Start/stop TNFS server on Windows 10 via SSH
I recently set up a TNFS server to use with FujiNet on my Atari 8-bits. Most people run the server on a Raspberry Pi, but with the current energy crisis(!) I wanted to do it from my always-on Windows 10 machine. After using files on FujiNet, even if I eject them from slots, I frequently can’t modify or delete them as they’re reported as in-use by the client I’m using, even when the FujiNet device is turned off. I haven’t tried this yet to see if it fixes the problem, but in any case, I wanted to find an easy way of restarting the server without needing to physically be on the Windows machine.
I chose to do this via SSH using Powershell. Here are the instructions for doing so in case it helps you out. Obviously this can be used to stop/start any service you like, and from any OS that gives you the ability to SSH into another machine.
There may be more elegant solutions, this is just the one I went for!
Install SSH server on Windows 10 via Powershell:
Add-WindowsCapability -Online -Name OpenSSH.Server~~~~0.0.1.0
Start and configure server:
Start the sshd service
Start-Service sshd
OPTIONAL but recommended:
Set-Service -Name sshd -StartupType 'Automatic'
Confirm the Firewall rule is configured. It should be created automatically by setup. Run the following to verify:
if (!(Get-NetFirewallRule -Name "OpenSSH-Server-In-TCP" -ErrorAction SilentlyContinue | Select-Object Name, Enabled)) {
Write-Output "Firewall Rule 'OpenSSH-Server-In-TCP' does not exist, creating it…"
New-NetFirewallRule -Name 'OpenSSH-Server-In-TCP' -DisplayName 'OpenSSH Server (sshd)' -Enabled True -Direction Inbound -Protocol TCP -Action Allow -LocalPort 22
} else {
Write-Output "Firewall rule 'OpenSSH-Server-In-TCP' has been created and exists."
Set Powershell to be default shell over OpenSSH:
New-ItemProperty -Path "HKLM:\SOFTWARE\OpenSSH" -Name DefaultShell -Value "C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe" -PropertyType String -Force
To stop the TNFS server:
taskkill /F /IM tnfsd.exe
To start the TNFS server:
start-process C:\tnfsd\tnfsd.exe C:\tnfsroot
