Switch1995 Posted September 1, 2022 Share Posted September 1, 2022 Hello 99ers, I picked up a Royal Alpha 2015 that I’m going to try and get setup as a printer. Looking at the manual, it appears every period computer needed a specific cable (RS232 to Centronics). Does anybody know if there is anything available “off the shelf” that would have the pin outs of Royal P/N PCUA 013156. I’m assuming I’ll have to make a cable, but doesn’t hurt to check. Thanks! Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted September 1, 2022 Share Posted September 1, 2022 I don't think there was anything out there specific to Royal. Smith-Corona and Okidata both required cables specific to them, and one or two other vendors actually used their in-house designed interfaces to plug into the console (the Alphacom81 interface comes to mind here, but I think there were one or two others as well). Almost every printer out there will work with the standard TI Centronics cable, the Smith-Corona cable, or the Okidata cable though, as between the three of them, they covered just about every available Centronics variant, signal-wise. IEC still makes all three cables commercially too (just go a bit over halfway down the linked page to find them). None of them cost over $20, and IEC has been a strong supporter of the TI since the 1980s. They're actually the only company left that has provided hardware support for the TI that long. 2 2 Quote Link to comment Share on other sites More sharing options...
Switch1995 Posted September 1, 2022 Author Share Posted September 1, 2022 Thanks, Ksarul. I ordered one of each and will report back on this thread after testing in case anybody else is interested in the Royal Alpha 2015. 1 Quote Link to comment Share on other sites More sharing options...
WhataKowinkydink Posted September 1, 2022 Share Posted September 1, 2022 6 hours ago, Ksarul said: IEC still makes all three cables commercially too (just go a bit over halfway down the linked page to find them). None of them cost over $20, and IEC has been a strong supporter of the TI since the 1980s. They're actually the only company left that has provided hardware support for the TI that long. That's pretty cool - thanks! Quote Link to comment Share on other sites More sharing options...
+TheBF Posted September 2, 2022 Share Posted September 2, 2022 "Looking at the manual, it appears every period computer needed a specific cable (RS232 to Centronics)." I am a bit confused. Does @Switch1995 need an RS232 to Centronics (Royal Alpha) parallel cable or TI-99 PIO to Centronics cable? 1 Quote Link to comment Share on other sites More sharing options...
Switch1995 Posted September 2, 2022 Author Share Posted September 2, 2022 The three cables from IEC all have the right connections. Now it is just a matter of testing to see if one has the right pinouts Quote Link to comment Share on other sites More sharing options...
+TheBF Posted September 2, 2022 Share Posted September 2, 2022 40 minutes ago, Switch1995 said: The three cables from IEC all have the right connections. Now it is just a matter of testing to see if one has the right pinouts Sounds like a good plan. For reference those cables are TI99 PIO (parallel In/Out) to Centronics. The RS232 part of the card is on the DB25 connector. That was why I was confused. Sometimes I am confused but other times I'm not sure... 1 Quote Link to comment Share on other sites More sharing options...
Switch1995 Posted September 2, 2022 Author Share Posted September 2, 2022 It is very confusing (for me)! The manual indicated that you could use the DB25 serial connection too, but needed a interface box that Royal sold. Not sure if any of those survived. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted September 2, 2022 Share Posted September 2, 2022 (edited) 5 hours ago, Switch1995 said: It is very confusing (for me)! The manual indicated that you could use the DB25 serial connection too, but needed a interface box that Royal sold. Not sure if any of those survived. That is correct. To convert RS232 (serial data) , to parallel , (8 separate bit wires + control signal wires) takes some hardware so an interface box would be needed. Probably not the best solution since TI-99 has the PIO port sitting there for driving old style printers. As I recall 40 years ago I wired up my own using my epson printer manual and the TI-99 PIO documentation. Edited September 2, 2022 by TheBF typo Quote Link to comment Share on other sites More sharing options...
Switch1995 Posted October 26, 2022 Author Share Posted October 26, 2022 Just to close the loop on this thread in case it is ever searched down the road: The three TI PIO to Centronics cables received from IEC were of very high quality. They make them to order and ship. The Royal Alpha 2015, however, is currently in a landfill. After about 5 power-on cycles it began to smoke. At that point, the juice wasn't worth the squeeze (for me). This was more a little hobby side-bar than a need for a printer. 1 Quote Link to comment Share on other sites More sharing options...
