Devalis Posted July 9, 2022 Share Posted July 9, 2022 I have acquired a 520st recently and I am wondering if an internal gotek would be possible? I was thinking about adding an interposer to the floppy controller IC to give an internal floppy connector, then remove the serial connector and bypass caps and make a custom bracket for the Gotek and mount it there, then maybe make some extension so the screen and controls pop over the top of the system. Thoughts? Quote Link to comment Share on other sites More sharing options...
oky2000 Posted July 12, 2022 Share Posted July 12, 2022 IIUYC then why butcher the beautiful 520ST case, just get an STFM with a duff internal drive and make life easier. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted July 12, 2022 Share Posted July 12, 2022 9 hours ago, oky2000 said: STFM with a duff internal drive and make life easier. Then a GOEX is designed to fit inside nicely with display on top of ST. (may need to extend the floppy cable though due to having to twist it) Quote Link to comment Share on other sites More sharing options...
snarkdluG Posted July 12, 2022 Share Posted July 12, 2022 24 minutes ago, TGB1718 said: Then a GOEX is designed to fit inside nicely with display on top of ST. (may need to extend the floppy cable though due to having to twist it) The new rev.2022 of GOEX doesn't need the floppy ribbon cable to be twisted any more. So no extra extended cable should be needed. Quote Link to comment Share on other sites More sharing options...
Devalis Posted July 12, 2022 Author Share Posted July 12, 2022 That was the point of removing an unused serial or parallel connector so I won't have to modify the case and it would be reversible later if I wanted. Quote Link to comment Share on other sites More sharing options...
oky2000 Posted July 12, 2022 Share Posted July 12, 2022 2 hours ago, Devalis said: That was the point of removing an unused serial or parallel connector so I won't have to modify the case and it would be reversible later if I wanted. Ahh OK, IIUYC = If I understand you correctly, clearly I didn't sorry. Nothing wrong with wanting to use your fav' model with modern emulator file solutions. I think I have two 520STs and one boxed 520STM somewhere in my stash of gear, my fav ST compatible case design of all time. Need to do the whole retrobrite gas business with them (Ozone gas machine + huge clear plastic bag + strong sunshine I think) Quote Link to comment Share on other sites More sharing options...
bfollowell Posted July 12, 2022 Share Posted July 12, 2022 On 7/9/2022 at 2:29 PM, Devalis said: I have acquired a 520st recently and I am wondering if an internal gotek would be possible? I was thinking about adding an interposer to the floppy controller IC to give an internal floppy connector, then remove the serial connector and bypass caps and make a custom bracket for the Gotek and mount it there, then maybe make some extension so the screen and controls pop over the top of the system. Thoughts? Well, the 520ST used an external floppy drive. Why not just replace the floppy mech with a Gotek and still use the external drive as originally intended, just to keep it as original as possible? 1 Quote Link to comment Share on other sites More sharing options...
tjlazer Posted July 22, 2022 Share Posted July 22, 2022 On 7/12/2022 at 2:30 PM, bfollowell said: Well, the 520ST used an external floppy drive. Why not just replace the floppy mech with a Gotek and still use the external drive as originally intended, just to keep it as original as possible? Yep! Quote Link to comment Share on other sites More sharing options...
