GFA Token File Format
Hi folks. Does anyone have information about the format of the GFA basic source files? I would like to build an environment where I can write GFA code on a PC, but use the GFA compiler in a Hatari emulator to compile these sources. However, the compiler requires a GFA file (which is some kind of binary, tokenized format), so I would need to convert my ASCII source files to the ".GFA" format before feeding them to the compiler.
So - is there any documentation about the ".GFA" file format anywhere? Any hints appreciated.
Hi there,
There are certainly tools to do the opposite of what you ask (gfa->lst) but I can't find anything to do what you wish right now.
However, @lp060 has been maintaining GFA Basic (compiler side) and has created his own IDE. I suggest you visit his website (http://gfabasic.net) and probably get in touch with him. I also see in his website that there's a discord so they also can help you out.
Good luck!
I already did check it out. It helped indeed. At this point, I can kinda read a binary GFA file with a hex editor and can recognize where the variable list is and where the code lines begin :D  I do have an early simple parser which can read a source file, process the header, the variable lists and then all the program lines.
Still, apart from the fact that I need to implement a serialization/deserialization for every single command, there is one part that I don't really understand yet; the 38 4-byte pointers. I guess for your use-case they were not really important and could be ignored, but when I create GFA files, these values need to be correct (I tried setting them to 0; the GFA compiler then hangs when processing the file).
Anyway, your stuff was of great help already, so thanks for that!
Edited by babyface
  • Haha 1
