jguff Posted July 31, 2022 Share Posted July 31, 2022 (edited) If you are like me and are frequently confused/bewildered by one particular poster's posts, i suggest applying the Confused emoji to that poster's posts. 1) Hover over the Heart emoji, located at the bottom right of the post, and then other emojis will appear nearby. One of those emoji's is the Confused emoji. 2) Click on the Confused emoji. To view the poster's reputation (number of each emoji applied by others): 1) From any post by poster: 2) Click on the poster's name (upper left hand corner of post) 3) Click on Reputation (right hand side, bit down from top, within the <username> Achievements pane). 4) View Reactions Received (left hand side, about halfway down). The poster i'm thinking of uses 50% technical speak that seems applicable to post subject, and 50% technical jargon that does not seem applicable to post subject. I've wondered if the posts are: a) a test of artificial intelligence to write posts b) a means of encrypted communication between the poster and someone else, which has nothing to do with Atari Jaguar programming c) some sort of extended, bizzare joke Bob Edited August 20, 2022 by jguff Updating instructions after move to new forum provider/host. 6 4 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted July 31, 2022 Share Posted July 31, 2022 For this very reason, I suggest a new emoji be created - it will be called the Numberwang. 3 Quote Link to comment Share on other sites More sharing options...
jguff Posted April 24, 2023 Author Share Posted April 24, 2023 Poster is back. Very ratio'd: 2 Quote Link to comment Share on other sites More sharing options...
