+mksmith Posted July 17, 2022 Author Share Posted July 17, 2022 ??? Outstanding!! Thank you again for putting together these examples ☺️ 3 Quote Link to comment Share on other sites More sharing options...
Traxx Posted July 30, 2022 Share Posted July 30, 2022 Thank you Eagle 3 Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted July 30, 2022 Share Posted July 30, 2022 On 7/3/2022 at 10:15 PM, Eagle said: Hmm 7000 cycles, not great, not terrible Welp, If you do 114*70 (If the screen is 192 lines, VBLANK is 70) then you get 7,980 cycles, or almost 8 KHZ per frame to work with. Now, with low DMA levels you could get more, like if you had 40 cycles at the end to work with, then that would be 15660 cycles in all... On the bright side, Quote Link to comment Share on other sites More sharing options...
+TwentySixHundred Posted August 2, 2022 Share Posted August 2, 2022 This is stunning! Racked my brain for weeks trying to achieve the same with Captain Comic using 'underthehood' and just gave up lol. I will be having some fun reading the source to try and work out exactly how this is achieved. So good. 2 Quote Link to comment Share on other sites More sharing options...
+mksmith Posted August 2, 2022 Author Share Posted August 2, 2022 It's excellent for sure. I really want to see how I can fit it into 7800basics DL setup but even if it can sit on top that would be great too. Very much quicker and cleaner than my attempt ? 3 Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted August 4, 2022 Share Posted August 4, 2022 (edited) You could use 16K RAM at $4000 and using 8K of the RAM, you can get 256*16 2byte wide 160B tiles. It's what I'm going to do for It's Conner Time 2. Edit: I think I'll not use that because 160B uses way too much DMA. Unless direct mode can save me, 160A it is. Edited September 2, 2022 by Ecernosoft Quote Link to comment Share on other sites More sharing options...
Eagle Posted August 5, 2022 Share Posted August 5, 2022 (edited) On 8/2/2022 at 8:40 AM, TwentySixHundred said: I will be having some fun reading the source to try and work out exactly how this is achieved. Turrican scroll - emulator link JS7800 If you want more fun then I attached source code for Circular scroll with decoding Tiles 4x4 from CharpadPro Have fun mwa #$00 scroll ;scroll counter=0 mwa #map sour mwa #tiles sour_tile main jsr WaitVBLANK inw scroll ;incrase word size jsr update_scroll jsr copy_scroll jmp main .macro put_4_lines lda :1 and #$0f :+4 asl @ sta temp lda :1 and #$F0 :+4 lsr @ clc adc #>tiles ;tile address sta temp+1 ldy TileX lda (temp),y sta :2+$100+32,x sta :2+[$100+32]-256,x ;duplicate for cirular buffor :+4 iny lda (temp),y sta :2+$300+32,x sta :2+[$300+32]-256,x :+4 iny lda (temp),y sta :2+$500+32,x sta :2+[$500+32]-256,x :+4 iny lda (temp),y sta :2+$700+32,x sta :2+[$700+32]-256,x .endm .use DLLs copy_scroll mwa scroll temp lsr temp+1 ror temp lsr temp+1 ror temp ;divide word/4 lda temp tax and #$03 sta TileX ; lsr temp+1 ror temp lsr temp+1 ror temp ;divide word/4 lda temp clc adc #<map sta temp lda temp+1 adc #>map sta temp+1 ldy #$00 lda (temp),y sta buffer ;extract tile number adw temp #600 temp ;add 600 (tile 4x4 map width) - next line lda (temp),y sta buffer+1 ;extract tile number adw temp #600 temp lda (temp),y sta buffer+2 ;extract tile number adw temp #600 temp lda (temp),y sta buffer+3 ;extract tile number adw temp #600 temp lda (temp),y sta buffer+4 ;extract tile number put_4_lines buffer,$4000 put_4_lines buffer+1,$4800 put_4_lines buffer+2,$5000 put_4_lines buffer+3,$5800 put_4_lines buffer+4,$6000 rts Scroll4x4.zip Edited August 5, 2022 by Eagle 3 2 Quote Link to comment Share on other sites More sharing options...
Traxx Posted August 5, 2022 Share Posted August 5, 2022 On c64 we would set an interrupt on a raster line to change the charset for the scrolling part and then set another interrupt raster line to change charsets for the Hud,do you have any code examples to accomplish that on 7800 Eagle? Quote Link to comment Share on other sites More sharing options...
Eagle Posted August 5, 2022 Share Posted August 5, 2022 (edited) @Traxx No problem, on 7800 you have DLI so is much easier then on C64 If you want full version let me now and how many changes you want (every line, every 4 lines, etc.) change bit 7 in DLL DLLs :3 .byte $0F,>emptyline,<emptyline ;3 empty DLL .byte $87,>line1,<line1 ;$87 - 8 lines + interrupt - bit 7 set DLI .byte $87,>line2,<line2 .byte $87,>line3,<line3 .byte $87,>line4,<line4 .byte $87,>line5,<line5 .byte $87,>line6,<line6 .byte $87,>line7,<line7 .byte $87,>line8,<line8 .... .... .... and then something like this Dlivect = $f0 ;any address in RAM ; ; on beginning of the program .... mwa #dli1 Dlivect .... ; NMI jmp (dlivect) DLI1 pha lda #>fnt1 ;first charset sta wsync sta chbase mwa #DLI2 dlivect pla rti DLI2 pha lda #>fnt2 ;second charset sta wsync sta chbase mwa #DLI3 dlivect pla rti DLI3 ..... ..... ..... last DLI have to set Dlivect = DLI1 Edited August 5, 2022 by Eagle 4 1 Quote Link to comment Share on other sites More sharing options...
Traxx Posted August 5, 2022 Share Posted August 5, 2022 I got it working,thank you Eagle 1 Quote Link to comment Share on other sites More sharing options...
Traxx Posted August 5, 2022 Share Posted August 5, 2022 Your right interrupts are immensely easier on 7800 Quote Link to comment Share on other sites More sharing options...
Eagle Posted August 7, 2022 Share Posted August 7, 2022 IMHO indirect mode scroll is not what A7800 should do, because of DMA and colours. Direct mode is right way to use capabilities of A7800. So today another scroll example for you guys, it's not beautiful but it works I'm using Pokey random numbers to generate screen and choose pallets I was to lazy to put nice gfx from Kirby or Mario, so you can see only numbers (instead you have to use your imagination ) Enjoy ps. You read at your own risk Direct scroll - JS7800 emulator link main jsr WaitVBLANK :40 sta wsync ;wait 40 lines to show cpu usage mva #$0a BACKGRND jsr update_scroll jsr reset_row mva #$00 BACKGRND jmp main update_scroll :170 change_x Line1,# ;decrase 170 times xpos (warning: also using 4th byte of DL_End, but DL need only two zeros) rts reset_row mwa #line1 sour ldy #$03 ;+3 - xpos in DL ldx #$00 @ lda (sour),y cmp #$F4 beq @+ adw sour #$04 inx cpx #16 bne @- rts @ :10 write_row ;write 10 times rts ;parametr :1 - address DL line, +3 (xpos in DL) ;parametr :2 - #*4 (# - loop counter) skip 4 bytes to next DL ;to make ?easier? for this example, DL_End is !!!4 bytes!!! instead of 2 bytes (sorry) .macro change_x dec :1+3+[:2*4] .endm .macro write_row lda #180 ;xpos = 180 after tile is disappear on left side ldy #$03 ;xpos in DL sta (sour),y ;don't look down :) ;this is only for draw new tiles ; ;choose random Tile lda Random and #$0F ;from 0-15 ;multiply x3 because Tiles are 3 bytes width sta temp ;=*1 asl @ ;=*2 clc adc temp ;=*3 ; ldy #$00 ;update LSB sta (sour),y ;get random pallet for Tile lda Random and #$E0 ;we use only highest 3 bits for pallet ora #$1D ;ora width of tile (3 bytes) ldy #$01 ;update pallet sta (sour),y adw sour #[17*4] ;16 DL*4bytes in one DL line + 2 zero ending DL + 2 extra zero to simplify math .endm directmodescroll.a78 DirectScrollSourceCodeMads.zip 6 Quote Link to comment Share on other sites More sharing options...
Traxx Posted August 8, 2022 Share Posted August 8, 2022 (edited) Thanks for sharing,I'm learning a lot from your code Eagle.I'm not used to mads macros so I rewrite the code without them,it's good practice until I get used to mads. Edited August 8, 2022 by Traxx 1 Quote Link to comment Share on other sites More sharing options...
+mksmith Posted August 8, 2022 Author Share Posted August 8, 2022 Nice mate thanks!! Once again compact and optimal! The scroller I added to Robots Rumble on the title screen uses this theory by the looks. 1 Quote Link to comment Share on other sites More sharing options...
Eagle Posted August 8, 2022 Share Posted August 8, 2022 Today direct mode scroll (25 colours) + 16 sprites (25 colours) I just merged my very old proc with scroll and it works Sorry for any brain damage trying to understand how it works (because I have no clue ) Enjoy Direct scroll + 16 sprites in 25 colours - link to emulator JS7800 main jsr WaitVBLANK mva #$0a BACKGRND ;show CPU usage jsr update_scroll jsr reset_row jsr Clear_all_sprites ;delete all srites from previous Vblank (put $00 in second byte after scroll/background data) jsr put_sprites_on_screen jsr Sinus_path mva #$00 BACKGRND jmp main put_sprites_on_screen ldx #$00 loop_put_sprites_on_screen lda tab_en,x stx reg_x beq skip_put_sprite jsr put_sprite skip_put_sprite ldx reg_x inx cpx #16 bne loop_put_sprites_on_screen rts Sinus_path inc sin_count lda sin_count tax ldy #$0f loop_sinus lda sinus,x clc adc #20 ;center sprites sta x_en,y txa clc adc #25 tax lda sinus,x sta y_en,y txa clc adc #15 tax dey bpl loop_sinus rts ;This time we update only DL for scrolling parts update_scroll :16 change_x Line1,# :16 change_x Line2,# :16 change_x Line3,# :16 change_x Line4,# :16 change_x Line5,# :16 change_x Line6,# :16 change_x Line7,# :16 change_x Line8,# :16 change_x Line9,# :16 change_x Line10,# rts reset_row mwa #line1 sour ldy #$03 ;+3 - xpos in DL ldx #$00 @ lda (sour),y cmp #$F4 beq @+ adw sour #$04 inx cpx #16 bne @- rts @ :10 write_row ;write 10 times rts ;parametr :1 - address DL line, +3 (xpos in DL) ;parametr :2 - #*4 (# - loop counter) skip 4 bytes to next DL ;to make ?easier? for this example, DL_End is !!!4 bytes!!! instead of 2 bytes (sorry) .macro change_x dec :1+3+[:2*4] .endm .macro write_row lda #180 ;xpos = 180 after tile is disappear on left side ldy #$03 ;xpos in DL sta (sour),y ;don't look down :) ;this is only for draw new tiles ; ;choose random Tile lda Random and #$0F ;from 0-15 ;multiply x3 because Tiles are 3 bytes width sta temp ;=*1 asl @ ;=*2 clc adc temp ;=*3 ; ldy #$00 ;update LSB sta (sour),y ;get random pallet for Tile lda Random and #$E0 ;we use only highest 3 bits for pallet ora #$1D ;ora width of tile (3 bytes) ldy #$01 ;update pallet sta (sour),y adw sour #[33*4] ;16 DL*4bytes in one DL line +16 DL*4bytes for sprites + 2 zero ending DL + 2 extra zero to simplify math .endm .macro tablica_line .word [:1],[:1+4],[:1+8],[:1+12],[:1+16],[:1+20],[:1+24],[:1+28],[:1+32],[:1+36],[:1+40],[:1+44],[:1+48],[:1+52],[:1+56],[:1+60] .endm ;Sprite addreses in DL line after scroll DL tab_line tablica_line line1+64 tablica_line line2+64 tablica_line line3+64 tablica_line line4+64 tablica_line line5+64 tablica_line line6+64 tablica_line line7+64 tablica_line line8+64 tablica_line line9+64 tablica_line line10+64 ;put $00 in second byte (dl end) Clear_all_sprites lda #$00 sta Line1+1+64 sta Line2+1+64 sta Line3+1+64 sta Line4+1+64 sta Line5+1+64 sta Line6+1+64 sta Line7+1+64 sta Line8+1+64 sta Line9+1+64 sta Line10+1+64 ldx #$0F lda #$00 loop_spr_count sta spr_count,x dex bpl loop_spr_count rts put_sprite ; I have no idea how this work :) I did this long time ago and now merged with scroll and it's working ; I translate some comments from Ponglish to English :D Enjoy ; ldy y_en,x ;Y position sty adc_temp ;copy lda tab_y,y ;address dll sta reg_a ldx tab_spr_count,y lda spr_count,x inc spr_count,x asl @ clc adc reg_a tay lda tab_line,y sta dest lda tab_line+1,y sta dest+1 ldy #$00 ldx reg_x lda tab_faz,x ;sprite address (you can use for sprite animation) sta (dest),y iny lda spr_color,x ;pallet number and width sprite sta (dest),y iny lda adc_temp and #$0f clc adc #>[sprite_data] sta (dest),y iny lda x_en,x ;x sprite sta (dest),y iny iny lda #$00 ;write $00 to mark end DL sta (dest),y lda adc_temp clc adc #16 sta adc_temp tay lda tab_y,y ;adres dll sta reg_a ldx tab_spr_count,y lda spr_count,x inc spr_count,x asl @ clc adc reg_a tay lda tab_line,y sta dest lda tab_line+1,y sta dest+1 ldy #$00 ldx reg_x lda tab_faz,x ;sprite address (you can use for sprite animation) sta (dest),y iny lda spr_color,x ;pallet number and width sprite sta (dest),y iny lda adc_temp and #$0f sec sbc #$10 clc adc #>[sprite_data] sta (dest),y iny lda x_en,x ;x sprite sta (dest),y iny iny lda #$00 ;write $00 to mark end DL sta (dest),y rts tab_y :16 .byte 0 :16 .byte $20 :16 .byte $40 :16 .byte $60 :16 .byte $80 :16 .byte $a0 :16 .byte $c0 :16 .byte $e0 tab_spr_count :16 .byte 0 :16 .byte 1 :16 .byte 2 :16 .byte 3 :16 .byte 4 :16 .byte 5 :16 .byte 6 :16 .byte 7 tab_msb :8 .byte 0 :8 .byte 1 :8 .byte 2 :8 .byte 3 :8 .byte 4 :8 .byte 5 :8 .byte 6 :8 .byte 7 :8 .byte 8 :8 .byte 9 :8 .byte 10 :8 .byte 11 :8 .byte 12 :8 .byte 14 :8 .byte 15 ;address of sprites from 0 to 15 in sprite_bank tab_faz .byte 0,3,6,9,12,15,18,21,24,27,30,33,36,39,42,45 DirectScrollSpritesSourceCodeMads.zip directmodescroll.a78 6 1 Quote Link to comment Share on other sites More sharing options...
Traxx Posted August 8, 2022 Share Posted August 8, 2022 Awesome! 1 Quote Link to comment Share on other sites More sharing options...
Cyprian Posted August 10, 2022 Share Posted August 10, 2022 well done Quote Link to comment Share on other sites More sharing options...
Eagle Posted August 10, 2022 Share Posted August 10, 2022 (edited) Just some "random" graphics from GBA 😁 Spoiler the graphics were only 4-color and I had to reduce the horizontal resolution instead of increasing the vertical resolution Sorry but AAge new links are not working with JS7800 kirbydreamland.a78 Edited August 10, 2022 by Eagle 1 Quote Link to comment Share on other sites More sharing options...
Albert Posted August 10, 2022 Share Posted August 10, 2022 23 minutes ago, Eagle said: Sorry but AAge new links are not working with JS7800 What's going on? ..Al Quote Link to comment Share on other sites More sharing options...
Eagle Posted August 10, 2022 Share Posted August 10, 2022 3 minutes ago, Albert said: What's going on? ..Al https://raz0red.github.io/js7800/?cart=https://forums.atariage.com/applications/core/interface/file/attachment.php?id=959741&key=2a4be4ece5cdc7507cfa97415beb98a8 I have no idea. Old links working fine. I think this is question to @raz0red Quote Link to comment Share on other sites More sharing options...
Albert Posted August 10, 2022 Share Posted August 10, 2022 1 minute ago, Eagle said: https://raz0red.github.io/js7800/?cart=https://forums.atariage.com/applications/core/interface/file/attachment.php?id=959741&key=2a4be4ece5cdc7507cfa97415beb98a8 I have no idea. Old links working fine. I think this is question to @raz0red Interesting, so that will load the linked attachment in the emulator? ..Al Quote Link to comment Share on other sites More sharing options...
Eagle Posted August 10, 2022 Share Posted August 10, 2022 Yes Below old link, working fine https://raz0red.github.io/js7800/?cart=https://atariage.com/forums/applications/core/interface/file/attachment.php?id=959666 Quote Link to comment Share on other sites More sharing options...
Cyprian Posted August 10, 2022 Share Posted August 10, 2022 10 minutes ago, Albert said: Interesting, so that will load the linked attachment in the emulator? ..Al and actually that was a great feature. would be cool to have it back Quote Link to comment Share on other sites More sharing options...
Albert Posted August 10, 2022 Share Posted August 10, 2022 4 minutes ago, Cyprian said: and actually that was a great feature. would be cool to have it back I need to know why it broke, first. ..Al 2 Quote Link to comment Share on other sites More sharing options...
Eagle Posted August 10, 2022 Share Posted August 10, 2022 KirbyDreamland - link JS7800 emulator 1 Quote Link to comment Share on other sites More sharing options...
