chevymad Posted August 19, 2022 Share Posted August 19, 2022 I built a 576nucc fujinet board, which i'm installing in my 1088xel. I've got the board flashed and it works fine with the SD card. However, it doesn't see any wifi networks. I thought maybe I got a bad wrover module, so I swapped it with a new one tonight. But it acts exactly the same way. I was able to pair bluetooth with my phone as well. I've loaded several demos and games from the sd card, works great as an sdrive but wifi is the reason for being so if anyone has some ideas please. Both of these boards are the E variety with no external antenna connection. The little shunt to the internal antenna seems to be in place as well. Also my router works fine with another fujinet I have. But I did also try an older router as well and even my phone's hotspot with none of these showing on the fujinet. Quote Link to comment Share on other sites More sharing options...
mozzwald Posted August 19, 2022 Share Posted August 19, 2022 Can you capture some debug output of Fujinet starting up and scanning for networks? https://github.com/FujiNetWIFI/fujinet-platformio/wiki/FujiNet-Flasher#capturing-serial-debug-output Quote Link to comment Share on other sites More sharing options...
chevymad Posted August 19, 2022 Author Share Posted August 19, 2022 It'll probably be tomorrow before I can do anything. Quote Link to comment Share on other sites More sharing options...
chevymad Posted August 21, 2022 Author Share Posted August 21, 2022 Spoiler Using 'COM5' as serial port. Showing logs: [21:38:11] [21:38:11] CF: 31 3f 20 00 90 [21:38:11] FujiNet CONFIG boot [21:38:11] disk sio_process() [21:38:11] ACK! [21:38:11] sio HSIO INDEX [21:38:11] ->SIO write 1 bytes [21:38:11] COMPLETE! [21:38:12] [21:38:12] CF: 08 fe 08 fe 08 [21:38:12] CHECKSUM_ERROR [21:38:12] [21:38:12] CF: 08 fe 08 fe 08 [21:38:12] CHECKSUM_ERROR [21:38:12] Toggling baudrate from 19200 to 67431 [21:38:12] [21:38:12] CF: 31 53 00 00 84 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] disk STATUS [21:38:12] response: 0x00, 0xff, 0xe0 [21:38:12] ->SIO write 4 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 01 00 84 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 02 00 85 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 03 00 86 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 04 00 87 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 05 00 88 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 06 00 89 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 07 00 8a [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 08 00 8b [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 09 00 8c [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 3f 00 00 70 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] sio HSIO INDEX [21:38:12] ->SIO write 1 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 0a 00 8d [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 0b 00 8e [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 0c 00 8f [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 0d 00 90 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 0e 00 91 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 0f 00 92 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 10 00 93 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 11 00 94 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 12 00 95 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 13 00 96 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 14 00 97 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:12] [21:38:12] CF: 31 52 15 00 98 [21:38:12] FujiNet CONFIG boot [21:38:12] disk sio_process() [21:38:12] ACK! [21:38:12] ATR READ [21:38:12] ->SIO write 128 bytes [21:38:12] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 16 00 99 [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 17 00 9a [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 18 00 9b [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 19 00 9c [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 1a 00 9d [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 1b 00 9e [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 1c 00 9f [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 1d 00 a0 [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 1e 00 a1 [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 1f 00 a2 [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 20 00 a3 [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 21 00 a4 [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 22 00 a5 [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 23 00 a6 [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 24 00 a7 [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 25 00 a8 [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 26 00 a9 [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 27 00 aa [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 28 00 ab [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 29 00 ac [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 2a 00 ad [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 2b 00 ae [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:13] [21:38:13] CF: 31 52 2c 00 af [21:38:13] FujiNet CONFIG boot [21:38:13] disk sio_process() [21:38:13] ACK! [21:38:13] ATR READ [21:38:13] ->SIO write 128 bytes [21:38:13] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 2d 00 b0 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 2e 00 b1 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 2f 00 b2 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 30 00 b3 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 31 00 b4 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 32 00 b5 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 33 00 b6 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 34 00 b7 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 35 00 b8 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 36 00 b9 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 37 00 ba [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 38 00 bb [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 39 00 bc [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 3a 00 bd [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 3b 00 be [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 3c 00 bf [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 3d 00 c0 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 3e 00 c1 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 3f 00 c2 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 40 00 c3 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 41 00 c4 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 42 00 c5 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:14] [21:38:14] CF: 31 52 43 00 c6 [21:38:14] FujiNet CONFIG boot [21:38:14] disk sio_process() [21:38:14] ACK! [21:38:14] ATR READ [21:38:14] ->SIO write 128 bytes [21:38:14] COMPLETE! [21:38:15] [21:38:15] CF: 31 52 44 00 c7 [21:38:15] FujiNet CONFIG boot [21:38:15] disk sio_process() [21:38:15] ACK! [21:38:15] ATR READ [21:38:15] ->SIO write 128 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 31 52 45 00 c8 [21:38:15] FujiNet CONFIG boot [21:38:15] disk sio_process() [21:38:15] ACK! [21:38:15] ATR READ [21:38:15] ->SIO write 128 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 31 52 46 00 c9 [21:38:15] FujiNet CONFIG boot [21:38:15] disk sio_process() [21:38:15] ACK! [21:38:15] ATR READ [21:38:15] ->SIO write 128 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 31 52 47 00 ca [21:38:15] FujiNet CONFIG boot [21:38:15] disk sio_process() [21:38:15] ACK! [21:38:15] ATR READ [21:38:15] ->SIO write 128 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 31 52 48 00 cb [21:38:15] FujiNet CONFIG boot [21:38:15] disk sio_process() [21:38:15] ACK! [21:38:15] ATR READ [21:38:15] ->SIO write 128 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 31 52 49 00 cc [21:38:15] FujiNet CONFIG boot [21:38:15] disk sio_process() [21:38:15] ACK! [21:38:15] ATR READ [21:38:15] ->SIO write 128 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 31 52 4a 00 cd [21:38:15] FujiNet CONFIG boot [21:38:15] disk sio_process() [21:38:15] ACK! [21:38:15] ATR READ [21:38:15] ->SIO write 128 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 31 52 4b 00 ce [21:38:15] FujiNet CONFIG boot [21:38:15] disk sio_process() [21:38:15] ACK! [21:38:15] ATR READ [21:38:15] ->SIO write 128 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 31 52 4c 00 cf [21:38:15] FujiNet CONFIG boot [21:38:15] disk sio_process() [21:38:15] ACK! [21:38:15] ATR READ [21:38:15] ->SIO write 128 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 31 52 4d 00 d0 [21:38:15] FujiNet CONFIG boot [21:38:15] disk sio_process() [21:38:15] ACK! [21:38:15] ATR READ [21:38:15] ->SIO write 128 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 31 52 4e 00 d1 [21:38:15] FujiNet CONFIG boot [21:38:15] disk sio_process() [21:38:15] ACK! [21:38:15] ATR READ [21:38:15] ->SIO write 128 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 31 52 4f 00 d2 [21:38:15] FujiNet CONFIG boot [21:38:15] disk sio_process() [21:38:15] ACK! [21:38:15] ATR READ [21:38:15] ->SIO write 128 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 31 52 50 00 d3 [21:38:15] FujiNet CONFIG boot [21:38:15] disk sio_process() [21:38:15] ACK! [21:38:15] ATR READ [21:38:15] ->SIO write 128 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 31 52 51 00 d4 [21:38:15] FujiNet CONFIG boot [21:38:15] disk sio_process() [21:38:15] ACK! [21:38:15] ATR READ [21:38:15] ->SIO write 128 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 31 52 52 00 d5 [21:38:15] FujiNet CONFIG boot [21:38:15] disk sio_process() [21:38:15] ACK! [21:38:15] ATR READ [21:38:15] ->SIO write 128 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 00 38 38 00 00 [21:38:15] CHECKSUM_ERROR [21:38:15] [21:38:15] CF: 00 38 38 00 00 [21:38:15] CHECKSUM_ERROR [21:38:15] Toggling baudrate from 67431 to 19200 [21:38:15] [21:38:15] CF: 70 ea 00 00 5b [21:38:15] sioFuji::sio_process() called [21:38:15] ACK! [21:38:15] Fuji cmd: GET WIFI ENABLED: 1 [21:38:15] ->SIO write 1 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 70 fe 00 00 6f [21:38:15] sioFuji::sio_process() called [21:38:15] ACK! [21:38:15] Fuji cmd: GET SSID [21:38:15] ->SIO write 97 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 70 e8 00 00 59 [21:38:15] sioFuji::sio_process() called [21:38:15] ACK! [21:38:15] Fuji cmd: GET ADAPTER CONFIG [21:38:15] ->SIO write 140 bytes [21:38:15] COMPLETE! [21:38:15] [21:38:15] CF: 70 fd 00 00 6e [21:38:15] sioFuji::sio_process() called [21:38:15] ACK! [21:38:15] Fuji cmd: SCAN NETWORKS [21:38:15] esp_wifi_scan_start returned error 12289 [21:38:15] ->SIO write 4 bytes [21:38:15] COMPLETE! Quote Link to comment Share on other sites More sharing options...
mozzwald Posted August 21, 2022 Share Posted August 21, 2022 52 minutes ago, chevymad said: [21:38:15] esp_wifi_scan_start returned error 12289 If you are building/flashing the firmware yourself with platformio, make sure you also 'Upload filesystem Image'. If you are using fujinet-flasher, remove your SD card from the FujiNet and do a fresh flash. Leave the SD card out and try again. Also, please capture the FujiNet startup messages. Plug in the USB cable to FujiNet and the computer, start the capture on the computer, press reset on FujiNet to see it's startup log. 1 Quote Link to comment Share on other sites More sharing options...
chevymad Posted August 21, 2022 Author Share Posted August 21, 2022 I've been using the fujinet-flasher. I had tried 2 different SD cards and booting without it. I'm not positive if I ever flashed without the card though. That seems to have worked. I did try putting the card back in before erasing fnconfig and that killed it again and I had to reflash. I've now erased both fnconfig files from the cards and will try them again tomorrow. The fujinet is working fine without the card for now though. Now to test the cards again and put this thing back together! Thank you for your assistance! Quote Link to comment Share on other sites More sharing options...
chevymad Posted August 21, 2022 Author Share Posted August 21, 2022 So last night I used one of the older firmware's. So before putting the xel together I thought i'd try flashing the newest one again. I did this once before and it scanned but my keyboard quit working. Well it still does that. My networks come up, but my keyboard is nonfunctional using this firmware. Spoiler Using 'COM5' as serial port. Showing logs: [10:40:15] [10:40:15] CF: 31 3f 20 00 90 [10:40:15] FujiNet CONFIG boot [10:40:15] disk sio_process() [10:40:15] ACK! [10:40:15] sio HSIO INDEX [10:40:15] ->SIO write 1 bytes [10:40:15] COMPLETE! [10:40:15] [10:40:15] CF: 08 fe 08 fe 08 [10:40:15] CHECKSUM_ERROR [10:40:15] [10:40:15] CF: 08 fe 08 fe 08 [10:40:15] CHECKSUM_ERROR [10:40:15] Toggling baudrate from 19200 to 67431 [10:40:15] [10:40:15] CF: 31 53 00 00 84 [10:40:15] FujiNet CONFIG boot [10:40:15] disk sio_process() [10:40:15] ACK! [10:40:15] disk STATUS [10:40:15] response: 0x00, 0xff, 0xe0 [10:40:15] ->SIO write 4 bytes [10:40:15] COMPLETE! [10:40:15] [10:40:15] CF: 31 52 01 00 84 [10:40:15] FujiNet CONFIG boot [10:40:15] disk sio_process() [10:40:15] ACK! [10:40:15] ATR READ [10:40:15] ->SIO write 128 bytes [10:40:15] COMPLETE! [10:40:15] [10:40:15] CF: 31 52 02 00 85 [10:40:15] FujiNet CONFIG boot [10:40:15] disk sio_process() [10:40:15] ACK! [10:40:15] ATR READ [10:40:15] ->SIO write 128 bytes [10:40:15] COMPLETE! [10:40:15] [10:40:15] CF: 31 52 03 00 86 [10:40:15] FujiNet CONFIG boot [10:40:15] disk sio_process() [10:40:15] ACK! [10:40:15] ATR READ [10:40:15] ->SIO write 128 bytes [10:40:15] COMPLETE! [10:40:15] [10:40:15] CF: 31 52 04 00 87 [10:40:15] FujiNet CONFIG boot [10:40:15] disk sio_process() [10:40:15] ACK! [10:40:15] ATR READ [10:40:15] ->SIO write 128 bytes [10:40:15] COMPLETE! [10:40:15] [10:40:15] CF: 31 52 05 00 88 [10:40:15] FujiNet CONFIG boot [10:40:15] disk sio_process() [10:40:15] ACK! [10:40:15] ATR READ [10:40:15] ->SIO write 128 bytes [10:40:15] COMPLETE! [10:40:15] [10:40:15] CF: 31 52 06 00 89 [10:40:15] FujiNet CONFIG boot [10:40:15] disk sio_process() [10:40:15] ACK! [10:40:15] ATR READ [10:40:15] ->SIO write 128 bytes [10:40:15] COMPLETE! [10:40:15] [10:40:15] CF: 31 52 07 00 8a [10:40:15] FujiNet CONFIG boot [10:40:15] disk sio_process() [10:40:15] ACK! [10:40:15] ATR READ [10:40:15] ->SIO write 128 bytes [10:40:15] COMPLETE! [10:40:15] [10:40:15] CF: 31 52 08 00 8b [10:40:15] FujiNet CONFIG boot [10:40:15] disk sio_process() [10:40:15] ACK! [10:40:15] ATR READ [10:40:15] ->SIO write 128 bytes [10:40:15] COMPLETE! [10:40:15] [10:40:15] CF: 31 52 09 00 8c [10:40:15] FujiNet CONFIG boot [10:40:15] disk sio_process() [10:40:15] ACK! [10:40:15] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 3f 00 00 70 [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] sio HSIO INDEX [10:40:16] ->SIO write 1 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 0a 00 8d [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 0b 00 8e [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 0c 00 8f [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 0d 00 90 [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 0e 00 91 [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 0f 00 92 [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 10 00 93 [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 11 00 94 [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 12 00 95 [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 13 00 96 [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 14 00 97 [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 15 00 98 [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 16 00 99 [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 17 00 9a [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 18 00 9b [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 19 00 9c [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 1a 00 9d [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 1b 00 9e [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 1c 00 9f [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 1d 00 a0 [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 1e 00 a1 [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 1f 00 a2 [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:16] [10:40:16] CF: 31 52 20 00 a3 [10:40:16] FujiNet CONFIG boot [10:40:16] disk sio_process() [10:40:16] ACK! [10:40:16] ATR READ [10:40:16] ->SIO write 128 bytes [10:40:16] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 21 00 a4 [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 22 00 a5 [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 23 00 a6 [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 24 00 a7 [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 25 00 a8 [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 26 00 a9 [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 27 00 aa [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 28 00 ab [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 29 00 ac [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 2a 00 ad [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 2b 00 ae [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 2c 00 af [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 2d 00 b0 [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 2e 00 b1 [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 2f 00 b2 [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 30 00 b3 [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 31 00 b4 [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 32 00 b5 [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 33 00 b6 [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 34 00 b7 [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 35 00 b8 [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 36 00 b9 [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:17] [10:40:17] CF: 31 52 37 00 ba [10:40:17] FujiNet CONFIG boot [10:40:17] disk sio_process() [10:40:17] ACK! [10:40:17] ATR READ [10:40:17] ->SIO write 128 bytes [10:40:17] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 38 00 bb [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 39 00 bc [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 3a 00 bd [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 3b 00 be [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 3c 00 bf [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 3d 00 c0 [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 3e 00 c1 [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 3f 00 c2 [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 40 00 c3 [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 41 00 c4 [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 42 00 c5 [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 43 00 c6 [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 44 00 c7 [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 45 00 c8 [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 46 00 c9 [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 47 00 ca [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 48 00 cb [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 49 00 cc [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 4a 00 cd [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 4b 00 ce [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 4c 00 cf [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 4d 00 d0 [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 4e 00 d1 [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:18] COMPLETE! [10:40:18] [10:40:18] CF: 31 52 4f 00 d2 [10:40:18] FujiNet CONFIG boot [10:40:18] disk sio_process() [10:40:18] ACK! [10:40:18] ATR READ [10:40:18] ->SIO write 128 bytes [10:40:19] COMPLETE! [10:40:19] [10:40:19] CF: 31 52 50 00 d3 [10:40:19] FujiNet CONFIG boot [10:40:19] disk sio_process() [10:40:19] ACK! [10:40:19] ATR READ [10:40:19] ->SIO write 128 bytes [10:40:19] COMPLETE! [10:40:19] [10:40:19] CF: 31 52 51 00 d4 [10:40:19] FujiNet CONFIG boot [10:40:19] disk sio_process() [10:40:19] ACK! [10:40:19] ATR READ [10:40:19] ->SIO write 128 bytes [10:40:19] COMPLETE! [10:40:19] [10:40:19] CF: 31 52 52 00 d5 [10:40:19] FujiNet CONFIG boot [10:40:19] disk sio_process() [10:40:19] ACK! [10:40:19] ATR READ [10:40:19] ->SIO write 128 bytes [10:40:19] COMPLETE! [10:40:19] [10:40:19] CF: 00 38 38 00 00 [10:40:19] CHECKSUM_ERROR [10:40:19] [10:40:19] CF: 00 38 38 00 00 [10:40:19] CHECKSUM_ERROR [10:40:19] Toggling baudrate from 67431 to 19200 [10:40:19] [10:40:19] CF: 70 ea 00 00 5b [10:40:19] sioFuji::sio_process() called [10:40:19] ACK! [10:40:19] Fuji cmd: GET WIFI ENABLED: 1 [10:40:19] ->SIO write 1 bytes [10:40:19] COMPLETE! [10:40:19] [10:40:19] CF: 70 fe 00 00 6f [10:40:19] sioFuji::sio_process() called [10:40:19] ACK! [10:40:19] Fuji cmd: GET SSID [10:40:19] ->SIO write 97 bytes [10:40:19] COMPLETE! [10:40:19] [10:40:19] CF: 70 e8 00 00 59 [10:40:19] sioFuji::sio_process() called [10:40:19] ACK! [10:40:19] Fuji cmd: GET ADAPTER CONFIG [10:40:19] ->SIO write 140 bytes [10:40:19] COMPLETE! [10:40:19] [10:40:19] CF: 70 fd 00 00 6e [10:40:19] sioFuji::sio_process() called [10:40:19] ACK! [10:40:19] Fuji cmd: SCAN NETWORKS [10:40:21] WIFI_EVENT_SCAN_DONE [10:40:21] esp_wifi_scan returned 10 results [10:40:21] ->SIO write 4 bytes [10:40:21] COMPLETE! [10:40:21] [10:40:21] CF: 70 fc 00 00 6d [10:40:21] sioFuji::sio_process() called [10:40:21] ACK! [10:40:21] Fuji cmd: GET SCAN RESULT [10:40:21] ->SIO write 34 bytes [10:40:21] COMPLETE! [10:40:21] [10:40:21] CF: 70 fc 01 00 6e [10:40:21] sioFuji::sio_process() called [10:40:21] ACK! [10:40:21] Fuji cmd: GET SCAN RESULT [10:40:21] ->SIO write 34 bytes [10:40:21] COMPLETE! [10:40:21] [10:40:21] CF: 70 fc 02 00 6f [10:40:21] sioFuji::sio_process() called [10:40:21] ACK! [10:40:21] Fuji cmd: GET SCAN RESULT [10:40:21] ->SIO write 34 bytes [10:40:21] COMPLETE! [10:40:21] [10:40:21] CF: 70 fc 03 00 70 [10:40:21] sioFuji::sio_process() called [10:40:21] ACK! [10:40:21] Fuji cmd: GET SCAN RESULT [10:40:21] ->SIO write 34 bytes [10:40:21] COMPLETE! [10:40:21] [10:40:21] CF: 70 fc 04 00 71 [10:40:21] sioFuji::sio_process() called [10:40:21] ACK! [10:40:21] Fuji cmd: GET SCAN RESULT [10:40:21] ->SIO write 34 bytes [10:40:21] COMPLETE! [10:40:21] [10:40:21] CF: 70 fc 05 00 72 [10:40:21] sioFuji::sio_process() called [10:40:21] ACK! [10:40:21] Fuji cmd: GET SCAN RESULT [10:40:21] ->SIO write 34 bytes [10:40:21] COMPLETE! [10:40:21] [10:40:21] CF: 70 fc 06 00 73 [10:40:21] sioFuji::sio_process() called [10:40:21] ACK! [10:40:21] Fuji cmd: GET SCAN RESULT [10:40:21] ->SIO write 34 bytes [10:40:21] COMPLETE! [10:40:21] [10:40:21] CF: 70 fc 07 00 74 [10:40:21] sioFuji::sio_process() called [10:40:21] ACK! [10:40:21] Fuji cmd: GET SCAN RESULT [10:40:21] ->SIO write 34 bytes [10:40:21] COMPLETE! [10:40:31] BUTTON_C: SHORT PRESS [10:40:31] ACTION: Reboot [10:40:31] Shutting down device 5a [10:40:31] Shutting down device 43 [10:40:31] Shutting down device 50 [10:40:31] Shutting down device 40 [10:40:31] Shutting down device 99 [10:40:31] Shutting down device 45 [10:40:31] Shutting down device 70 [10:40:31] disk UNMOUNT [10:40:31] disk UNMOUNT [10:40:31] disk UNMOUNT [10:40:31] disk UNMOUNT [10:40:31] disk UNMOUNT [10:40:31] disk UNMOUNT [10:40:31] disk UNMOUNT [10:40:31] disk UNMOUNT [10:40:31] Shutting down device 5f [10:40:31] Shutting down device 78 [10:40:31] Shutting down device 77 [10:40:31] Shutting down device 76 [10:40:31] Shutting down device 75 [10:40:31] Shutting down device 74 [10:40:31] Shutting down device 73 [10:40:31] Shutting down device 72 [10:40:31] Shutting down device 71 [10:40:31] Shutting down device 38 [10:40:31] Shutting down device 37 [10:40:31] Shutting down device 36 [10:40:31] Shutting down device 35 [10:40:31] Shutting down device 34 [10:40:31] Shutting down device 33 [10:40:31] Shutting down device 32 [10:40:31] Shutting down device 31 [10:40:31] All devices shut down. [10:40:31] WIFI_EVENT_STA_STOP [10:40:31] Shutdown handler called [10:40:31] Shutting down device 5a [10:40:31] Shutting down device 43 [10:40:31] Shutting down device 50 [10:40:31] Shutting down device 40 [10:40:31] Shutting down device 99 [10:40:31] Shutting down device 45 [10:40:31] Shutting down device 70 [10:40:31] disk UNMOUNT [10:40:31] disk UNMOUNT [10:40:31] disk UNMOUNT [10:40:31] disk UNMOUNT [10:40:31] disk UNMOUNT [10:40:31] disk UNMOUNT [10:40:31] disk UNMOUNT [10:40:31] disk UNMOUNT [10:40:31] Shutting down device 5f [10:40:31] Shutting down device 78 [10:40:31] Shutting down device 77 [10:40:31] Shutting down device 76 [10:40:31] Shutting down device 75 [10:40:31] Shutting down device 74 [10:40:31] Shutting down device 73 [10:40:31] Shutting down device 72 [10:40:31] Shutting down device 71 [10:40:31] Shutting down device 38 [10:40:31] Shutting down device 37 [10:40:31] Shutting down device 36 [10:40:31] Shutting down device 35 [10:40:31] Shutting down device 34 [10:40:31] Shutting down device 33 [10:40:31] Shutting down device 32 [10:40:31] Shutting down device 31 [10:40:31] All devices shut down. [10:40:31] [10:40:31] [10:40:31] --~--~--~-- [10:40:31] FujiNet 0.5.fd038d41 2022-06-05 01:37:38 Started @ 4 [10:40:31] Starting heap: 4376715 [10:40:31] Detected Hardware Version: 1.6.1 and up [10:40:31] Enabled Safe Reset Button C [10:40:32] SPIFFS mounted. [10:40:32] E (1452) vfs_fat_sdmmc: sdmmc_card_init failed (0x107). [10:40:32] SD mount failed with code #263, "ESP_ERR_TIMEOUT" [10:40:32] fnConfig::load [10:40:32] Load fnconfig.ini from spiffs [10:40:32] fnConfig::load read 563 bytes from config file [10:40:32] SPIFFS Config Storage: Enabled [10:40:32] fnConfig::load read 563 bytes from SPIFFS config file [10:40:32] WiFiManager::start() complete [10:40:32] WIFI_EVENT_STA_START [10:40:32] disk UNMOUNT [10:40:32] disk MOUNT [10:40:32] ATR MOUNT [10:40:32] mounted ATR: paragraphs=5760, sect_size=128, sect_count=720, disk_size=0 [10:40:32] Creating a default printer using FS_SPIFFS storage and type 1 [10:40:32] SSH client initialized. [10:40:32] ModemSniffer::ModemSniffer(FS_SPIFFS) [10:40:32] SIO SETUP [10:40:32] Set HSIO baud from 0 to 67431 (index 6), alt=68209 [10:40:32] Available heap: 4239935 [10:40:32] Setup complete @ 578 (574ms) Quote Link to comment Share on other sites More sharing options...
chevymad Posted August 21, 2022 Author Share Posted August 21, 2022 If I go back to 0.5.b28073ee my keyboard functions again. Quote Link to comment Share on other sites More sharing options...
mozzwald Posted August 21, 2022 Share Posted August 21, 2022 53 minutes ago, chevymad said: If I go back to 0.5.b28073ee my keyboard functions again. I've got no idea how the FujiNet firmware would effect the keyboard. I'm guessing this has the TKII thingy in it. Maybe @mytek has a clue? The CONFIG program did not change b/w those 2 firmware versions. 56 minutes ago, chevymad said: [10:40:32] WiFiManager::start() complete [10:40:32] WIFI_EVENT_STA_START This looks good and the scan results showed. Maybe you had a bad fnconfig.ini on the sd cards. Quote Link to comment Share on other sites More sharing options...
chevymad Posted August 21, 2022 Author Share Posted August 21, 2022 Definitly odd. One thing I didn't try was to use a joystick to try and select something. Perhaps the computer was completely locked up at that point instead of just the keyboard. I've tried twice now and it didnt work either time. Not a huge problem, the older firmware does everything I want anyway, and I'm bout done playing with it for the moment. Thanks again for your help! Quote Link to comment Share on other sites More sharing options...
+mytek Posted August 22, 2022 Share Posted August 22, 2022 5 hours ago, mozzwald said: I've got no idea how the FujiNet firmware would effect the keyboard. I'm guessing this has the TKII thingy in it. Maybe @mytek has a clue? Yeah that's definitely weird. Unless the FujiNet firmware that's loaded on boot-up has inadvertently changed something with Pokey's keyboard scan routines, it really shouldn't mess with the keyboard. After all it's an SIO device, which would have no reason that I can think of to change anything other than stuff that relates to that communication bus. But if you can bounce back and forth between new and old firmware iterations and see the keyboard stop working, and then start working each and every time, that points to Pokey's keyboard aspect being somehow altered in the new version. Maybe not enough to prevent a stock keyboard from functioning (has that been confirmed independently on a different system?), but enough to throw TKII off track. Quote Link to comment Share on other sites More sharing options...
chevymad Posted August 22, 2022 Author Share Posted August 22, 2022 Another thought I had. If the fujinet is still all connected up when it's flashed. Can that do anything to the tkII? The XEL wasn't powered up.. but i'm not sure if it can backfeed. Right now it's a hassle to disconnect all the pins so i've left them connected. Quote Link to comment Share on other sites More sharing options...
+mytek Posted August 22, 2022 Share Posted August 22, 2022 17 hours ago, chevymad said: Another thought I had. If the fujinet is still all connected up when it's flashed. Can that do anything to the tkII? The XEL wasn't powered up.. but i'm not sure if it can backfeed. Right now it's a hassle to disconnect all the pins so i've left them connected. The PIC chip for the TKII can't be reprogrammed by the Atari side of things (it would actually be cool if that were possible). The TKII programming pins require external connection to some kind of programmer. BTW, when the keyboard stops working, is that everything? So in other words, is it every key that stops responding, or do the console key equivalents still work (F2-F5, specifically F5 for RESET). Also curious if ALT+Insert toggles the Scroll Lock LED or ALT+M cycles through the Mouse Port Selection LEDs. Quote Link to comment Share on other sites More sharing options...
chevymad Posted August 22, 2022 Author Share Posted August 22, 2022 I know reset doesn't work. For the rest I'll need to reflash again to try. Also I'm not sure if it's just the keyboard or if the whole computer locks up. I didn't think about trying a controller to scroll the menu. Quote Link to comment Share on other sites More sharing options...
+mytek Posted August 22, 2022 Share Posted August 22, 2022 35 minutes ago, chevymad said: I know reset doesn't work. For the rest I'll need to reflash again to try. Also I'm not sure if it's just the keyboard or if the whole computer locks up. I didn't think about trying a controller to scroll the menu. No rush, since I'll be incognito for the rest of the day (heading up to my vacation home). Quote Link to comment Share on other sites More sharing options...
chevymad Posted August 24, 2022 Author Share Posted August 24, 2022 Well reflashed to the newest firmware tonight. It worked.. differently. It allowed me to pick my network. Then when I started typing my password it froze and only entered half the password. After that errored out and I reset everything, I re-entered the password it seems to be working. I'm going to play with it awhile and see what happens. Quote Link to comment Share on other sites More sharing options...
chevymad Posted August 25, 2022 Author Share Posted August 25, 2022 Spent the night in the ER to have a chunk of steel removed from my face. So haven't had alot of time to play around. I seem to be having some stability problems now. Doubt that it has to do with the fujinet, more likely my VBXE. I may disassemble it and replace the VBXE with a new one I bought recently. This one didn't work very well at all in my XLD, then worked pretty good in the XEL, but now weird things are happening. There's a weird drop out in the middle of Numen where the tv loses signal for a minute. Also once in awhile I get a red screen with fuzzy lettering. I have to shut clear down and let the caps discharge, then restart to get a normal screen again. Now the starter went out in my jeep tonight. So I need to go change that in a few. Been a fun week. Quote Link to comment Share on other sites More sharing options...
chevymad Posted August 27, 2022 Author Share Posted August 27, 2022 And then the wife tested positive for covid. After being vacced and double boosted even. Been a helluva week. Maybe I'll get some more Atari time this weekend. Quote Link to comment Share on other sites More sharing options...
chevymad Posted September 15, 2022 Author Share Posted September 15, 2022 Well, I ended up with covid as well. Anyway, I installed a new VBXE. It's more stable then the old one, and more vbxe specific software works with it. The old vbxe some stuff wouldn't play, and I just wouldn't know why it didn't. So I noticed some newer firmware came out. I went ahead and flashed it with the newest BT firmware version last night. Tried it out tonight. At first most of the keyboard didn't function again. Direction arrows, space bar etc. But Option and Reset did work. I was able to select the files I wanted with a joystick and press option. It errored a few times, acted like it needed more time. Then worked and I played a game. Reset the fujinet and pressed Reset on the keyboard. When it booted back up the keyboard all functioned like it's supposed to. Haven't had an issue since. I'm going to play with it awhile longer, then screw the machine back together. So far seems to work well enough. Nice to have an internal fujinet. Quote Link to comment Share on other sites More sharing options...
