Modded CX80 Trackball
ILAH
I got a CX80 Atari Trackball with the original packing an manual. It has been modded. The JS - TB switch has been removed. Two cables, 1 D-Sub 9 male and 1 D-Sub female leave the case on the left side.
The function is like an Atari ST - Mouse and a joytick can be plugged to the second cable an works properly. I took some photos from inside.
Was that a common mod by a third party? I would prefer a original behaviour with joystick / trackball mode.
Anyone interested in exchanging this one against a CX22 / CX80 or Wico trackball?
What's the correct name on the mod PCB?  I can make out something that looks like 'Traecase' or 'Raecase' followed by 'Computer' depending on the angle of the photo, but would appreciate a quick clarification.
It's an interesting mod, and looks to be fairly easily reversible with the addition of the joystick / trak-ball switch.
8 hours ago, Fuji-Man said:
It didn't require that much modding, cutting a trace or two and running a few wires at most.
That's true, but the complexity of the mod shown here is due to the inclusion of an automatic switcher to allow a joystick to be left always plugged in the same port. Normally you can't just plug them in parallel - e.g. using a simple Y-cable - as they would interfere with each other.
That's what the extra board is for, and I imagine it was taken from a third party switcher, as it seems it has been filed to make it fir inside the trackball case.
