ulao Posted August 10, 2022 Share Posted August 10, 2022 I have done a few of these now but I'm human, thus I make errors... I have modded another 4 port atari 5200 to use a side power jack. Instead of connecting the 12v input to the place I should, I mistakenly plugged it in to the 5 volt output used for the AV mod ( where the transister was removed). I'm not able to turn on the unit now that I put the 12 volts in to the correct point and I think I took out a regulator. No LED and no power at that trasnister point. Just a bit unclear were to look. I have two 5200 4 ports side by side so I can make checks, just looking for anyone with more experience here. I left out the detail as I'm thinking someone that does this mod would be best fit but happy to add detail for anyone willing to help. I use this write up https://console5.com/wiki/Atari_5200 "4-Port Switchbox Elimination Modification" Basically making my own power jack. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted August 10, 2022 Share Posted August 10, 2022 What were you trying to do different compared to how this is normally done? It is one of the easier modifications to do for a console and pretty much a requirement for the 4 port systems. Obviously some pics if you can share them of exactly where you initially had your wiring attached so that others can get a better idea of what else could be impacted by the initial mistake that was made. If you can get it back to semi stock condition, then it would be good to start with seeing if you are able to get both input voltage to the pair of 7805s and if they are putting out any voltage on their output pins. Quote Link to comment Share on other sites More sharing options...
ulao Posted August 10, 2022 Author Share Posted August 10, 2022 (edited) 35 minutes ago, -^CrossBow^- said: What were you trying to do different compared to how this is normally done? It is one of the easier modifications to do for a console and pretty much a requirement for the 4 port systems. Different? No, just a normal mod. Like I mentioned I have done many, I just made the error on this one and I think I messed it up as a result. I have done over 20 of them, I buy 4 ports unwanted from thrift fix them up and mod them. Normally goes well. Helps not to make the wrong connections. Quote If you can get it back to semi stock condition, then it would be good to start with seeing if you are able to get both input voltage to the pair of 7805s and if they are putting out any voltage on their output pins. No I do not have the modulator power adapter. So if it was back to the original state I'd have no way to power it up. I have no way to know if this was a bad atari but in my experience then tends to all be in working order. Either way I should be able to trace the power on down thru the circuit just looking to any suggestions along the way. attached where I connected the + ~12 Edited August 10, 2022 by ulao Quote Link to comment Share on other sites More sharing options...
ulao Posted August 10, 2022 Author Share Posted August 10, 2022 (edited) Ok this transister middle leg is not showing anything on the questionable board but shows 12v on the good board. Its the one on the lower right of the image above (bottom transister) Edited August 10, 2022 by ulao Quote Link to comment Share on other sites More sharing options...
ulao Posted August 10, 2022 Author Share Posted August 10, 2022 never mind that, I was comparing with the power on. To be equal I need to compare with the power off. Quote Link to comment Share on other sites More sharing options...
ulao Posted August 10, 2022 Author Share Posted August 10, 2022 Ok the CD4013 was bad. There were two pins that should have 12 volts when switched on and one pin would not show 12 volts. I happened to have an extra CD4013 so that part is replaced but the damage is elsewhere . Quote Link to comment Share on other sites More sharing options...
ulao Posted August 20, 2022 Author Share Posted August 20, 2022 just a follow up, the internal trace ( the trace inside the pcb) burned up. I made a bridge connection. The video worked but was black and white, adjusting the pot (lower right) fixed the B&W issue. Unit full working Quote Link to comment Share on other sites More sharing options...
