42bs Posted July 13, 2022 Share Posted July 13, 2022 Hi anyone know where virtualjaguar stores the settings and the window positions? Moving from a 4K screen to a FHD screen made many windows "disappear" THX Quote Link to comment Share on other sites More sharing options...
42bs Posted July 13, 2022 Author Share Posted July 13, 2022 Ah, found, it is in the registry (Windows). Quote Link to comment Share on other sites More sharing options...
dilinger Posted July 13, 2022 Share Posted July 13, 2022 If you are using VJ Rx, there are command line options to deal with the settings. Quote Link to comment Share on other sites More sharing options...
42bs Posted July 13, 2022 Author Share Posted July 13, 2022 11 minutes ago, dilinger said: If you are using VJ Rx, there are command line options to deal with the settings. Also window positions? There is no option to reset those. At least I did not find it. Quote Link to comment Share on other sites More sharing options...
dilinger Posted July 13, 2022 Share Posted July 13, 2022 16 minutes ago, 42bs said: Also window positions? There is no option to reset those. At least I did not find it. The --es-ui option should do the trick. 1 Quote Link to comment Share on other sites More sharing options...
42bs Posted July 13, 2022 Author Share Posted July 13, 2022 I will give it a try. Thx. Quote Link to comment Share on other sites More sharing options...
42bs Posted July 13, 2022 Author Share Posted July 13, 2022 Yepp, works. But it would be nicer if the settings would be stored in a text file to easy save and modify it. But now I saved the key [HKEY_CURRENT_USER\SOFTWARE\Underground Software\Virtual Jaguar\ui] and can now switch between FHD and 4K monitor setup. Quote Link to comment Share on other sites More sharing options...
dilinger Posted July 13, 2022 Share Posted July 13, 2022 Cool. You are correct, I follow the original VJ to store the settings. I have added your suggestion in the VJ Rx's project pool of ideas. 1 Quote Link to comment Share on other sites More sharing options...
