rdefabri Posted August 10, 2022 Share Posted August 10, 2022 I know there is an IDE for FastBasic, which I need to get my hands into. As I am most familiar with Atari BASIC, I am trying to shake off some rust and experimenting with coding, primarily on Altirra. However, it's a little slow, I'm not Altirra-savvy and it's a little time consuming. I'd love a Windows-based IDE that would allow me to code and then run it in a separate window - does anything like that exist? Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 10, 2022 Share Posted August 10, 2022 I doubt it. You could use a PC-based text editor then use the ENTER command with a H: device using ATASCII tranlation. But you'd still need to enter line numbers and you'd probably not be able to enter control graphics. At the end of it all, probably slower than just using a native emulated machine. Doing such things can be made less painful with some simple things like speeding up the key repeat rate. e.g. POKE 729,30 : POKE 730,3 Altirra also has the copy/paste function which you can use to post sections of code. But note that it's not going to enter the lines so care is needed. Quote Link to comment Share on other sites More sharing options...
rdefabri Posted August 10, 2022 Author Share Posted August 10, 2022 22 minutes ago, Rybags said: I doubt it. You could use a PC-based text editor then use the ENTER command with a H: device using ATASCII tranlation. But you'd still need to enter line numbers and you'd probably not be able to enter control graphics. At the end of it all, probably slower than just using a native emulated machine. Doing such things can be made less painful with some simple things like speeding up the key repeat rate. e.g. POKE 729,30 : POKE 730,3 Altirra also has the copy/paste function which you can use to post sections of code. But note that it's not going to enter the lines so care is needed. Yep as I surmised. With work and family, hard for me to commit to learning something completely new, although I suspect FastBasic might not be too difficult. My curmudgeonly personality dictates I'll probably stick with BASIC for now though. 1 Quote Link to comment Share on other sites More sharing options...
+Philsan Posted August 10, 2022 Share Posted August 10, 2022 Mad Studio works with many languages including Atari Basic. After having read first post, scroll up from the last one to find latest version. Check out topic for newbies, there are other useful programming resources. 1 Quote Link to comment Share on other sites More sharing options...
rdefabri Posted August 10, 2022 Author Share Posted August 10, 2022 24 minutes ago, Philsan said: Mad Studio works with many languages including Atari Basic. After having read first post, scroll up from the last one to find latest version. Check out topic for newbies, there are other useful programming resources. Thanks - I was working under the impression that was Pascal only, but will give it a look. Quote Link to comment Share on other sites More sharing options...
dmsc Posted August 10, 2022 Share Posted August 10, 2022 (edited) Hi! 6 hours ago, rdefabri said: Thanks - I was working under the impression that was Pascal only, but will give it a look. There are various tools that help with editing Atari BASIC in a PC: - My BASIC parser tool (at https://github.com/dmsc/tbxl-parser ) can read basic program listings (in normal or extended form) and produce BAS files directly. It supports standard Atari BASIC and TurboBasic XL. - @Irgendwer developed "Turban", this uses the above tool to simplify development in a PC, integrating an editor and the Altirra emulator: - Integrating other editors and emulators should be easy, @ggn did an integration with Notepad++ at: Edit: - You have the complete MadStudio at https://github.com/Gury8/Mad-Studio/releases/ , as Philsan said it also integrates my basic parser to allow developing BASIC programs in the PC, plus a lot of other functionality. Have Fun! Note to self: I should do a new release of the basic parser, there are a few bugfixes in the code after the last release... Edited August 10, 2022 by dmsc I can edit again :-) 4 Quote Link to comment Share on other sites More sharing options...
dmsc Posted August 10, 2022 Share Posted August 10, 2022 (edited) Hi, Tried to edit my post above, but the forum does not allow editing currently 😞 To the above, I forgot to add the great MadStudio at https://github.com/Gury8/Mad-Studio/releases/ , as Philsan said it also integrates my basic parser to allow developing BASIC programs in the PC. Have Fun! Edit: now editing works again, added info above!. Edited August 10, 2022 by dmsc I can edit again :-) Quote Link to comment Share on other sites More sharing options...
rdefabri Posted August 10, 2022 Author Share Posted August 10, 2022 13 minutes ago, dmsc said: Hi! There are various tools that help with editing Atari BASIC in a PC: - My BASIC parser tool (at https://github.com/dmsc/tbxl-parser ) can read basic program listings (in normal or extended form) and produce BAS files directly. It supports standard Atari BASIC and TurboBasic XL. - @Irgendwer developed "Turban", this uses the above tool to simplify development in a PC, integrating an editor and the Altirra emulator: - Integrating other editors and emulators should be easy, @ggn did an integration with Notepad++ at: Have Fun! Note to self: I should do a new release of the basic parser, there are a few bugfixes in the code after the last release... Thanks - I'll check into this! Quote Link to comment Share on other sites More sharing options...
+MrFish Posted August 10, 2022 Share Posted August 10, 2022 3 hours ago, dmsc said: - My BASIC parser tool (at https://github.com/dmsc/tbxl-parser ) can read basic program listings (in normal or extended form) and produce BAS files directly. It supports standard Atari BASIC and TurboBasic XL. - @Irgendwer developed "Turban", this uses the above tool to simplify development in a PC, integrating an editor and the Altirra emulator: - Integrating other editors and emulators should be easy, @ggn did an integration with Notepad++ at: 3 hours ago, rdefabri said: Thanks - I'll check into this! I'm using the basicParser for all my larger TBXL development projects. I've also done my own integration with Notepad++, using the NppExec plugin (which is still in active development) and my own custom language highlighter configuration, for Notepad++. I'm not sure why @Irgendwer is using line numbers in his examples, as they are not needed. 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted August 10, 2022 Share Posted August 10, 2022 4 hours ago, dmsc said: Note to self: I should do a new release of the basic parser, there are a few bugfixes in the code after the last release... Any details on the bugs? Quote Link to comment Share on other sites More sharing options...
dmsc Posted August 11, 2022 Share Posted August 11, 2022 Hi! 41 minutes ago, MrFish said: Any details on the bugs? From https://github.com/dmsc/tbxl-parser/compare/v10...master : - Fixes parsing of "TIME$" when the parser expected number or string (i.e, PRINT TIME$ ). - Fixed writing TBXL programs with 256 variables, or Atari BASIC with 128 variables. - Fixed parsing of "SOUND" without parameters. Also, extends the Atari BASIC parser to allow (and convert): - %0 to %3 - IF without THEN - PUT without # - Hex numbers Also, I added two more optimizations and better long-list output. Have Fun! 2 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted August 11, 2022 Share Posted August 11, 2022 3 minutes ago, dmsc said: - Fixed writing TBXL programs with 256 variables, or Atari BASIC with 128 variables. Obviously this one is of particular interest to me. Any more information on this? Good to hear your still planning updates for the basicParser. Thanks Quote Link to comment Share on other sites More sharing options...
+MrFish Posted August 11, 2022 Share Posted August 11, 2022 19 minutes ago, dmsc said: From https://github.com/dmsc/tbxl-parser/compare/v10...master : - Fixed writing TBXL programs with 256 variables, or Atari BASIC with 128 variables. 13 minutes ago, MrFish said: Obviously this one is of particular interest to me. Any more information on this? I missed your link the first time. So, it looks like it's just related to writing exactly 256 (TBXL) or 128 (Atari BASIC) variables. Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted August 11, 2022 Share Posted August 11, 2022 13 hours ago, MrFish said: I'm not sure why @Irgendwer is using line numbers in his examples, as they are not needed. I'm not using line numbers. The link image uses a screen shot not part my post, but can be found in the thread... Quote Link to comment Share on other sites More sharing options...
OxC0FFEE Posted September 19, 2022 Share Posted September 19, 2022 On 8/10/2022 at 8:51 PM, MrFish said: Good to hear your still planning updates for the basicParser. I'm also glad to hear you're still working on basicParser, @dmsc. It'd be a huge win if it supported obfuscating/parsing FB code as well (or do you have a separate tool for crunching FB code?) I'd use something like "basicParser -vcs0n long.bas >short.bas" (iirc, though that was 100% from memory) to get TBXL programs down to size for my previous tenliners. Currently there's no way to do this for FB other than manual abbreviation, correct? Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted September 19, 2022 Share Posted September 19, 2022 (edited) Try this: https://x868k.com/apps/memopad/?os=win lets you directly edit ATASCII files on a PC. Will also import BASIC files from most Atari BASICs. Edited September 19, 2022 by Synthpopalooza Quote Link to comment Share on other sites More sharing options...
