Ecernosoft Posted August 11, 2022 Share Posted August 11, 2022 Hello! I sucessfully flashed the firmware... but it still thinks it's a harmony cart. Can someone please post the correct firmware down below? I'm very confused... (Now it just says "Bios file was not found" and it has the harmony firmware) Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted August 11, 2022 Author Share Posted August 11, 2022 I'm sorry that I've posted 3 times about this, I just can't figure this out... 🤨 Quote Link to comment Share on other sites More sharing options...
+batari Posted August 11, 2022 Share Posted August 11, 2022 It sounds like you have the "EEPROM loader" installed. The EEloader is a temporary operating system based on Harmony firmware, and its function is to look for a BIOS file on the SD card. At this point, just copy the attached file to your SD card, insert into your Concerto and boot. Although it says "press a button to continue" after a successful flash of BIOS, you actually need to power cycle after that for Concerto BIOS. The latest build of the Concerto BIOS is in the firmware thread here: https://forums.atariage.com/topic/314640-concerto-firmware-thread/?do=findComment&comment=5103077 Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted August 11, 2022 Author Share Posted August 11, 2022 Ok. Do I need to have the harmony bios too on the SD card? Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted August 11, 2022 Author Share Posted August 11, 2022 7 minutes ago, batari said: It sounds like you have the "EEPROM loader" installed. The EEloader is a temporary operating system based on Harmony firmware, and its function is to look for a BIOS file on the SD card. At this point, just copy the attached file to your SD card, insert into your Concerto and boot. Although it says "press a button to continue" after a successful flash of BIOS, you actually need to power cycle after that for Concerto BIOS. The latest build of the Concerto BIOS is in the firmware thread here: https://forums.atariage.com/topic/314640-concerto-firmware-thread/?do=findComment&comment=5103077 When I do that, it says the bios file wasn't found. Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted August 11, 2022 Author Share Posted August 11, 2022 Even after power-cycling it still does that. Do I need to select the concerto bios in the EEPROM loader thing on the harmony software? Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted August 11, 2022 Author Share Posted August 11, 2022 Did I need all the other files on the Harmony to still be there? On my bios 1.05 I currently have: hbios (Harmony?) Concerto hbios 7782 build (1) Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted August 11, 2022 Author Share Posted August 11, 2022 Just what files do I need in the Bios1.05 on the harmony SD card? (my SD) Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted August 11, 2022 Author Share Posted August 11, 2022 YAY IT WORKS!! Quote Link to comment Share on other sites More sharing options...
