4 hours ago, Aking said:
Hi everyone
Have a .bin file i need in .a78 format to play on my dragonfly.
Any way to load the file into an emulator and save as .a78 ?
Don't know the bankswitching the file is using
Thanks in advance!
Recently posted.
If the bankswitching/ROM type is not set correctly in the header, it is highly likely not to run correctly, if at all, under an emulator and probably will have issues under Dragonfly as well.
If the ROM is >48K, the correct bankswitching information would need to be acquired from the developer.
https://forums.atariage.com/topic/336300-bin-to-a78/#findComment-5066720
2 hours ago, Trebor said:
Recently posted.
If its a regular 48k file wich is the command line order to put in 7800header ?
Also to put a name on the header for df to display is it name or [name] ?
Edited by Aking
https://forums.atariage.com/topic/336300-bin-to-a78/#findComment-5066778
