Ecernosoft Posted September 3, 2022 Share Posted September 3, 2022 Hello! Ok, so I have a problem. When I compile my source code on DASM, I can't find the .bin file. I'm using Visual Studio code, so how do I get a .bin file from the assembler? I also have the Atari dev studio for VS code. If you need more information let me know. The reason I'm asking is because untill now, everything I make is in 8bitworkshop. But 8bitworkshop is flawed, specifically in the 7800 stuff. Most of the external features aren't supported, and even some amount of internal ones don't exist or are porrly emulated. Thanks! Quote Link to comment Share on other sites More sharing options...
+Karl G Posted September 3, 2022 Share Posted September 3, 2022 Check the bin/ subdirectory that was likely created when you assembled with VSC. Edit: Also check your compile messages in the terminal window after you attempted to assemble. I'm not 100% sure if VSC can do 7800 ASM without making use of a Makefile. Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted September 3, 2022 Author Share Posted September 3, 2022 Hmmm, ok. not saying I’ll use dasm though. I’ll try that though. Quote Link to comment Share on other sites More sharing options...
