tschak909 Posted September 4, 2022 Share Posted September 4, 2022 (edited) The #FujiNet NOS for #Atari8bit is progressing nicely, thanks to the hard work of Michael Sternberg @16kRAM Version 0.3.0 adds: * an on-line help system (which pulls its pages from GitHub!) * simple batch processing (using the SOURCE command) * TYPE command to view files Still to be done, is a COPY command. But even at this stage, I am sure you will agree, that this DOS Replacement shows significant flexibility and usefulness. Do you want to hack on it? The code is here: https://github.com/FujiNetWIFI/fujinet-nhandler in the nos/ folder. and the bootable ATR is on atari-apps.irata.online in the DOS/ folder. Edited September 4, 2022 by tschak909 mention. 8 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted September 11, 2022 Share Posted September 11, 2022 (edited) Hi Thom, would it be helpful if MADS could build the complete ATR file directly from the source and Michael would only need to rename the file from nos.xex to nos.atr? Since I do not have a Github account, here in plain text the needed changes: ;;; Initialization ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ORG $0700 OPT h- becomes ; ATR Header OPT h- ORG $0700 DTA $96,$02,$80,$16,$80 :11 DTA $00 ;;; Initialization ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ORG $0700 and EDIT: Removed because the offsets do not calculate correctly. Edited September 11, 2022 by DjayBee Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted September 12, 2022 Share Posted September 12, 2022 I had to remove the HELP command from NOS to have enough free memory. It seems to work. Writing data, also from the VC/SC converter, produces garbage. This might be a problem of Fujinet-PC which I used for testing. I do not have hardware at hand at the moment. 1 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted September 12, 2022 Author Share Posted September 12, 2022 Check that out, @16kRAM! awesome! -Thom Quote Link to comment Share on other sites More sharing options...
