alfredtdk Posted August 6, 2022 Share Posted August 6, 2022 TANK MISSION (NTSC) ? Whether the mission is by land, water or air. Tank Mission (2022) (River Raid Hack) [Alfredtdk].bin 5 Quote Link to comment Share on other sites More sharing options...
alfredtdk Posted August 6, 2022 Author Share Posted August 6, 2022 TANK MISSION - ENEMY BASES (NTSC) ? This is a version where I replace bridges with enemy bases to be destroyed. Tank Mission - Enemy Bases (2022) (River Raid Hack) [Alfredtdk].bin 1 Quote Link to comment Share on other sites More sharing options...
alfredtdk Posted August 6, 2022 Author Share Posted August 6, 2022 TANK MISSION - ENEMY BASES CLASSIC TREE (NTSC) ? As a last modification, instead of two enemy bases to be destroyed, it is now the enemy base along with the classic tree next to it. Tank Mission - Enemy Bases Classic Tree (2022) (River Raid Hack) [Alfredtdk].bin 1 Quote Link to comment Share on other sites More sharing options...
LatchKeyKid Posted August 7, 2022 Share Posted August 7, 2022 I like the combo of ground and air targets. It definitely works! 1 Quote Link to comment Share on other sites More sharing options...
alfredtdk Posted August 7, 2022 Author Share Posted August 7, 2022 (edited) TANK MISSION - MILITARY CONVOY (NTSC) ? Version only with military land vehicles, tanks and trucks. Enemy tanks now have better animation. Tank Mission - Military Convoy (2022) (River Raid Hack) [Alfredtdk].bin Edited August 7, 2022 by alfredtdk 2 Quote Link to comment Share on other sites More sharing options...
+Hydro Thunder Posted August 7, 2022 Share Posted August 7, 2022 Great hack of an all time classic!! 1 Quote Link to comment Share on other sites More sharing options...
alfredtdk Posted August 7, 2022 Author Share Posted August 7, 2022 TANK MISSION - Collection Pack (PAL) ? Collection containing 5 ROMS, all variations released for NTSC now in PAL version, including a Bonus that doesn't have for NTSC, Air Mission. Hope everyone likes it. Tank Mission Collection (PAL).zip 1 Quote Link to comment Share on other sites More sharing options...
LatchKeyKid Posted August 12, 2022 Share Posted August 12, 2022 I like the Kaboom! upon explosion. Did you change the speed of the enemies or the tank? It's an interesting change to have the option to drive past the former bridge/guard house instead of destroying it. Quote Link to comment Share on other sites More sharing options...
alfredtdk Posted August 12, 2022 Author Share Posted August 12, 2022 3 hours ago, LatchKeyKid said: I like the Kaboom! upon explosion. Did you change the speed of the enemies or the tank? It's an interesting change to have the option to drive past the former bridge/guard house instead of destroying it. Glad you liked these changes during the blast. I didn't really notice if there was an increase in the speed of enemy targets, it wasn't my intention. What happens perhaps is the behavior of some enemy targets, who pass through barriers as if they didn't exist. See my next release hack based also on River Raid, enemy targets have the same behavior as in Tank Mission. Depending on what you change in the code, you can close doors, making it impossible to play at a certain point in the game, or simply open everything and release the entire path. See the two examples below, changing just a fraction of the code and you again return to classic mode, in the second example, changing almost an entire line of programming and you will eliminate almost 100 percent of all barriers, leaving the field wide open and can eliminate everything that appears in front of you, including the trees and the small military posts, of course that will add nothing to your score. Tank Mission - Classic Mode (2022) (River Raid Hack) [Alfredtdk].bin Tank Mission - No Barriers (2022) (River Raid Hack) [Alfredtdk].bin 2 Quote Link to comment Share on other sites More sharing options...
LatchKeyKid Posted August 13, 2022 Share Posted August 13, 2022 That definitely changes the gameplay. I think I die more often to running into walls than enemies! Are you using bithacker or the annotated code to change it up? 1 Quote Link to comment Share on other sites More sharing options...
alfredtdk Posted August 14, 2022 Author Share Posted August 14, 2022 7 hours ago, LatchKeyKid said: That definitely changes the gameplay. I think I die more often to running into walls than enemies! Are you using bithacker or the annotated code to change it up? In this case I use the hex editor. Quote Link to comment Share on other sites More sharing options...
chavert Posted August 30, 2022 Share Posted August 30, 2022 I finally enjoy playing a river raid thanks to your version of the game. Thanks 1 Quote Link to comment Share on other sites More sharing options...
Eccy249 Posted October 22, 2022 Share Posted October 22, 2022 brilliant game,can I put it on my YouTube channel and call it river raid 3: tank mission,I am a massive fan of river raid and this is the best hack I have played 1 Quote Link to comment Share on other sites More sharing options...
OldSchoolRetroGamer Posted October 23, 2022 Share Posted October 23, 2022 Cool hacks you make, this and Pitfall. Very cool. 1 Quote Link to comment Share on other sites More sharing options...
