rietveld Posted August 16, 2022 Share Posted August 16, 2022 I just ordered a F18a but can't find an offset socket for my stand alone adam If I put the F18a in my colecovision will the expansion module 3 work with it using the VGA out? Quote Link to comment Share on other sites More sharing options...
NIAD Posted August 16, 2022 Share Posted August 16, 2022 2 hours ago, rietveld said: I just ordered a F18a but can't find an offset socket for my stand alone adam If I put the F18a in my colecovision will the expansion module 3 work with it using the VGA out? Yes, you can install it in your ColecoVision and pretty sure that you don't need the Offset Board... it's for the Stand-Alone ADAM ColecoVision PCB. However, I don't recall if it affects the use of the Exp. Mod. #1 Atari Adapter or not as well as RF output. You should be able to find info about that on Matthew's website if no one chimes in to confirm things. Quote Link to comment Share on other sites More sharing options...
digress Posted August 16, 2022 Share Posted August 16, 2022 I think it would work fine. I don't have an exp module 3 anymore to test with my f18a colecovision but the video out is still coming from the colecovision when I did have one. It should just replace the video chip of the coleco but the output would still operate in normal TMS9918 mode anyways. Quote Link to comment Share on other sites More sharing options...
Captain Cozmos Posted August 17, 2022 Share Posted August 17, 2022 What confuses me is that the 38 was the obvious upgrade from the 28 yet the original SGM Exp 3 claimed that it would bring more vibrant colors ect.... to the Colecovision but how was this going to happen unless it was going to use the 38? As we have seen that this was changed to ADAM which still used the 28. What is also confusing is that from my knowledge the video piggyback line to the Colecovision 28 is not even connected. The Atari 2600 EXP 1 is just an Atari that passed through using a power supply, audio/video and I think the CPU clock. The 9928 series has the ability to layer external chips but Coleco in their wisdom.... Maybe that is also why the CED player was dumped because the video would never pass through. Quote Link to comment Share on other sites More sharing options...
rietveld Posted August 31, 2022 Author Share Posted August 31, 2022 (edited) My f18a is in the mail. Can anyone confirm if a f18a modded colecovision and expansion module 3 will work together? If not then I will just put it into a stand alone adam Edited August 31, 2022 by rietveld Quote Link to comment Share on other sites More sharing options...
digress Posted September 1, 2022 Share Posted September 1, 2022 install a socket in the colecovision then you can test it and or replace it with the original vdp. I expect it will work fine in the coleco with module 3. same amount of soldering / desoldering to put a socket in. 1 Quote Link to comment Share on other sites More sharing options...
rietveld Posted September 25, 2022 Author Share Posted September 25, 2022 IT WORKS 1 Quote Link to comment Share on other sites More sharing options...
