TIstang Posted August 19, 2022 Share Posted August 19, 2022 So, everyone (but me) has heard this one, right? I have a PEB that has worked well for many years, mostly. I notice with this system that there are times when it does not respond - at all. But 99% of the time all is good. Well, starting last Friday the disk drive just decided it was going to stop reading disks. Spin, spin, spin, red lights then nothing. Checked the connections, pulled the drive, nothing evident, put it back together, still nothing. Fortunately, I have another PEB, a complete one. Swap it out, problem solved. Until this morning. Same thing, no response spin, spin, spin red lights and all. There is no way both of these units have crapped out at the same time. Everything I can tell, regarding the console seems fine. It can see the 32K in TI writer the cassette reads in etc, Though I am going to switch out the console to see if that helps and hook up a parallel printer to see if Basic can see that through the box, I believe the original problem will persist. So, I wanted to get this into the ether to see if this can be resolved. I am sure somebody out there has seen this. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
WhataKowinkydink Posted August 19, 2022 Share Posted August 19, 2022 I'm assuming both PEBs were using *different* disk drives? Quote Link to comment Share on other sites More sharing options...
TIstang Posted August 19, 2022 Author Share Posted August 19, 2022 Yes, each PEB has its own controller, RS 232, 32K and flex cable interface. Just dropped one PEB in place of the other. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted August 19, 2022 Share Posted August 19, 2022 Different disk? Look for power issues at how your connecting, extension cord, or old power strip. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted August 20, 2022 Share Posted August 20, 2022 tried cleaning the heads? bad disk dirtying up both drives? Quote Link to comment Share on other sites More sharing options...
TIstang Posted August 20, 2022 Author Share Posted August 20, 2022 Thank you both, I will try these options and let you know. Quote Link to comment Share on other sites More sharing options...
