maelstrom9510 Posted August 15, 2022 Share Posted August 15, 2022 Hello there! I'm working on creating a BBS using Waffle 1.65 and a Lantronix UDS10 serial-to-ethernet controller. Everything works great except the UDS10 doesn't seem to understand when to "hang up". When a person leaves the board with "bye", Waffle sends a disconnect signal to the UDS10. But the UDS10 just sits there like the session is still happening. The next "caller" is unable to log in because the UDS10 has not released the previous telnet session, because (seemingly) it is ignoring Waffle's request to "hang up". I have to manually reboot the UDS10 after every "call". Everything else works great, but this has me stumped. Any ideas? Thank you! Quote Link to comment Share on other sites More sharing options...
maelstrom9510 Posted August 17, 2022 Author Share Posted August 17, 2022 So the problem seems to be that Waffle is terminating the modem with "ATH" before allowing the telnet session to close. Quote Link to comment Share on other sites More sharing options...
MarkO Posted October 18, 2022 Share Posted October 18, 2022 (edited) On 8/15/2022 at 3:57 PM, maelstrom9510 said: Hello there! I'm working on creating a BBS using Waffle 1.65 and a Lantronix UDS10 serial-to-ethernet controller. Everything works great except the UDS10 doesn't seem to understand when to "hang up". When a person leaves the board with "bye", Waffle sends a disconnect signal to the UDS10. But the UDS10 just sits there like the session is still happening. The next "caller" is unable to log in because the UDS10 has not released the previous telnet session, because (seemingly) it is ignoring Waffle's request to "hang up". I have to manually reboot the UDS10 after every "call". Everything else works great, but this has me stumped. Any ideas? Thank you! What Disconnect Signal is Waffle sending to the UDS10?? Can you use the DSR/DTR to control the ON Hook/OFF Hook Status? The UDS10 supports Modem Mode commands with a 1 Second Delay, then Three '+' , with no longer that 1 Second Delay, then another 1 Second Delay. The UDS10 Prompts, "OK", then you send "ATH" and Enter and the UDS10 Prompts with another "OK". This will Disconnect the Session.. ( See Lantronx UDS10/100 Manual, PDF Page31 ) https://www.lantronix.com/wp-content/uploads/pdf/UDS10-UDS100_UG.pdf MarkO Edited October 18, 2022 by MarkO Quote Link to comment Share on other sites More sharing options...
