Neogeoman Posted August 27, 2022 Share Posted August 27, 2022 JUST OUT OF CURIOSITY IS ANYONE ELSE HAVING A PROBLEM WITH AZTEC CHALLENGE? IVE TRIED THE GAME ON TWO DIFFERENT COLECOVISIONS BOTH WITH AND WITHOUT THE SGM INSERTED AND ITS THE SAME. THE FIRST LEVEL PLAYS FINE FOR A LITTLE BIT THEN I KEEP DYING FOR NO APPARENT REASON. I EITHER DIE BEFORE THE ARROW TOUCHES ME OR AFTER I JUMP OVER AND CLEAR IT I DIE. THIS IS CONSISTENT AND IT KEEPS HAPPENING SOMETIMES MY CHARACTER KEELS OVER WHEN THE ARROW MAKES ITS APPEARANCE ON THE SCREEN. I DONT GET IT... TRIED PULLING THE CART AND REINSERTING IT AND NOTHING THE PROBLEM PERSISTS. THE GAME IS UNPLAYABLE. ANY ONE ELSE EXPERIENCING THIS? THANKS Quote Link to comment Share on other sites More sharing options...
TPR Posted August 27, 2022 Share Posted August 27, 2022 I've not had this happen with my copy, but it would appear you're also experiencing a glitch in your CAPS LOCK key! 3 Quote Link to comment Share on other sites More sharing options...
Neogeoman Posted August 27, 2022 Author Share Posted August 27, 2022 What is the caps lock key? 1 Quote Link to comment Share on other sites More sharing options...
+evg2000 Posted August 27, 2022 Share Posted August 27, 2022 i haven’t had any issues either Quote Link to comment Share on other sites More sharing options...
+5-11under Posted August 27, 2022 Share Posted August 27, 2022 CAPS LOCK STUCK ON. SHOUTING. DIFFICULT TO READ. Caps lock not stuck on. Not shouting. Easier to read. 1 Quote Link to comment Share on other sites More sharing options...
Ikrananka Posted August 27, 2022 Share Posted August 27, 2022 I played my copy of the game again recently and it worked perfectly. I've never experienced the glitch you describe. Quote Link to comment Share on other sites More sharing options...
NIAD Posted August 28, 2022 Share Posted August 28, 2022 Do you have a Coleco or CBS version of the ColecoVision? Have your systems been modded in anyway such as a different version of the BIOS or the ground plane screw above the cartridge connector was removed. Have you tested other games on these systems to make sure they are working properly and there isn’t a possible issue with overheating of the power supply, bad RAM, etc. Do you have the means to dump the cart to a rom image and test the resulting dump with an emulator an or with the AtariMax Ultimate SD Cart? The issue you describe is VERY odd to say the least and would seem more like a faulty cart and even the it such an odd issue that a faulty cart doesn’t seem like a possibility. Quote Link to comment Share on other sites More sharing options...
Neogeoman Posted August 29, 2022 Author Share Posted August 29, 2022 23 hours ago, NIAD said: Do you have a Coleco or CBS version of the ColecoVision? Have your systems been modded in anyway such as a different version of the BIOS or the ground plane screw above the cartridge connector was removed. Have you tested other games on these systems to make sure they are working properly and there isn’t a possible issue with overheating of the power supply, bad RAM, etc. Do you have the means to dump the cart to a rom image and test the resulting dump with an emulator an or with the AtariMax Ultimate SD Cart? The issue you describe is VERY odd to say the least and would seem more like a faulty cart and even the it such an odd issue that a faulty cart doesn’t seem like a possibility. I'm using it on two modded colecovisions that now have av mods. As far as I know they have no other mods other than that. I guess I can dig out my original unmodded coleco and also try it on my PHOENIX. If that doesn't work I think it's a bad cart. Quote Link to comment Share on other sites More sharing options...
NIAD Posted August 29, 2022 Share Posted August 29, 2022 Def test the cart on your original CV and Phoenix. On your 2 AV modded CVs, open the cartridge slot flap and shine a flashlight in. Check that there is a screw that fastens the PCB to the bottom plastic housing just above the cartridge connector. I think that you should be able to see it otherwise a small mirror might be needed. Quote Link to comment Share on other sites More sharing options...
