Ecernosoft Posted July 30, 2022 Share Posted July 30, 2022 Hi! If any of you had the same experience as me, being blown away that the frenzybeserk cartridge could SPEAK... I wanted to play 4-bit samples of voice clips too. Here is the code:Voices (1).a If you set CTRL to %01000000 then you can string multiple voice clips together. Basically this is how it works: 1. "length" determines how long the sample is. 2. "location" is the word that points to the sample. 3. Samples are played at 15,720 KHZ (1 sample per WSYNC) 4. Samples can be anywhere from one byte (2 smp) or 256 bytes (512 smp) When setting CTRL to %01000000 it triggers an interupt which does this: 1. Each frame, a new sample location is fetched. 2. "Where" holds the low bytes for every sample location 3. "WhereH" holds the high bytes form every sample location 4. "Lengths" holds the lengths of each sample. So, at the cost of ~60 HZ and some audio quality, you can instead of storing one huge sample saying "Hello world!".. You can instead store a sample for H, e, l, o, W, r, and d. The bad side of doing this is it makes a pluck noise whenever the IRQ happens because the last 4 it sample plays for an extended (More than a WSYNC) period of time. Have fun with it! And, can someone record all the letters of the alphabet and numbers 0-9 using this method please? Thanks, because I wanted ICT to say "Ecerno" and then "Have you played atari today" at the begining on startup. (The second phrase might not be posible) Voices.a 1 Quote Link to comment Share on other sites More sharing options...
+Muddyfunster Posted July 30, 2022 Share Posted July 30, 2022 1 hour ago, Ecernosoft said: <snip> Have fun with it! And, can someone record all the letters of the alphabet and numbers 0-9 using this method please? Thanks, because I wanted ICT to say "Ecerno" and then "Have you played atari today" at the begining on startup. (The second phrase might not be posible) Voices.a 7.82 kB · 1 download Even if you had every letter of the alphabet recorded, you wouldn't be able to combine them to say "Have you played atari today" because that's not how speech is formed. You need phenomes to form the words. You would end up with something that sounds like "HaichAyeVeeEee" instead of "have". If you want to have speech, take a look at the AtariVox. It can be easily supported by the 7800, 2600 and I believe Vectrex. You can use AtariVox to form more complex speech sounds but of course you do need to have an AtariVox plugged into your 7800 2 Quote Link to comment Share on other sites More sharing options...
Eagle Posted July 30, 2022 Share Posted July 30, 2022 https://github.com/bit-hack/SAM 1 Quote Link to comment Share on other sites More sharing options...
gambler172 Posted July 31, 2022 Share Posted July 31, 2022 22 hours ago, Eagle said: https://github.com/bit-hack/SAM Sam for the 7800 would be cool ? Quote Link to comment Share on other sites More sharing options...
Eagle Posted July 31, 2022 Share Posted July 31, 2022 (edited) @gambler172 I know is not A8 forum but open this file with Altira and press 1 sound_engine_speak.obx Edited July 31, 2022 by Eagle Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted August 1, 2022 Share Posted August 1, 2022 On 7/30/2022 at 9:58 AM, Ecernosoft said: If any of you had the same experience as me, being blown away that the frenzybeserk cartridge could SPEAK... I wanted to play 4-bit samples of voice clips too. If the Atari 2600 can do it in a 4K binary using the TIA chip I'm sure it can be adapted for the 7800! Video below... SOURCE CODE: https://github.com/rossumur/SAM2600 DISCUSSION: https://atariage.com/forums/topic/309689-software-speech-synthesizer-for-the-2600/ - James (START AT 22:46) 2 Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted August 5, 2022 Author Share Posted August 5, 2022 Uhm.......... wow. I bet the 7800 would sound better than that! But still Wow! Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 7, 2022 Share Posted August 7, 2022 There is also the Covox on the dragonfly cart as well. 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 7, 2022 Share Posted August 7, 2022 On 7/30/2022 at 3:30 PM, Muddyfunster said: Even if you had every letter of the alphabet recorded, you wouldn't be able to combine them to say "Have you played atari today" because that's not how speech is formed. You need phenomes to form the words. You would end up with something that sounds like "HaichAyeVeeEee" instead of "have". If you want to have speech, take a look at the AtariVox. It can be easily supported by the 7800, 2600 and I believe Vectrex. You can use AtariVox to form more complex speech sounds but of course you do need to have an AtariVox plugged into your 7800 Suppose you could map out all the phenomes you'd need for your phrases, and record just them and string them together ... Have = "h" + "ä" (apple) + "v" You = "y" + "u" Played = "p" "l" "a" "i" (as in "mi") "d" etc. I agree though, Atarivox is more economical. For one thing, hitting the POKEY chip eats a lot of CPU time. Quote Link to comment Share on other sites More sharing options...
+batari Posted August 7, 2022 Share Posted August 7, 2022 On 8/5/2022 at 6:24 AM, Ecernosoft said: Uhm.......... wow. I bet the 7800 would sound better than that! But still Wow! If sound goes through the TIA or a stock POKEY chip, 7800 speech will likely sound worse than the 2600. The Maria's DMA halts the Sally and this prevents exact control of the sample rate. However, using a custom sound chip that works independently of the Sally, you can produce high-quality sound on the 7800. Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted August 7, 2022 Author Share Posted August 7, 2022 Welp, you can manage DMA. Make sure your DMA doesn't get too high. And before writing to AUDC0, you do a WSYNC to ensure you write in HBLANK. 10 hours ago, batari said: If sound goes through the TIA or a stock POKEY chip, 7800 speech will likely sound worse than the 2600. The Maria's DMA halts the Sally and this prevents exact control of the sample rate. However, using a custom sound chip that works independently of the Sally, you can produce high-quality sound on the 7800. Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted August 12, 2022 Author Share Posted August 12, 2022 On 8/7/2022 at 12:13 AM, Synthpopalooza said: There is also the Covox on the dragonfly cart as well. Yeah! That's true. 8 bit samples are better than 6 bit. Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted August 12, 2022 Author Share Posted August 12, 2022 On 7/31/2022 at 2:30 PM, Eagle said: @gambler172 I know is not A8 forum but open this file with Altira and press 1 sound_engine_speak.obx 2.43 kB · 9 downloads Who cares? As long as it's atari, then we're all good. 😃 *see, I said the Atari had more options than NES. It was more powerful on it's own and it's enhancements still beat the NES's enhancements. 4mb of ROM!* Quote Link to comment Share on other sites More sharing options...
