like ordinary BASIC, while others look like 6502 mnemonics. REM statements are included in those places where the BASM code differs sig- nificantly from the original BASIC. BASM programs are composed using a text editor supplied with the software. Then the source file is saved onto a disk and assembled into machine lan- guage. A very small run-time library is linked to the code, and your application is ready to run. The BASM system understands a very usable sub- set of ATARI BASIC, along with a number of state- ments and conditionals not found in the cartridge (see Listing 6). "Primitive" commands like PEEK and POKE must be replaced with their assembly- language equivalents, LDA (Load Accumulator) and STA (Store Accumulator). READ/DATA structures are implemented by using the 6502 X - and Y-registers as indexes. BASM allows you to mix BASIC and assembly statements freely, even on the same logical line. This arrangement combines the simplicity of BASIC with the power of machine language in a most ingenious manner. Because BASM programs have an assembly-like syntax, the efficiency of compilation is much greater than either ABC or Datasoft. Only the pure BASIC statements are actually "compiled" — the assembly- language sections are incorporated into the program as in-line machine code. This means that the speed of a BASM program can approach the limits of the hardware. I compiled and executed the BASM program in Listing 5 and obtained an execution time of 18 jiffies or less than 1/3 of a second. This is 231 times faster than the ATARI BASIC equivalent! Computer Alliance claims a more conservative speed improvement of up to 130 times. Not For Beginners BASM is not as straightforward to use as the ABC or the Datasoft compilers. You'll have a hard time following the 72-page reference manual unless you know something about 6502 architecture and assembly-language programming. It took me a while to grasp the syntax required for certain types of BASIC variables and addressing modes. More com- plete documentation is definitely called for — even if it means raising the price a bit. I also ran across a bug in the disk interface. My PAGE 64 A.N.A.L.O.G. COMPUTING Listing 5 8188 REM * PROGRAM EQUATES 811BSCREEf4=88 8!2eTIHER-28 0138T]HER256=1? 3148 REM * POKE 19,8:P0KE 28.8 8158 LET TIMER256 = 8 ; LET TIMER = 8 81i8 GRAPHICS 2A 8178 SETCOLOR 5 , 8 , 14 : SETCOLOR 6.8,8 8188 FOR I = 8 TO 191 : FOR J = 8 TO 3^ 8198 REM ♦ POKE SCREEN+J.255 8288 LI» «255 : LDY J : STA (SCREEN) ,Y : f-CxT J 8218 REN « SCREEN=SCREEN+48 8228 REM * THIS IS A 16-BIT BUtftRY ADDITION 8238 CLC : LDA SCREEN : ADC tt48 ; STA SCREEN 8248 LDA SCREEN+1 : ADC «8 : STA SCREEN+I 8258 NEXT 1 3388 REM « GRAPHICS 8 0318 FILE 8 8328 BPRINT TIMER ! PRINT " Ji{+ies" 8338 BPRINT T1MER256 : PRINT ■ jiffies x 256" 3348 RETURN : REM * BACK TO BASH 8358 REM » LINE 368 INITIALIZES THE VARIABLES I & J 3368 DIM I , J ISSUE 11 A.N.A.L.O.G. COMPUTING PAGE 65 Listing 6. BASM keywords. BINI'UT BPRINT CLOSE COLOR DATA DEF/ENDDEF DIM DRAWTO FILE FILL FOR/NEXT GET GOSUB GOTO GRAPHICS IF INPUT LET LOCATE OPEN PLOT POSITION PRINT PUT REM RETURN SETCOLOR SOUND STOP TR TRAP WHILE 2 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted April 4, 2023 Share Posted April 4, 2023 Well, we've got a live image now: Atarimania - BASM No manual. There was a version made for the C64; I looked a bit, but didn't see a manual for it yet either. The disk seems to have some example programs, though. 1 Quote Link to comment Share on other sites More sharing options...
+Allan Posted April 5, 2023 Share Posted April 5, 2023 Looking forward to finding the manual for this. Quote Link to comment Share on other sites More sharing options...
