+dhe Posted July 29, 2022 Share Posted July 29, 2022 I see these terms in a goodly number of messages that go by. I look them up, and six months later they are gone again. This time I doc'ed 'em for me, hope others find this information useful. From: E/A PHM3055 - PG 301 Level 3 - File Level I/O. >00 Open >01 Close >02 Read >03 Write >04 Restore/Rewind >05 Load >06 Save >07 Delete >08 Scratch Record >09 Status From: Tech Drive Low Level I/O Level 1 routines — the lowest level — allow direct sector read/write and disk formatting. >10 Read/Write Individual Sector >11 Format Disk Level 2 routines - introduce the concept of a "file"; provide for file renaming and protection modification; allow file access by logical sector; and enable the programmer to control the number of disk buffers available. >12 Modify File Protection >13 Rename File >14 Transfer Direct Input File >15 Transfer Direct Output File >16 Buffer Allocation 3 2 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted July 29, 2022 Share Posted July 29, 2022 A concise description of the three levels can be found in the "GPL Interface Specification for the 99/4 Disk Peripheral" document. See the last entries of section 3 (in the topic below) for the GPL spec and related documents. 1 2 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted July 30, 2022 Share Posted July 30, 2022 This is true for the standard operating system in the TI 99/4A. If you instead use the p-system, you have a similar arrangement. The highest level file access involves declaing a file type (file of), where the type often is a record. Thus you define the data content of each record in the file. The filetype text is predefined and somewhat similar to DISPLAY 80 in the standard system. A bit more advanced, though. You then use some Pascal keywords to acces the file, where all access is based on handling one record in the tile at a time, or a line of characters, if it's a text file. The commands rewrite, restore and close are used to create/open and close a file. Readln and writeln to read and write with text files. Put, get and seek to handle files with custom definitions. The next level maintains the file concept, but no longer cares about the content of the file. Thus any file definition will work in the same way. The commands blockread and blockwrite are used to read/write one or more blocks in the file. A block in the p-system is 512 bytes. With these commands you can for example copy a file without knowing anything about the structure of the data in the file. The lowest level allows direct access. Here you can send or receive characters on a serial interface, or read and write disk blocks anywhere on a disk, including accessing directories or other stuff outside the file's areas. The commands unitclear, unitstatus, unitread and unitwrite are used for this access. The advantage over the standard system is that in the p-system, all levels are accessible from Pascal level. 2 Quote Link to comment Share on other sites More sharing options...
